Question about Brother LX3125 Sewing Machine
Motor stop working. the hand wheel works to sew but when i press the pedal the motor just spins but does not move the needle or anything else.
    Genius:
  • 1,788 Answers
Check your bobbin winder lever, make sure that it is fully disengaged.
Posted on Aug 21, 2010
Brother sewing maching
On the hand wheel there is the lock that is used to stop and start the needle from being used. This is necessary for refilling the bobbin with thread. If the hand wheel doesn't make the needle work then you will need to do some minor adjustment.
1. On the hand wheel find a small screw and loosen it until it is just about ready to remove.
2. Now tighten the hand wheel.
3. Tighten the small screw again.
It should be ready to use now.
Aug 31, 2016 | Brother Sewing Machines
The handwheel will turn manually but it will not move using the foot pedal. The sound it makes when I press on the foot pedal *sounds* like I am filling the bobbin.
foot pedal not moving needle - Home Forums - GardenWeb
ths.gardenweb.com > Home Forums > Sewing
Nov 8, 2013 - We have a Brother Limited Edition Project Runway Sewing MachineRefurbished LS2250PRW. I was trying to sew on a button and was turning the hand wheel to do ... front near the needle where you can run the machine with foot pedal ...just what I would experience when my Bernina was running, or not, ...
Sewing Machine Repair ' ThriftyFun
www.thriftyfun.com/tf/Home.../Machines/Sewing_Machines/index.html
The thread is being picked up from underneath, but will not form a stitch at all. ... Butwhen I push my pedal down my needle won't move, the motor runs, but nothing happens. ... I have a Bernina machine which is sewing OK with the normal foot. ....The hand wheel, the wheel at the end that manually turns to make the needle ...
Help me diagnose and fix a problem with my sewing machine - Sewing ...
artisanssquare.com > ... > Sewing Machines
Jan 11, 2016 | Bernina Sewing Machines
Juki DDL-227 won't spin
:) welcome to the world of industrial machines. The good news is they are typically simple machines.
It is a good habit to take a few minutes to clean and oil your machine before you start sewing. Look for the oil points and give it one drop of quality sewing machine oil in each port.
Now let's try to determine why the hand wheel isn't turning. Loosen and remove the belt from the large reducer wheel under the table to the sewing machine. Try to turn the hand wheel. If it does turn.... Good! If it doesn't turn... we know the problem is in the the machine head and not the wheels below.
Make sure there is no bobbin thread or upper thread. Try to turn the hand wheel again. Anything?
Look carefully at the machine... is the take up lever bent? (personally had this happen with friends helped me move a big machine like this.)
Keep working this way... inspecting the machine until you find the problem. Good luck
Sep 08, 2012 | Juki Sewing Machines
The needle is stuck,not moving.its very hard and the motor makes a sound but needle does not move.
Refer to your manual and make sure the bobbin winding feature is disengaged.
Turn off the power and remove the needle and if there is fabric, remove it also.
Open the needle plate look for thread tangles.
After cleaning, turn the hand-wheel by hand to see if it moves the needle up and down.
If it does, press on the foot pedal to see if it is working.
Any of the above could be the problem.
Mar 01, 2010 | Kenmore Sewing Machines
Consew CP206-R Stopped Sewing/Working
Hi there, please send me an email and I will send you the mechanics book for your machine.
Kindest Regards,
Richard.
sewingmachines@gmail.com
Oct 24, 2009 | Sewing Machines
Won't sew when foot pedal is pressed
foot pedals do fail and possibly your s has .
Oct 31, 2017 | Kenmore Sewing Machines
When i press the pedal, the needle wont move and i already oiled the machine
press the hand wheel in. On this machine you pull the hand wheel out to disengage the needle while threading the bobbin and press it back in to reengage the needle.
Jul 11, 2009 | Kenmore 15212 Mechanical Sewing Machine
Kenmore 10 stitch needle won't move
hi there,
push or pull hand wheel clutch to engage
motion of needle and shutter.
if not check belt on downside of hand
wheel open cover motor,loosen bolt cover
see belt check if engage on pulley by
holding hand wheel move belt if
hand wheel move,if not tighten screw on
pulley from hand wheel and moter.
have a nice day and thanks
Apr 03, 2009 | Sewing Machines
Brother LX3125 Sewing Machine Logo
182 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
