Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA D52W14 I HAVE PROJECTION TV FROM RCA AND WE HAVE HAD IT FOR 2 YEARS NOW ...AND 2WEEKS AGO THE CABLE COMPANY DID THERE NEW UPDATES AND MY TV WON'T TURN ON THE LIGHT COMES ON AND IT TRIED TO TURN ON AFTER ABOUT THREE TRIES THE GREEN BUTTIN JUST SHUTS OFF I KEEP TRYING TO TURN IT ON AND OFF SAME THING JUST HAPPENS THE GREEN BUTTON BLINKS TO PICTURE ..PLEASE HELP
  • 1 more comment
  • Anonymous Jul 14, 2008
    my tv was doing the same thing .I have had my 2 years to my tv just burned up i came home on friday and push the tv to turn on and it burned up the borad in back of tv it ****
  • Roger Williams
    Roger Williams Oct 29, 2008
    my television wont power up, but attempts to come on 3 times everytime I try to cut it on.
  • TISADIXON Nov 18, 2008
    I AM HAVING THE SAME PROB. I HAVE HAD THE TELEVISION FOR 3 YEARS AND IT IS DOING THE SAME THING GREEN LIGHT COMES ON FOR ABOUT 30 SEC AND THE TV SHUTS DOWN.
So how do you fix it???
Posted on Jul 06, 2008
  • RCA Master
  • 8,617 Answers
That model is famous for bad flybacks that shut the set down and there is no warning they just quit working. If you need further info please let me know.
Posted on May 03, 2008
RCA D52W14 Cable connector on the ITC 222 and ITC 222A signal
a good experienced tech might be able to do it for you .  other than that you will have to replace the SSB
Jul 28, 2010 | RCA D52W19 52" Rear Projection Television
TV will not turn on
Replace the CP150 CP120 and CP114 capacitors. You can get the repair kit for your RCA at the following link www.tvrepairworld.com The kit contains the capacitors and CD with detailed instructions
Sep 05, 2009 | RCA D52W19 52" Rear Projection Television
RCA Proj TV (model D52W14) Power light flashes 3 times
Replace CP150, CP120 and CP114. You can get the repair kit for your RCA at the following link. www.tvrepairworld.com the kit contains the capacitors and the CD with detailed instructions.
Sep 05, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca tv my guide plus has quit working
The guide plus needs to reset itself over night. But as long as you are only connected to cable it will not allow for it to reset. You need a two way splitter the cable company signal will go in one side and the outside antenna or what ever you were connected to before cable will go on the other connector. The single side connector will go to the tv. Where the splitter says 'in' you will actually be using it as out to the tv. Where the splitter says 'out' you will be using as in for the cable and the other antenna. Guide Plus is built into your tv and needs the tv to be off to reset over night.
Jan 28, 2009 | RCA P61960 61" Rear Projection Television
Replacing the flyback
If your model is a HD52W59 the wires are part of the new transformer and have to be changed at the tripler and screen control block
Jan 21, 2009 | RCA HD52W59 HDTV Projection Television
D52W14 power button blinks 3 times
Yes make sure you get correct flyback,call UED 1-800-648-6657 see if they have part; also are you sure that is what is wrong?Check capacitor cp150 2200uf 16 v see if it is ok or if it is bad this cap if bad will keep set from coming on,and if it is bad there is 2 other capacitors that need to be replaced also.
Dec 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA tv model D52W14
That is an ITC222 chassis and likely the HOT has shorted, 2sc5588 Rca Part # 259899
You might also check Cp150 2200uf/16v in the 6 volt line, a common failure. Always replace Cp120 330uf/35v & Cp150 2200uf/16v and always resolder Cl031 & Cl032...
There is also a tech bulletin Tv-06003 Dated 12/8/2006 which states:
Replace deformed ribbon cable plastic connector BP005 on the flyback board. This connector is warping or bowing (May Not Even Look Like It) and causing poor connections to the ribbon cable. Replace Rca P/N # 258686.
Try putting pressure on the BP005 connector and turn the set on, you may find the set will now work fine. Replace connector and you may wish to replace the ribbon as well while you are doing the repair!
This set is notorious for failures like this and it is not uncommon to find multiple problems.
Hope this helps!
Bill
Aug 08, 2008 | Televison & Video
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
210 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
