Question about Candy F248P Electric Single Oven
I have a Candy double oven, bought about 18 months ago from Homebase. Recently, the bottom oven (which is a fan oven, and the larger of the two) has stopped heating up. The fan starts and it lights up, but there is just no heat. Candy will charge something extortionate to come out and look at it as it is out of guarantee now (£130 I think). Does anyone have any ideas what it could be? I apologise but I am unsure of the model number, and I was just looking for the manual but failed to locate it.
    Genius:
  • 1,622 Answers
There are 2 different types of element which are commonly on electric ovens. these are plug-in or direct wired element.Repacing plug in element will be much easier and these can also be removed for easier inspection. the element can be pulled out and the connections can be inspected, if there is any damage to the connection , then the entire element will need replacing.
When removing a direct wired element you should first pull the element up and the use a screwdriver to open the wire porcelain connector which is located towards the back of the element, but if otherwise. call for a skilled personnel to handle it. Thanks and take care....
Posted on Aug 21, 2010
Beko double oven the fan has started to make a loud noise and sometimes cuts out had oven 18 months
by loud noise do you mean squeeling squaking .
then its the fan bearing just order another fan motor.
Jul 25, 2014 | Ovens
Candy Built in double fan oven bottom oven not getting hot
Cheak the coils. Do a continuity test also look for signs of an electrical short(small scorched area) and clean the contact where the coil attaches to the appliance.
Apr 17, 2014 | Candy Ovens
Oven will not heat on either oven
Candy Oven not heating? How to replace a Candy fan oven element
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
You searched for candy element How to Repair Home Appliances
Dec 16, 2013 | GE JTP45 Electric Double Oven
Has anyone had a problem with the inner glass on the Lamona oven door exploding. Mine just has! It's only 18 months old and hardly used. I wonder if it's the difference in temperature betweeen the hot oven...
We bought our kitchen from Howden's as well about 15 months ago. They installed a Lamona double oven and hob. Last night when opening the door to the bottom oven our glass on the inner door exploded as well. Maybe there was a batch of defective ovens as ours sounds as though they mat have been bought/manufactured at the same time.
Mar 07, 2011 | Ovens
I have a thermadore double oven c302or 272; both are convection recently the upper oven stall after setting and then shows F34 on the controll panel. What does this indicate, and is there an easy fix?
We had this problem a long time ago.. At the very bottom of the lower oven there is a slot.. Maybe 1" tall.. Look in there with a flash light. You will see 2 sail switches.. More then likey one of them is stuck.. The other problem could be the fan motor not running which would cause the same error.. "Fan air flow" But if you are getting flow it is probably the switch,.
Nov 23, 2010 | Thermador C302U Electric Double Oven
I recently bought a new house with fitted kitchen containing a fitted Diplomat double oven. When the power is on but both ovens off the Amber light above the top oven mode selector glows dimly. When I...
I'm not sure its been connected properly, needs checking out by someone who know's what they're doing. Be careful, the fuse doesn't trip for nothing.
Jul 09, 2010 | Ovens
Candy double oven purchased 14 months ago. Bottom oven cut out during cooking. Fan and light works no temerature though
It's most likely to be the oven heating element that is 'gone'. You will need to have it replaced.
Jan 08, 2010 | Ovens
Bosch convection double oven,ovens won't heat,only broilers work
If it is fan assisted then check the fan element, it is located behind a panel at the rear of the oven compartment.
Plz rate my\solution.
Thanks.
Dec 17, 2008 | Bosch Ovens
No manual
The light bulb is the oven light.
The snowflake with 3 raindrops is Defrost Mode (fan runs with no heat to reduce defrost time)
The 2 lines up top & down bottom is Traditional Cooking (heat from top & bottom elements)
The big circle with a fan is the Fan forced Oven
The small line at top only is the Grill Mode
The larger line at top only is the Double Grill Mode
The line up top with the fan underneath is Double Grill with Fan mode
The line on the bottom with fan on top uses the lower element with the fan for delicate dishes
The manual can be found on the Baumatic website - www.baumatic.com.au - select your product which takes you into another page & you will see on the left hand side a link to "View User Manual"
Nov 11, 2008 | Baumatic B187 Stainless Steel Electric...
Heating
i would first check the lower units bake element , usually a visually inspection is enough to determine if its good or nor, usually a burn mark can be seen on the element itself, and if you can even see the element the bottom f the oven cavity will lift off for better inspection
Mar 25, 2008 | Maytag CWE5800A Electric Double Oven
Candy F248P Electric Single Oven Logo
319 people viewed this question
Top Candy Ovens Experts
ashburton
ray gallant
Gaark
Are you a Candy Oven Expert? Answer questions, earn points and help others
