Question about GE Dehumidifiers
I have a GE 40 pint dehumidifier. It is supposed to train either into the bucket or to a hose. I have the hose attached, but it will not run unless the bucket is in place and the hose does not work> only the bucket fills. How can I fix it so that the hose works and the bucket does not fill? Pleaase reply to mbrodkey@netscape.net. Thank you.
  • 3,083 Answers
Others have had this problem, and are annoyed by it. One fellow in an Amazon Review fixed it, and here is what he said:
This dehumidifier came with the house I bought 6 months ago. It sucks the water out of the air very well. I had to empty the bucket once a day. I finally figured out how to attach a hose (you have to punch through a rubber barrier with the adapter) and haven't had any problems. The unit is very noisy and I can hear it humming from the 2nd floor. When I move it around a few inches, the noise reduces, but it gets loud again after a while. I might wrap the non-functioning sides with foam to help with the noise.
Not sure what rubber barrier he's referring to, but maybe it will make sense to you- hope so.
Good luck, and hope this helps.
Posted on Aug 22, 2010
I HAVE A ge 40 pint dehumidifier it wont run because it says the container is full and there is nothing in it
i did have one of a simmiliar model do just this same thing it turns out i hit the sensor float inside removable bucket part and knocked it out of its little hole it fits in , hence the it no longer connects with other part of overfill sensor thats buryed inside machine, so it allways says its full , i put the little float back in it's hole and now it works ok
Oct 20, 2014 | GE Dehumidifier With 40 Pint Capacity
I have an Energy Star 54701. Turned on, 35 % humidity set, hose connected and ready to drain in sump hole, bucket connected. set for 6 hours. No water is draining from hose or into bucket????
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 02, 2011 | Soleus 30-Pint Dehumidifier
What setting do you have to have it on for the water to come out of hose only
The water collection bucket may have a hose tap in it. But, in your case the hose drain connection is on the side of the unit. You have to remove the cover of the hose connection, before you can connect the garden hose. Here's where it gets a little tricky, because the Owners Manual says to leave the bucket in place. However, the Troubleshooting Guide says to remove the bucket, if water is not draining thru the hose. Which to me, makes sense, because the unit can't recognize that the hose is connected, if the bucket is still installed, because it has a safety switch.
In case you have misplaced your Owners Manual, here is a link to it, that you can download and print for future reference.
http://www.natlallergy.com/uploads/pdfs/Soleus-Air-30-40-Pint.pdf
Hope this helps you solve the problem.
Mar 23, 2011 | Soleus 30-Pint Dehumidifier
50 pint dehumidifier has drain hose connected but fills up the drain bucket and stops running....
safety switch is turning off the dehumidifier....you need to drain out the bucket more often....or put the drain hose into an actual drain....ive seen some people run a small plastic hose from the dehumidifier to the sump pump hole in their basement.
Jan 27, 2010 | Frigidaire Dehumidifiers
Haier 30 pint dehumidifier continuous drain problem.
Many just attach the hose at the reservoir; from your description, Haier apparently has a separate location. Check that the point that the hose attaches has an opening (many don't, they expect you to drill it). It should then drain through gravity. Check to make sure that no part of the drain hose is higher than the bottom of the reservoir, otherwise it can't drain. It won't siphon because each time the the tank empties, the suction is broken and the siphoning can't continue.
Aug 24, 2008 | Haier Dehumidifiers
Dehumidifiers Logo
262 people viewed this question
Top GE Dehumidifiers Experts
J.D. Browning
J.D. Browning
AZBen
AZBen
Are you a GE Dehumidifier Expert? Answer questions, earn points and help others
