Question about Philips Televison & Video
There is too much red, even after I've restored the dealer settings. The color is very red.
  • Philips Master
  • 8,617 Answers
Sounds like the CRT coolant needs replacement in the Blue and green CRts which will make the red CRT dominate.
Posted on Aug 21, 2010
Why is my Sony 3lcd projector not showing the color red?
I hope its on warranty because that sounds like a circuit board problem. Was the replaced lamp the original specification?
-GWOOD
Jul 14, 2014 | Office Equipment & Supplies
Beamerproblem! I've got a red-color problem with
Take it to GameStop. They can find the problem lickety-split!
May 17, 2013 | Office Equipment & Supplies
The colors of my laptop's sreen are inverted. I've tried everything I could think of (display settings, system restore,....), how do I fix this?
Click start control panel administration tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers You might need to upgrade your graphics card drivers. You might have to remove your graphics card to make sure the socket is clean restart your computer the reinstall it this should activate found new hardware wizard if your computer came with a mother board disk the drivers could be on it Click start control panel display desktop you can select a different desktop from the drop down list or a browse button where you can select different pictures this may vary depending on your operating system also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal , larger or custom settings
Always click APPLY after making any changes windows 7 Open Personalization by clicking the Start button, clicking Control Panel, clicking Appearance and Personalization, and then clicking Personalization. Click Window Color and Appearance. Under Window Color and Appearance, click the color you want, and then click OK. Note If you see the Appearance Settings dialog box instead of the Window Color and Appearance window, the theme might not be set to Windows Vista, the color scheme might not be set to Windows Aero, or the computer might not meet the minimum hardware requirements for running Windows Aero. For more information, see Troubleshoot problems with Windows Aero.
Feb 28, 2013 | Dell Latitude D820 Notebook
I cannot get the tension to set correctly on my Singer 6268 sewing machine. For instance, I'm using red thread on top spool and white in the bobbin. Suddenly, as it always does, the thread is loos
I have solved my tension problems by going to threadmagazine.com. they have solutions to many, many problems you have with your sewing machine. Hope this helps. jdokos95
Aug 01, 2012 | Sewing Machines
Eiki LC-XC1 color problems
check all the optical parts around the blue lcd-panel, they might be darkened due to heat
May 07, 2012 | Eiki Office Equipment & Supplies
I have a Sony viao model VGN-NR18OE, and it keeps restarting before I can even log on, which means something is deeply wrong with it. I want to restore it to factory settings but I've pressed f1, f8,...
I believe in order to start the procedure, you need to press ALT + F10 while it's starting up. For most Sony Vaio's I've worked on, that was the key combination.
I hope this helps!
Sep 09, 2011 | Computers & Internet
I have a 2002 jeep grand cherokee limated,the blower motor resistor wireing shorted out at the plug connection the control circuit to the resistor,I need to know the color code for the j1,j2,j3 termals on...
I've seen a few of these and the easiest fix is to replace both the blower motor speed controller/resistor and the wiring harness connector. I've tried fixing the connector but the repairs don't last because of the heat generated at the connector if everything isn't just right. You can purchase the connector, which comes with color coded pigtail wires attached, from the dealer and it's a fairly easy and permanent fix. Hope this helps and good luck!
Aug 10, 2011 | 2002 Jeep Grand Cherokee
All of the red colors have changed on my 37-inch LCD screen. I have tried all of the color settings in various modes and the color is still bad. I have reset the defaults and the reds and greens are bad.
Contact your LG dealer to arrange a service engineer to call out & update the software. This can re-set the internal colour settings held within the chip memory, if this fails then it the component or board would need replaced.
Jan 04, 2010 | LG Televison & Video
Red is printing pink.
A manual and troubleshooting guide for your printer can be found here.
May 05, 2008 | HP Color LaserJet 2600n Printer
Televison & Video Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
