Question about Toshiba Satellite A135-S2276 Notebook
Computer wont start up cause bootmgr is missing im on my brohers computer
  • 2,296 Answers
You can try to Repair your Windows using the Windows installation CD (for Repair choose R when prompted). You can let the automatic repair to try and fix it, if that doesn't work upon restart reboot and start the Repair again, but this time select Command Prompt or Console and put in "bootrec /rebuildbcd" without the quotes. If you don't have Windows installation CD you can try downloading Hiren's Boot CD and try to fix the bootmgr with the utilities from the disc: http://www.hirensbootcd.org/download/
Posted on Feb 11, 2011
Bootmgr missing
You need to have a operating system's disc because you would need to load the bootmgr from it. Insert the disc and start your computer. Your computer will ask you to boot to the cd. Hit enter and run a start up repair so that the missing system file will be added.
I hope this helps!
David
Jun 22, 2013 | Dell Vostro 1014 Notebook
Bootmgr is missing on another computer how to fix
http://pcsupport.about.com/od/findbyerrormessage/a/bootmgr-is-missing.htm
This has happened to me a few times. Just go to that link and it will solve your problem. :)
Apr 17, 2013 | Compaq Computers & Internet
My computer is saying BootMgr is missing !!!
Bootmgr is missing is an error from your system. The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose hard drive interface cables. you can fix it by the following steps:
Firstly, create a bootable CD/USB byWindows Boot GeniusSecondly, set the computer boot from CD/USB after enter into the BIOS menu.Thirdly, start Fix "Bootmgr is missing" with the CD/USB created at the first step.
Source:http://www.windowspasswordsrecovery.com/fix-windows/bootmgr-is-missing.html
Feb 19, 2013 | HP Computers & Internet
Bootmgr is missing toshiba satellite model number a136-s4727
If bootmgr is missing..your computer wont turn on....you have to now reinstall the operating system.
you can try with the inbuilt system recovery..or you can use a os cd to do that.
Aug 20, 2011 | Toshiba Satellite A135-S4727 Notebook
Bootmgr missing
Causes of BOOTMGR ErrorsThere are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.
The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
Another reason you might see BOOTMGR errors is if your PC is trying to boot from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from. Fixes for BOOTMGR Errors
  1. Restart the PC. The BOOTMGR error could be a fluke.
  2. Perform a startup repair of Windows. This type of installation should replace any missing or corrupt files, including BOOTMGR. Continue troubleshooting if this does not resolve the issue.
  3. Check your floppy and optical drives for media. Often times, the "BOOTMGR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk or CD/DVD.
    Note: If you find that this is the cause of your issue and it's happening regularly, you might want to consider changing the boot order in BIOS so the hard drive is listed as the first boot device.
  4. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including BOOTMGR errors.
    Note: There's usually an Auto setting in BIOS for hard disk and optical drive configurations which is usually a safe bet if you're not sure what to do.
  5. Reseat all internal data and power cables. BOOTMGR error messages could be caused by loose or malfunctioning power or controller cables.
    Try replacing the PATA or SATA cable if you suspect it might be faulty.
  6. Update your motherboard's BIOS. An outdated BIOS version can sometimes cause the "BOOTMGR is Missing" error.
  7. Perform a clean installation of Windows. This type of installation will completely remove Windows from your PC and install it again from scratch. While this will almost certainly resolve any BOOTMGR errors, it's a time consuming process due to the fact that all of your data must be backed up and then later restored.
    If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows.
  8. Replace the hard drive and then perform a new installation of Windows. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
BOOTMGR Errors Apply To BOOTMGR issues apply to Windows 7 and Windows Vista operating systems only. Windows XP does not utilize BOOTMGR. The equivalent function in Windows XP is NTLDR
Whish you the best luck.
Mar 06, 2011 | HP Computers & Internet
BOOTMGR is missing. Acer 4730Z
You need to Have Operating System (Windows disk). Boot your computer with the help of disk and run repair take the option of Start up repair. Run repair and it will fix your Bootmgr missing error and you will be able to log on to windows again.
Jun 01, 2010 | Acer Aspire 4730-4516 Notebook
Satellite M305-S4826 14.1" Laptop : my computer wont load . it says missing bootmgr pr...
May 18, 2010 | Toshiba Satellite M305-S4826 Laptop
Bootmgr missing on a hp pavilion 533w with windows xp
You need to run the installation CD and run"REPAIR" The bootmgr file is missing from the setup and doing the repair,the computer will take it from the CD again.
Mar 28, 2010 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
Toshiba Satellite A135-S2276 Notebook Logo
142 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
