Question about Belkin Wireless Surf Router (F7D2301)
We have plugged in the router to the instructions on the box what next not working
    Sergeant:
  • 358 Answers
To restore the router to factory default settings, please do the following:
1. Unplug the router's power supply
2. Press and hold the reset button on the bottom of the router
3. Keep the reset button depressed and, at the same time, plug the power supply back in
4. Keep the reset button depressed for another 10 seconds
5. Release the reset button
======================= Manually configuration ==============================
Step 1 : Connect modem - Router - Computer ( Wired )
Step 2 : Open router setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left side under internet WAN click Connection Type
Step 4 : leave the Password Blank and click submit
Step 5 : Choose the connection type as dynamic and click next
Step 6 : Leave the Host name blank and click apply
Step 7 : On the left Under Internet WAN Click MAC Address
Step 8 : Click Clone and Click Apply changes
Step 9 : If the Internet status on the top right is connected
Step 10 : Then check if you have internet
Step 11 : if not Then unplug the Power Cable from the Modem And the Router
Step 12 : Plug the power Cord to the Modem
Step 13 : Wait till all the lights are on
Step 14 : Plug the power to the belkin
Step 15 : Check the color of the light in the belkin
Step 16 :If green then Check if you have internet
If not working then call belkin
=================== WIRELESS SETTING UP A WIRELESS CONNECTION ====================
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Posted on Nov 01, 2010
Unable to connect to wi-fi network. password entered years ago so forgotten,
If you have no other access to the internet then this may be a little challenging. Of course if you have no other access you can't read this answer!
Get the name and model of your router and google. Find the manufactures setup instructions. Find how to reset the router usually with a paper clip.
The best course of action is to start all over as if your router is brand new out of the box.
If your only access is via wi-fi then on the back of the router there is usually a reset button that returns the router to its original factory setting. This will reset the password.
Next plug everything in and you should be able to access the router, not the internet.
Next you may be required to enter the default password, usually "admin" to start making the necessary changes in the setup. This is where you would enter/change the assigned password to secure the wi-fi connection.
Hope this helps?
Nov 20, 2016 | Computers & Internet
Tip
How to hook up a wireless router.
<ol> <li> <p>Open the wireless router box and examine the contents. You should have the router, a setup CD-ROM, a network cable and a power adapter. If any of these are missing call the company on the box.Put the setup CD in the<a href="http://www.ehow.com/computers/">computer</a>. A screen will come up and ask you if you want to start the setup. All this CD is doing is taking you step by step through the hook-up process. Click Start setup.Choose which language you want to <a href="http://www.ehow.com/how_4424109_hook-up-wireless-router.html#">continue</a> in from a drop down menu and click next.Go over the user license agreement and check the box that says, "I accept this agreement." When you are ready click next.Allow the program time to check your <a href="http://www.ehow.com/internet/">internet</a> connection. When it is done it will say, "Check successful." Click next and you will be ready to begin hooking up your new wireless router.Remove <a href="http://www.ehow.com/internet/">the internet</a> cable from your computer. It will be the only one that goes in to a phone jack. Then plug it in to the wireless router in to the yellow spot. Each spot is colored for your convenience, but it should also be the only spot that fits the plug so you can't get it wrong even if you try. When you have done that click next.Get the network cable you found in your box. The cable should be blue. Plug one end of the cable in to the blue spot of your wireless router and the other end in to your computer. It will only fit in one spot so don't worry. Click next when you are done this part.Plug the power adapter into the wireless router. It goes right next to the blue wire, and will only fit in that one spot. The other end should be plugged in to an outlet or power strip. Click next and wait for the system to check if the router is hooked-up properly. If it is hooked-up properly it will say, "Configuration Complete." Click next.Click next to close the setup wizard and begin using the new wireless router. This process should have only taken you a total of five minutes. If you have any problems contact the company listed in your instruction booklet.<br /></li> <li> <p><br /></li></ol>
on Dec 05, 2010 | Computers & Internet
When plugged directly into router works ok. when plugged into our work network it will work ok for a day or two or maybe more then drops out and does not work. The B is blue and network boxes are green but...
The router uses DHCP to get an IP-address from a DHCP-server on your work-network. Each IP-address is valid for 24 hours.
