Hi
Ghosting or blurring vision happens due to a faulty video processing board. It may be due to faulty T-con board (BN81-01308A) or a main board ( BN94-01199B ). However, you'll need to check the wiring on both of these boards. Before this I'll suggest you to callibrate the TV by following these settings--
Contrast: 85
Brightness: 46
Color: 56
Tint: G50 / R50
Sharpness: 15
Backlight: 5
Black Adjust: low
Dynamic Contrast: low
Gamma: 1
If this doesn't resolve the issue then turn off and unplug the TV for 4-5 hours and check. Tell me if there are any horizontal or vertical lines.
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
I have the same problem on my TV. Happens when the TV has been off for more than a few hours, on all input channels. Displays the picture in four horizontal blurred sections. When on an input channel w/o a signal (AV1) - displays the input channel logo (AV1) 2-3 times on the screen on different positions. What seems to temporarily fix it is: unplug all input cables, unplug the TV from the power outlet for a few minutes to half an hour (haven't figured out what is the minimum/maximum period the TV has to be off) and plug the TV back into the power outlet.
Were you able to fix yours?
