Question about Cameras
I think I tore my film in the process of rewinding the film of my Nikon FM2 to remove it and I can't get it to open or anything and I don't have a clue what to do
    Guru:
  • 1,705 Answers
It would be best to go to a photo processing lab, they should have and dark room or light proof bag where they can open your camera.
Once open they should be able to container your film safely, they're used to these kind of issues.
If you try to open it in ordinary, even subdued light you will loose the photo's on the film.
However, here's a link to a user manual:-
http://www.cameramanuals.org/nikon_pdf/nikon_fm2.pdf
Posted on Aug 21, 2010
How do i remove film from nikon lite zoom ed 130
First rewind film in canster then when you hear the click you are finished rewinding the pull up on left winder knob this will open the door keep holing up and let fil drop out walla you're done.
Oct 01, 2013 | Nikon Lite Touch Zoom 130ed 35mm Film...
Where can i buy fm2 cameras in the philippines? thank you.
Welcome to Fixya.
This is where you can purchase a Nikon FM2 camera in the Philippines :
Nikon FM2 purchase
Thank you for using Fixya.
Jun 05, 2011 | Nikon F3 35mm Film Camera
This is kind of embarassing... i received an old nikon f65, and i don't know how to remove the film properly without burning it...
The film should rewind automatically at the end of the roll. If it doesn't, press the two film-rewind buttons simultaneously for about one second. The film rewind buttons are maked with a red film icon; one is also the exposure compensation button to the right of the LCD control panel, the other is the auto exposure bracketing button to the left of the viewfinder.
Once the film is rewound, turn the power off. Slide the release lever on the left end of the body, and the back should pop open a little.
You can download the manual from
http://butkus.org/chinon/nikon/nikon_n65/nikon_n65.htm
Aug 23, 2010 | Nikon F65 35mm SLR Camera
What does the blinking E in the Nikon n65 mean?
It means "Film remains in the camera after film rewind complete."
If this is happening after shooting, the remedy is simple: open the camera and remove the film. If this is happening right after loading the film, then you've got a more serious problem: the camera is rewinding the film upon loading.
Mar 03, 2010 | Nikon Photography
I have a nikon fm2 and everything seems to work fine but when i get the film developed, my film comes back blank?
In that case you probably have a shutter fault. (Blank film is unexposed film, but if it's black film then report back as the causes will be different). The other possible causes would be that the film has either failed to engage on the take up spool or that the film has engaged but is not being wound on by the take-up spool, this could happen if the rewind lock button has got stuck (but then the rewind crank would not turn when you advance the film and the rewind action would be *very* brief). Another cause is that the mirror fails to flip up during exposure, but then your camera would sound very different and you'd notice that the viewfinder doesn't black out during exposure. As you didn't mention any of these obvious signs, I'll continue with the shutter.
Rewind any film and open the camera back. Remove the lens. Use the film advance lever to set the shutter. Hold the camera up to the light and press the shutter release button. If you don't see any light then it's a faulty shutter. You may wish to repeat the test at all shutter speeds including the B setting. If the shutter proves to be fine, then try again with the lens attached (remember to remove the lens cap, and set the aperture to it's widest setting). If the fault only occurs with the lens attached then it's a lens fault if it only happens with that one lens, and a different fault within the body if it's with all lenses.
If everything proves negative and you find no fault, then check with the last lab you used to see if they have an equipment fault. If the film is totally blank with not even any frame numbers, brand name nor bar codes present then it's been chemically bleached out
The FM2 has an entirely mechanical shutter which is usually highly reliable, and it's a model which I've very rarely encountered any serious faults on. Every fault I've had to deal on them with has been caused by abuse, lack of servicing, or simply where an example has clearly been so heavily used that it has worn out. As the batteries are used for metering only, the battery box and light meter can be ruled out as possible causes leaving you with a purely mechanical fault.
This is good as it means your FM2 is very likely to be repairable, but it's not a DIY repair. If your example has had a very long and hard life and is looking very battered, then let it finally rest in pieces(!), but otherwise I suggest that you book your camera in for a CLA service (Clean, Lubricate, Adjust).
Your FM2 will be anywhere between nine and twenty eight years old, so if you're lucky the fault is just due to dried out gummed up lubricants. If you're unlucky then many parts are still available new from Nikon and there are millions of them in circulation so used parts are widely available. Any experienced camera repair technician will be very familiar with the FM2. I'd strongly suggest that you take the chance to get the foam light seals and mirror buffer replaced at the same time as if they haven't already turned into a corrosive black goo then they soon will; it's a one-off job and modern materials will last the lifetime of the camera.
You need to be aware that you're looking at spending a minimum of £80-£90 for repairs (more if parts must be replaced) and this exceeds the price of a used FM2. But even if you buy a used example, it's still going to need the CLA and seals unless there is reliable proof that it has been done recently by a professional technician. For what you may need to invest there is simply nothing else which comes anywhere close to the build quality of an FM2 and once serviced it should be good for many more years of use (although I'd recommend a CLA every few years).
A fully serviced FM2 in good condition is one of the few 35mm SLR's which is still in great demand, and so will be worth around £180 if sold privately. At that price, most repairs will be economically viable.
If you're in the UK then I can highly recommend A J Johnston for Nikon repairs, current turnaround time for most FM2 issues is about ten days.
I hope that my reply has been of assistance, if so then please take a moment to rate my answer.
Feb 25, 2010 | Nikon FM2N 35mm SLR Camera
I was taking some photos (I had got around taking 4 exposures) and all of a sudden (and this is the first time its ever happened) I was not able to take anymore pictures. It sounds like the Shutter Release...
it seems to think you reached the end of the film. Try rewinding. Once in a great while film does not want to exit the canister for whatever reason. It stops. that creates tension, film advance motor stresses out and signals the computer program which tells you that it thinks you're outa film. REWIND!!!
I doubt you did anything wrong. Try rewinding the film. Another possible fix if its electronic issues is to remove power(battery) and reinstall battery.
lightspiritphotography.com
Oct 02, 2009 | Nikon N8008 AF 35mm SLR Camera
My Nikon N2020 will not open to insert film
life up on manual film rewinder to release the the back to load film
Jul 29, 2009 | Nikon N2020 35mm SLR Camera
Nikon fa how do i start ? how do i get the film out i need the basics
On all of that series of Nikon SLRs, there is a small black plastic tab under the rewind handle on the left side of the camera. (as looking from the back). The tab needs to be pushed lightly and that will release the rewind shaft so you can pull up on the rewind knob to open the film door.
more info can be found here on Fixya
The FE2/FM2 are very similar in operations and function
May 29, 2008 | Nikon Cameras
Film rewind
For some reason the camera thinks it is at the end of the roll. You could turn off auto rewind, Custom Menu #1, to 0. This issue could manifest itself in cold weather as well, film becomes too stiff causing drag tripping the auto rewind. Call Nikon Film 1-800-645-6687. The camera may need to go in for CLA.
Feb 06, 2008 | Nikon F100 with 28-80 and 70-300 lens 35mm...
Nikon one touch zoom 90 camera
I bought this camera at Value Village for $1.99. It came up with an E. I assumed this was an E for empty. I loaded a film and it is fine. frankvos@sasktel.net
Oct 07, 2007 | Nikon One Touch Zoom 90S 35mm Point and...
Cameras Logo
70 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