So, your router is not issuing "renew" requests, to be allowed to use the IP-address for the "next" 24 hours.
Also, check that the router's internal clock has the correct date/time.
Mar 06, 2015 | Computers & Internet
It cannot be connect to pc
Check the physical layer first between the PC and the router. Make sure the ethernet cable is plugged in correctly on the port from the router to the port on the PC.
Next check if both devices are turn on, is the router functioning properly? is the pc turned on?
Now check the connection from one end to the other. Did the router work before or is it new? Is there instructions for out-of-the-box setup?
You can check your pc connections by opening a command prompt (start -> run and type cmd) this will open a black terminal in which you can issue the command ipconfig. By default routers will issue your computer a unique address called an IP Address. The format may look similar to 192.168.1.1. Does your PC have this connection? If not, ensure that network card on your pc is functioning and your router can assign addresses.
Mar 01, 2011 | Computers & Internet
Hello i am having probelms with my Belkin g basic router it has wireless and it works but when i connect it to my computer it does not it says it can't find or something but if i plug in my other box that...
It's sounds like you're getting your cords mixed up. The modem (the box from your company that provides internet) needs it's power cord plugged in, a phone cord or a cable cord plugged in, and an ethernet (LAN) cord plugged into it. The power cord will plug into the wall obviously, the phone cord or cable cord will be coming out of the wall obviously, but the Ethernet (LAN) cord will plug into your computer or a router. A router in your case. So the Ethernet cord from your modem (box that came from you company that provides internet) will plug into the router in the specific slot that says Internet or Modem connection. Now you need another Ethernet cord to go from your router to your computer. Try to plug the cord that goes from the router to the computer into the 4 different ports on the router until one of them works, you'll have to give it about a min to check each one. If that doesn't fix it then you need to make sure your LAN card is being read correctly and installed correctly, best way to do this is to go to Start > Control Panel > Device Manager and look at Network Adapters. If there is a Red X next to a conenction, right+click the conenction and tell it to enable, or update drivers.
Dec 13, 2010 | Belkin (F5D7231-4) Wireless Router
How do you hook up the wireless router
First configure your router with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi .Then save settings and restart router. Then connect internet cable from service provider to your router's WAN port.If you want wired internet then connect lan cable from computer to router's lan port. Let me know if you need further assistance. Thanks for using FixYa.
Oct 16, 2010 | Computers & Internet
Can not set up x box live error message states
Hello
First try a router reboot.Unplug all cables from router except power.
Find reset button on router,small use a pen tip or paperclip to hold button in for 60 sec.
Power router off.reconnect all cables.power router up.
Next activate wireless on the router.You will need to enter your wep or wireless code of router into the x box.
If your hard wired you will need to enter your username and password for the router into the x box.and the ip address of router.
username=admin
password=admin or password
Jan 17, 2010 | Microsoft Xbox Live 12 Month Gold...
Belkin G wireless basic home router installed ,followed instructions on cd .showing no connection on laptop.provider is virgen media,broadband via ethernet connection.any ideas.thanks
connect computer to router with an ethernet cable, open IE, on address bar type: 192.168.2.1. hit enter, u'll get a belkin router set up. in the left hand side click on "connection type".. it'll ask for a password, leave it blank and hit submit. on the next window click on dynamic ..click next.. click apply changes. then on the left hand side click MAC ADDRESS, click clone, click apply changes. then unplug the power from the belkin, unplug power from ur modem. and plug out the co-axial cable behind ur modem. wait for 2 mins. plug the modem back 1st.. wait for 3 mins.. plug back the belkin.. it shud work
Jan 13, 2010 | Computers & Internet
Belkin N Wireless Modem-Router F5D8633 drivers
Just hook it all up, and push and hold the reset button in the back of the router for 10 sec..
Then unplug your internet box, [cable/DSL box] and plug back in,
The internet box will send a IP to your router automaticly.
[If it dont work unplug power from both boxes, then back in but plug the internet box in first..]
done..
if your useing wireless this will not be setup with a password to join, and will be open to neighbors,,
If you want to go to the next step and setup a password to join, you can do this with out the cd also, but get it working first and hit me back
Sep 12, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Belkin Wireless Surf Router (F7D2301) Logo
138 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
