Question about KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher
I have a kitchen aid dishwasher. The upper spray arm is getting water and getting enough water pressure but wont seem to spin. Ive ran a lot of tests but nothing. ive cleaned out the spray arm and port that gets water to the spray arm. Cant seem to fix it. Any ideas?
  • Dvwiemann Aug 24, 2010
    still aint workin.... peice of ****
  • KitchenAid Master
  • 43,501 Answers
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
http://www.fixya.com/support/r4817172-dishwasher_spray_arms_not_spinning
heatman101
Posted on Aug 22, 2010
The spray arms aren't spinning, any ideas?
The main water pump sounds to be defective, not supplying enough water pressure to turn the spraybars.
Nov 05, 2015 | LG Dishwashers
Upper spray arm on my Kitchen Aid dishwasher (8573025) doesn't work.
Arm operates(turns) by water pressure. If it does not turn no water is going to the top spray arm. make sure the setting washer is on does not preclude the top spray arm from operating(read manual). If not check arm by spinning by hand to make sure it is free. If arm is free and it still does not turn when DW is running than there is a restriction in the tubing to the upper spray arm or the check ball or solenoid are not operating correctly.
Mar 01, 2012 | Dishwashers
The middle and top spray bar does not seem to
Is there enough water getting into machine. I it fills until the float shuts off water valve the the pump or motor may be bad.
Jul 10, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Top rack of Kitchen Aid not clean
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Also, There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
**Water temperature Note***
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
Sep 01, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Very low pressure getting to spray arms
I removed the lower spray arm, and then the filter. I found that there was a lot of buildup under the filter area. I scraped the buildup off. I found that it was restricting the input of water flow to the pump
Aug 01, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
No water to upper arm.
check to see if you are getting enough water.should be about 1/2 under the heater.if you are getting enough then check the chopper this is under the lower spray arm.could be broken.
Dec 09, 2008 | Dishwashers
Top arm not spinning
only the top rack isnt getting clean?
there is a little plastic circle in the middle of the bottom of the upper spray arm. turn it counter clock wise to pull the upper spray arm from the upper rack. make sure that isnt clogged and the spray holes are not clogged. otherwise....
the piece that the bottem spray arm plugs into and runs along the back wall of the tank to the top is called a feed tube. pull the bottom spray arm out. now you can see the part of the feed tube that feeds the upper spray arm water. does it pop out freely and easily? if so then you need a new feed tube, if not then its most likely your not achieving the right water level or your impeller connected to your circulation pump(motor) is clogged not supplying enough water pressure to travel up the feed tube to spin the upper spray arm.
Jul 13, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Rinse arms not spinning
Could be a a couple different issues.. Not filling with enough water or food chopper brokeen or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
Inspect food chopper:
Remove lower spray arm and rear water supply tube to upper spray arm. Remove torx screws that secure the sump cover. Remove the rounded cover on the left side to expose the chopper assembly. Inspect for breakage of blockage. There may be an additional plastic screen to remove first.
Jun 10, 2008 | Dishwashers
KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher Logo
299 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
