Question about EuroTech EDV158 Electric Dryer
The dryer had been continuing to spin unless it was off. Earlier today it just quit mid load. Now it will not turn on!
  • EuroTech Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ...
www.dslreports.com > ... > Home Improvement
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Dec 02, 2015 | Maytag Washing Machines
I own a Samsung dryer model DV218AEB/XAA. In both the sensor and timed cycles it shuts off early and goes dead for about 30 minutes before it comes back to life and the load can be restarted, only to
I have a good idea that it may be the following;
Drum Roller Axle
This dryer has drum support rollers. There will always be two supporting the rear of the drum, and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If the roller axles are worn out the rollers may not spin freely which can overload the motor and the dryer stops. If the dryer stops mid-cycle, remove the belt and spin the drum, it should spin freely. If not, check the rollers and roller shafts.
You can check out other possibilities and order parts here using the following link;
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/2---/Dryer-stops-turning-during-cycle
Good Luck!
Rich Lilja
Oct 29, 2014 | Samsung DV218AEB/XAA 7.3-CuFt Electric...
Aeq6000 won't turn off
This has to do with the control board failure. The control board runs every aspect of the dryer and will need to be replaced. Here is the new control board.
Oct 20, 2012 | Frigidaire AEQ6000ES Electric Dryer
Whirlpool electric dryer leq7030kq1 wont turn without help
Sounds like you have a dead zone in your motor...could be a replacement motor is called for. or continue to spin the drum by hand till the motor goes kaput...its cheaper
Sep 26, 2009 | Whirlpool LEQ9858P Electric Dryer
Washer quit mid cycle
open lid pull tub to you till you hear a click(when you have an off balance load the tub will trip the switch)
Aug 22, 2009 | Maytag Dependable Care LAT9706
Stops mid cycle, won't spin
You need to check and see if the door-lock light is on ,if not then you have either a faulty door lock mech. or a defective solid state board in the control panel
Dec 27, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
thermostat would not cause it not to run if the white thermal fuse has continuity ck the door switch to be sure lever is not broke also ck breaker after switch timer most logical but unless you know to ck best not just guess could be expensive
Dec 07, 2008 | Whirlpool LER4634J Electric Dryer
EuroTech EDV158 Electric Dryer Logo
79 people viewed this question
Top EuroTech Dryers Experts
Tim Whalen
Colin Stickland
Colin Stickland
Are you an EuroTech Dryer Expert? Answer questions, earn points and help others
