Question about Maytag Neptune MDE5500AY Electric Dryer
Light are on but buttons dont work when you press them.
  • rdshuba Aug 21, 2010
    I tried unplugging the dryer and leaving it unplugged for over an hour, but buttons still dont work
  • Maytag Master
  • 43,501 Answers
There a very many things that can keep your dryer from starting...
Here is a tip that details many of the problems ...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Aug 22, 2010
Remote doesn't work properly
ON THE TOP OF TOUR REMOTE IS SITUATED A INFERAD LIGHT. USE A DIGITAL CAMERA OR A MOBILE CAMERA PHONE TO VIEW THE INFERAD LIGHT. ON THE REMOTE. INORDER TO SEE THE LIGHT WORK PRESS ANY BUTTON ON REMOTE AND YOU SHOULD SEE A LIGHT FLASH EAC H TIME THE BUTTON IS PRESSED. IF YOU DONT GET A LIGHT CLEARLY ITS NOT EVEN TRANSMITTING. ALTERNATE WAY BUY A UNIVERSAL REMOTE AND CODE IT.
Sep 15, 2013 | Bose Audio Players & Recorders
Tip
How to program an rca universal remote without codes
If you have a universal remote but dont have the codes or the codes dont work then what you can try is to scan all the frequencys using the remote to manually scan to work for your telly or other equipment your trying to control.
Follow these simple instructions
1. Turn on the device you want the control to control ie the tv or dvd or stereo etc
2. You need to now press and hold the button for the device you want to control and also the power button untill the light on the remote stays on( for this case we are going to program it to control a tv) so press and hold the tv button and power button hold them down untill the light stays on
3. press the play button once every 5 seconds( a bank of 10 codes is being sent every time you press the play button)
4. when it turns the tv off wait press the rewind/reverse button and check it turns the telly back on if it does then you need to hold the stop button untill the light goes off.
Once you have done this check the remote is working properly ie changing channels ets if it dont work properly then follow the instructions again and try again you may need to do this a few times till it gets the right signal
on Jan 18, 2010 | Televison & Video
Remote not working...
Remove the batteries. Press all the buttons to eliminate a stuck button as the problem. Reinstall the batteries or install new batteries. Check remote operation.
May 18, 2013 | Denon AVR-2807 Receiver
L dont have right 4-digit code for daewoo, the codes i have,dont work
Try these codes.
0130 0004 0009 0100 ................. 0005 0138 0043 0140 0039
....... 0252 0279 0444 0080 0042 0058
....... 0017 0010 0126 0018 0127 0019
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
    Code Search Method.
    1. Manually turn on the device (TV, VCR, etc.) to be controlled.
    2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
    3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
    4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
    5. Press and release MUTE to install the code. The indicator light goes off.
    Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Apr 17, 2012 | Televison & Video
At work we have a panasonic kx-t7668 telephone. I have followed the instructions on (one-touch dialing), but now when we have incoming calls in the office i dont have a red light that flashes at me, so i...
Did you do something stupid like program over the top of the buttons? Press PROGRAM and, starting from the bottom press a button, then dial 0 01 STORE Move up the line and press 0 02 STORE etc. Do that for however many lines you have and it puts the lines back into the Single-CO sequence that you probably started with. (PROGRAM is done from an idle phone and you press PROGRAM to exit).
Carl
Apr 01, 2011 | Panasonic Lands Phones
Waste ink absorber full
you can reset the ink counter but make sure u find way to replace the pad else it's going to be messy once the ink leak out...below is how you reset your waste ink...
1. Turn off printer.
2. Press the button Resume/Cancel(dont release) then press POWER button- if done, you will see the light change to green color.
3. Release the Resume/Cancel button, but dont release the POWER button.
4. Press Resume/Cancel button of 2 times, while still pressing the POWER button, after that, release both.
5. When the light change to GREEN - press the button Resume/Cancel 4 times.. then press POWER button once.
6. Turn off printer
7. Turn on and try print.
May 26, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
I can't get my directv Remote to work my sanyo tv must use tv remte now to turn on tv and addjust volume
try these steps.
1. turn on device 2. press setup (underneath on/off) till red light stays on the take finger off the button 3. press and quickly release device button (tv,vcr,etc.) the red indicator blinds off once 4. press the on/off button (up to 300 times) until the device is to be controlled turns off the red light blinks off with each button press 5. press and release enter to install code.
if your tv is not working the remote dont have your tv model stored, you need to find a compatible remote.
Feb 20, 2010 | GE JASRM24912 Remote Control
How do I get the codes for this. My TV is a sony
Hi, try this first if they dont work (code search)
SONY 002, 006, 013, 071, 128, 380
Code search
1. Turn on the device you wish to program.
2. Press and hold CODE SEARCH/SETUP until the INDICATOR
LIGHT lights, then release.
3. Press and release the device button for the device you are
programming (TV, VCR, DVD, etc.). The INDICATOR LIGHT will
blink once then remain lit. For AUX, press AUX then the device
button you are assigning to AUX.
4. Press and release POWER until your device turns off. Wait at least
2 seconds between each time you press POWER. Important: You
may have to press POWER up to 250 times.
5. When your device turns off press the ENTER/SAVE button. The
INDICATOR LIGHT will go off.
good luck dont for get to rate it
Dec 16, 2009 | GE JASRM24912 Remote Control
Programming my hitachi remote
there are several. try each one seperate.
1. press and hold setup button until the red light stays on.
2. press and release the desired mode button (example t. v.) the light will blink and then stay on.
3. enter one of the 4digit codes.
note: if the code is valid the light will turn off if it flashes it is an invalid code.
4. with the device on press the channel up and down. if the remote only controls some of the functions try another code.
CODES: 0545,0529,1754,0509,0465,0513,0518,0530,0531,0464,0511,0533,0526,0463
If none of the the codes work try following these steps:
1.manually turn on the t.v.
2.press and hold the setup button.
3. press and release the tv button the light will blink once and then stay on.
4.press the channel button repeatedly up to 300 times until the device changes channels. the light will blink and then stay lit.
5. press and release the mute button to store the code the light will go off.
Aug 28, 2009 | Televison & Video
Maytag Neptune MDE5500AY Electric Dryer Logo
26 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
