Question about Schecter Hellraiser C 1 Fr Electric Guitar Cherry
HI THERE. I VE BEEN CHANGE MY SHECTER'S STRINGS, BUT I DONT KNOW WHY THEY´RE TOUCHING THE HUMBUKERS AND SOUND BADLY. WHAT DO I HAVE TO DO?
    President:
  • 1,138 Answers
Try adjusting the pickup height lower and playing your guitar. If your action is set right and it plays fine then adjust the pickups for the sound you want. You may have inadvertently changed string guages. Here is a link that will help you:http://www.projectguitar.com/tut/aph.htm Also:http://www.igdb.co.uk/pages/guitar_setup/pickup_height_adjustment.htm
Posted on Aug 22, 2010
How change strings gibson guitar?
One of the best was to keeping your guitar in tune, is to also string it correctly and use new strings . Make sure the first winding of a new string around the tuner post goes over the exposed tip of the new string. The rest of the windings go under the exposed tip of the string. This will keep the string clamped firmly in place. Use 4-5 turns around the post for unwound strings, 2-3 for wound strings, in a downward spiral towards the bottom of the post as shown in the photo.-Tom, 30yr player.
Apr 15, 2016 | Gibson Les Paul Studio Electric Guitar
My 3rd guitar string sounds bad
Get it a repare at guitar center they have a pack of guitar strings for 5-10 Dollers they are located in Oregon Washington cailfoina if you relly want a cheep guitar that sounds good get bc rich or finder or eipcphone your guitar strings are probley getting old you have to buy a certain brad of stings that well last a year and if you need tuneing you can download an app for online tuning or you can type in online guitar tuneing I hoped this helped give me a message if you need more
Nov 25, 2012 | Dean Guitars Dean Ml Xm Electric Guitar
Gretsch G5120 strings go severely sharp on open D chord
Are you, by any chance, pushing the strings a little too hard? You may be unaware of it, but some people who are used to playing power or bar chords, tend to push too hard in first position. On an electric guitar, this can cause the unwanted sharping. Plus, if you're more attuned to playing acoustic guitar, this can sometimes happen as well. I don't know if this is the problem, since I've never seen you play, but you might want to check it out.
Sep 13, 2012 | Gretsch G5120 Electromatic® - Orange with...
I`ve just bought a new Fender Telecaster Deluxe. When I plug it into my amp there`s a slight hissing hum. When I touch the strings it stops. I`ve tried it through a different amp & changed leads so
you may have a ground loop problem and when you touch the strings you complete the ground loop so the noise dissapears. make sure the amp is plugged into a proper grounded outlet. also there is an aftermarket ground plate that goes under the pick guard. that is what I put on mine to cut the emf way down. if you bought the guitar from a dealer take it back to the store and ask them why you are getting so much noise.
Nov 26, 2011 | Fender American Deluxe Telecaster
Hey my ax260 strings rattle alot mainly the bass strings? and every time i touch the coil tap knob a ugly sound comes from the amp its not even a year old yet and never been knocked over or droped could...
Strings "rattling" is usually guitar setup. This has to do with string height and POSSIBLY the neck truss rod. For the latter, have a guitar shop set it up for you. Hum from touching a knob is likely a broken ground wire in the cavity of the guitar. Also view videos on YouTube search "Guitar setup"
Apr 27, 2011 | ESP Ltd EX-50 Electric Guitar
How do I change the strings on my Dean Vendetta
How to Change Strings on a Dean Vendetta Guitar
Dean Vendetta is a company that makes a wide range of electric guitars. These guitars are used by famous musicians and bands such as Alice in Chains and Megadeath. If you own a Dean Vendetta guitar, you will need to change the strings periodically in order to keep your guitar sounding bright and crisp. Without changing the strings, your instrument will sound dull due to dirt and oil build-up on the strings.
Instructions
Things You'll Need:
* Dean Vendetta guitar
* String winder
* Guitar strings
* Electronic tuner
* Wire cutters
Locate the high E string. This is the string that is highest and thinnest and closest to the ground when you play the guitar.
Loosen the high E string by turning its tuning key counterclockwise. Use a string winder for this if you have one. Pull the string off of the tuning peg and out through the bridge.
Insert a new high E string through the hole in the bridge, up the neck, to the head of the guitar.
Thread the string through the hole in the tuning key so that about two inches extends beyond the hole.
Hold the string at the top end of the neck in one hand as you turn the tuning key clockwise with the other hand. A string winder makes this task much easier.
Continue to wind the string until it tightens to pitch. Use an electronic tuner to check the pitch.
Clip off the excess string with wire cutters.
Repeat these steps to install the B, G, D, A, and low E strings.
Tips & Warnings
Expect to re-tune often for the first few hours after installing the new strings, as they tend to stretch quite a bit at first.
Hope it helped.
Thanks for using fixya..
Jan 14, 2011 | Dean Vendetta XM Electric Guitar
I don't know how to change the strings on my shector 006 deluxe, any help please? ive had the guitar a few months now and think it is due a change in strings, however i feel unsure about uncsreweing parts...
There are instructions on YouTube.com regarding changing strings on guitars. The video illustrations are much better than trying to write in words the proceedure.
Apr 23, 2010 | Schecter 006 Deluxe Electric Guitar...
Washburn guitar B and high E string sound real buzzy-tinny. am fretting it clean. It just started doing it. Any Help?
Probably time for string replacement !!! They do go bad...
Get a set and try the E string... if it fixes that one, change ALL the strings at one sitting, but do them one at a time and tune each as you go... this keeps the tension and minimizes the interaction when you do the final tuning.
Feb 27, 2010 | Washburn Idol Series WI18QT Electric...
"G" string tunning problems,
hi there .... flat means does the string go lower in pitch ...needing the string to be tightend after you have bent it ?
Do you give the strings a real good pull a few times after fitting? this often corrects the problem .... let me know ..as there could be a few other reasons
cheers Pete
Feb 02, 2009 | Epiphone Les Paul 100 Electric Guitar
Problem with the pickup sound on the 'g' string on my epiphone les paul standard
Hi ! Must be a problem with either the nut or the g-saddle in the bridge of the guitar.
Good luck , Stefan from Sweden
Nov 10, 2008 | Epiphone Music
Schecter Hellraiser C 1 Fr Electric Guitar Cherry Logo
75 people viewed this question
Top Schecter Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Schecter Music Expert? Answer questions, earn points and help others
