Question about Mitsubishi WS-65809 65" Rear Projection Television
The Light turns on and then 2-3 seconds later turns off. Any solutions to fix it?
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
DO SELF CHECK IT HAS: WHEN SHUTS OFF PRESS AND HOLD BOTH THE MENU AND INPUT BUTTONS ON THE FRONT OF THE SET FOR AT LEAST 5 SECONDS AND RELEASE BOTH BUTTONS.
POWER LIGHT WILL BLINK TWO DIGIT ERROR CODE LIKE: 2 blinks, 2 blinks, a pause and repeat 4 more times.
let me know error code found and I will tell you what it means.
SD TECH
Posted on Aug 21, 2010
Entrance light on Lift Master garage door opener won't stay on when door is opened ?
Light Feature
Activate the Light Feature
  1. Close the garage door.
  2. Start with the garage door opener lights "ON".
  3. Press and hold the light button for 10 seconds. (Upon pressing the light button, the lights will immediately turn off and come on 10 seconds later.)
Deactivate the Light Feature
  2. Start with the garage door opener lights "OFF".
  3. Press and hold the light button for 10 seconds. (Upon pressing the light button, the lights will immediately turn on and go off 10 seconds later.)
Light Timer
Press the Light button to turn the opener light on or off. It will not control the opener lights when the door is in motion. If you turn it on and then activate the opener, the light will remain on for 4-1/2 minutes. Press again to turn it off sooner. The 4-1/2 minute interval can be changed to 1-1/2, 2-1/2, or 3-1/2 minutes as follows:
  1. Press and hold the Lock button until the light blinks (about 10 seconds).
  2. A single blink indicates that the timer is reset to 1-1/2 minutes.
  3. Repeat the procedure and the light will blink twice, resetting the timer to 2-1/2 minutes.
  4. Repeat again for a 3-1/2 minute interval, etc., up to a maximum of four blinks and 4-1/2 minutes.
Oct 20, 2017 | Building Materials
Maintenance light coming on, then the oil light.
The maintenance light is telling you that the cpu has found faults in sensors and is shutting down the engine to prevent engine failure. Have the codes read and replace that which is faulty with genuine units.
Mar 21, 2013 | 2003 Dodge Caravan
Lenovo IdeaCenter K300...turn power on, light comes on, turns off, and 2 seconds later comes on. Fans are running but nothing on screen
just unscrew the tower remove the RAM - erase the golden color edge with a pencil eraser and then place it back. make sure the RAM edge looks golden glittering new, wired solution but worked for many trust me
Jan 27, 2013 | Lenovo IdeaCentre K300 53162CU Intel...
Hdmi cable was put in my ps3 by my friend ihavent got one now my ps3 does not work without a hdmi cable how can fix it
Please try the following solution :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it and then about 5 seconds later it will beep again. Let go of the power button when you hear this second beep.
Step 3. Wait for your PS3 to start.
This solution basically resets the video output back to standard definition. If this does not owrk then it is probably down to a faulty Graphics Processing Unit on the motherboard which is unfortunately terminal.
Hope this helps and thank you for using FixYa
Sep 05, 2010 | Sony Playstation 3 (PS3) Console
When TV is turned on the green light comes on but the TV does not. 2 seconds later the green light turns back off.
DO THE SELF CHECK THIS SET HAS AND LET ME KNOW WHAT YOU FIND:
When you turn on and green light comes on and then goes off:
On the front of the set press and hold both the Menu and Input buttons at the same time for longer than 5 seconds and release both buttons.
Power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know and if this told you something you did not know rate this solution as very helpful as I do this here for free.
SD TECH
Aug 31, 2010 | Mitsubishi WS-65311 65" Rear Projection...
Thers no picture or sound with my playstation 3 im using hdmi also tried 3prong cable
Please carry out the following steps to fix your PS3 :
Aug 25, 2010 | Sony Playstation 3 (PS3) Console
Ps3 turns on then 5 seconds later the green light
well i can tell u this. If your having any problems then 1.turn on your ps3
2.hold down the ps3 button until it beeps and turns red 3.then hold it again it should beep twice 4.then a screen will pop up with options 5.choose the one that your having problems with 6.it shouldnt turn off but if it does call the geek squad or get one of those ps3 fixing books.
i have a problem of my own 2 of my games froze while loding and one just froze while loding the first level of the game can u help me?
Oct 03, 2009 | Sony Video Game Consoles & Games
Tv comes on just the sound about three seconds later tv shuts off
I have the same issue with mine and have a solution that sometimes works. I had a repair guy come to check it out and he powered off the TV so that the red light was no longer blinking, then he unplugged the TV for about 30 seconds or so and then plugged it back in. He then turned on the TV and it worked. He said it would cost about $400 to fix the issue (some circuit or something). I have since expeerienced the on/off problem (due to power outage) and now I cannot get the TV to work. But at least give this solution a try and please post to let me know if it worked or not. Good luck!
Dec 23, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Mitsubishi television light turned on then two seconds later turns off
Looks like the infamous protection circuit error. Can you give me more details please? Does the LED stay on after the set turns itself off?
Aug 31, 2008 | Mitsubishi WT-42413 42" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
51 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
