Question about Health & Beauty
Instyler won't turn , relatively new. - Health & Beauty
Hand wheel won't move.Scissorbutton wont work.
Repairing a Janome or New Home Sewing Machine ...
www.thriftyfun.com/Repairing-a-Janome-or-New-Home-Sewing-Machin...
Question: Memory Craft Machine Won't Run ... I'm a computer repair technician and good with tools, is this something I could fix or should we .... machine which will zig zag fine if i turn the wheel by hand or sew very slowly; as soon as I speed ...
Janome won t turn Sewing Machines Questions & Answers ...
www.fixya.com > Forum > Tags > won t turn > Sewing Machines
Janome sewing machines won t turn related questions and answers. ... Ad. Question about Memorycraft 6500P Computerized Sewing Machine ... it could be a part has worn or broken, esecially when the hand wheel won't turn,, it needs to be.
Janome wheel not turning Sewing Machines Questions ...
www.fixya.com > Forum > Tags > wheel not turning > Sewing Machines
Janome sewing machines wheel not turning related questions and answers. ... 10000 janome jamming fly wheel won't turn fly wheel won't turn warning for too thick ...the hand wheel is not moving the needle at all Hi I was unable to move the needle at all ... Janome Memory Craft 9000 Computerized Sewing Machine.
Jan 25, 2016 | Janome Memorycraft 6500P Computerized...
I have a blower/vac made by McCulloch that won't start! I tore the carb apart & cleaned it! Got it started but w n rev up! Turned I&H screws all t w in & bk out now won't start! help!
McCulloch 2 cycle leaf blower vac - YouTube
? 3:40
https://www.youtube.com/watch?v=skwugvObHtU
Dec 1, 2013 - Uploaded by Alan Marshall
McCulloch 2 cycle leaf blower vac. ... Your brand new leaf blower won't start? Try this ... starting contest echo pb251 vsmcculloch leaf blower.
cold start of my mcculloch leaf blower. - YouTube
? 4:24
https://www.youtube.com/watch?v=MgfmIezh65c
Mar 13, 2010 - Uploaded by keepin'itcountry
cold start of my mcculloch leaf blower. ... Your brand new leaf blower won't start? ... starting contest echo pb251 vs mcculloch leaf blower.
McCulloch won t start Leaf Blowers Questions & Answers ...
www.fixya.com > Forum > Tags > won t start > Leaf Blowers
McCulloch leaf blowers won t start related questions and answers. Ask your McCulloch questions. Get free help from leaf blower experts.
Nov 07, 2015 | McCulloch Garden
How to fix it?i put it on 220 and its 110
sorry but there is not fix for that .
Oct 23, 2015 | InStyler Rotating Iron
I have a InStyler (the rotating iron) by Tre Milano. This device is for styling hair. This is not a flat iron, but a cylinder that warms up and rotate's against a brush. It has 3 heat settings which...
I'm repairing an Instyler right now.
Troubleshooting, I connected a multimeter and measure the voltage where the motor is connected. When I push the button that makes spin it, I measure 12Vdc which is a correct value for that motor. Then I connected the motor and it did not spin. Therefore I need to buy one motor here:
http://www.makepolo.com/products/Linear-Motor-with-4.5-to-24V-p39074920.html
Same motor... yes you can repair it by installing a new motor.
Feb 04, 2013 | Vacuums
Put in new battery and it won't turn on
Hello, Hard to tell with info given, Try new battery to determine if it is battery related or a camera failure, Batteries are cheaper than camera repairs.
Hope this helps, Russell
Dec 10, 2012 | Kodak EasyShare Z612 Digital Camera
93 jeep won't crank. It is not turning over so to
Sluggish engine turnover can be the battery but won't be caused by gas. A problem related to gas would be more apparent after the engine is running.
Nov 04, 2012 | Cars & Trucks
Just had both o2 sensors replaced and now the truck won't shift from 2nd to 3rd gear. Evidently it had been slipping a bit before but now it won't shift into 3rd at all. The tranny is an E4OD......
O2 Sensors --- not related to shifting
New transmissions --- are only new once
When installed on the assy line
Has to be rebuilt if necessary
PO 147 ---O2 Sensor Heater (Bank 1 Sensor 3) don't have one of those
PO714 -- Trans Temp Sensor -heat for the slipping
PO 471 --- Exhaust Pressure Sensor -don't have that either
Need a new guy
Not very professional were they
Jun 13, 2011 | 1997 Ford Expedition
Won't turn over when trying to start. All dash lights come on...won't stary if jumped.
check the voltage of the battery,, it should be a little over 12 volts,, if not,, replace it
Jun 13, 2011 | 1995 Chevrolet Blazer
Does this unit have an automatic cutoff in case it is left on by mistake?
No, this flat iron does not have a shut off feature. If you're looking for one that does, the InStyler has the shut off feature and it's one of the best I've had (plus it doesn't burn my hair as bad). Hope this helps! :]
May 24, 2011 | Chi Ceramic 1 inch Flat Iron GF1001USA
I would like to know shipping arrival for a instyler hair tool
You should be able to click on set of numbers called a tracking link, usually in blue or green. Most often found in your shipping confirmation email. It doen't always get updated right away though. Sometimes it may take up to 24 hrs. to show any location.
Hope this Helps,
RSMITH972278
P.S. PLEASE RATE MY ASSISTANCE
Mar 08, 2010 | Computers & Internet
Health & Beauty Logo
105 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
