Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Everything has been checked out. and is working. now is time to see if it is the router. I can get on line only if I conect with cable. no wireless. It was working.
    Scholar:
  • 86 Answers
Hi fine so i do understand u are able to go online wired but not wireless....just try these steps
Step 1: Connect modem>>router>>computer
Step 2: Open the browser page and type http://192.168.2.1
Step 3: Towards the left coloumn click on channel and ssid below wireless
Step 4: Change the channel to 11
Step 5: Assign ur own ssid name-any name as u prefer
Step 6: Checked broadcast ssid is enabled or checked
Step 7: Then apply changes
Step 8: Then click on the security below channel and ssid
Step 9: Select the security type as 64 bit wep
Step 10: Type any 10 numbers make note of those nos thats ur password
Step 11: THen disconnect the connection between router and laptop
Step 12: Tried scan and connect
Step 13: U wiil see the network created by u select that and connect
It will surely work out
Posted on Aug 24, 2010
I am trying to connect a wrt150n wireless linksys router to my dsl. I am using a desktop windows 7 and laptop windows vista. Please help, I have tried everything but it just does not want to work.
unplug everything, including ethernet cables. then work in this exact order.
if you get a wireless signal and no internet, plug a computer in into the router in one of the available ports and check for internet. If no internet, unplug everything and test the modem without the router. If internet available without the router, then follow these instructions
  1. plug phone line into modem
  2. plug power into modem
  3. wait for all lights to become steady
  4. plug ethernet cable into modem
  5. plug other end of same cable into port labled "internet"
  6. wait for lights to become constant on both router and modem
  7. check your wireless device for wireless service.
if you dont get a wireless signal at all, plug your device into the rear of the router and type 192.168.1.1 in the adress bar
the password and username are both "admin" or simply leave the password blank if that doesn't work
navigate to the wireless option and turn on the wireless transmiter.
GOOD LUCK AND PLS RATE THIS POST!!!!!!
Dec 01, 2010 | Linksys Wireless-N WRT150N Router
Robotek
it means that if using the dhcp option then he send the ip address to your pc or laptop but you give the static then this problen will not get it
Apr 17, 2009 | Gateway 802.11g Wireless DSL/Cable Router...
Dilnk 655 router conected i can connect through wireless on laptop but the desk top which is wired in from router is saying not conected to internet the network magic program says router is not conected...
try reconneccting the lan cable from your router to your main desktop, take it out for about 5 seconds then put it back in, a light should turn on around the port but check with the on screen details. this should fix it, if not you may need to set up a lan connection through thte network thing
Apr 14, 2009 | 2wire (1000-400108-001) Router
Wireless ir conected, but don't works
My name is ArmyMason, I have a suggestion for you. In Internet Explorer click on file and see if Work offline is checked. If it is unchecked it and try again. If this solution doesnt work might I suggest using our premium service or live chat.
Thanks,
ArmyMason
Feb 24, 2009 | Linksys (WIFIDESKTOP) Wireless Adapter
I have just bought a belkin ADSL2 wireless router, as I have cable broad band which come in on a lan line and not conect to a RJU phone line do I need to connect it to any phone line. would be grate ful if...
Hi and welcome to FixYa,
First congratulation on your new wireless router, not the worst by these days :-)
You unplug your internet connection, where your computer now connects to the internet.
Then, you use the short cable to connect between the modem and the router in the one named WAN.
Next to this, is four called LAN, - you connect your computer to one of these (which one don’t matter).
Then you use the CD that came with the router, and follow each step.
It is very important that you set up the Admin password, so that your neighbor can’t access your router and change the setup.
Then in "Wireless ->Wireless security" setup one of the keys.
Allso the SSID, your own network "name".
Write everything down, as you have to set up the same on your laptop later.
If you need additional info, do come back, I’m here to help you.
/Teis -> if this is enough, don’t forget to vote
Dec 07, 2008 | Computers & Internet
Can not get on line
1. Make sure the ethernet cable going from the modem is going into the port on the router labeled "internet." Next, make sure the ethernet cable that is plugged into your desktop is going into the port labeled either 1,2,3,or4.
2. If it is in port 1, or any other port, make sure you try all of the number ports.(1,2,3,4)
Apr 02, 2008 | Computers & Internet
Belkin Router
Log onto the router to see if the entire box is hanging or only the conection to the internet.
Check for a 'Auto Reconnect Setting" in the router.
If there is alot of Noise on your DSL lines it could disconnect without re-connecting.
Also check to make sure you have all your filters installe don the phone lines....
Feb 10, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
D-link 524 looses conection
check the timeout when idle settings on the router. you need to set it to 0 for never break the connection.
other options are to upgrade the firmware of the router.
you should also isolate the problem by connecting the pc directly to the modem to make sure the same problem doesnt occur. if it does then contact your isp.
good luck
smeags.
Dec 31, 2007 | D-Link AirPlus DI-524 Wireless Router
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
26 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
