Question about ASUS P4XP-X Motherboard
Power sw -data +data
Hi ,
i'm bulding a PC
1- I put the procrssor and its fan
2- but ASUS P4XP-X Motherboard inside case
now there is wires from the case
coloer one have label like power sw
and other gray have label like -data
where i put these ?
    President:
  • 2,351 Answers
Did you get a manual with the board? Check page 1-20
You should find a pic just like this.
Wire colors. Black wire is ground - . Of all the case wire connectors the other common ground wire is white. Colors like red & blue are plus +.
It is much simpler to connect the case to motherboard LED's when the board is outside of the case.
Mike
Posted on May 04, 2008
I dont have wiring diagram of my motherboard please send me the diagram of wirng
Here is the link to download the manual for this motherboard:
http://dlcdnet.asus.com/pub/ASUS/mb/sock478/p4xp-x/e1193_p4xp-x.zip
Apr 12, 2011 | ASUS P4XP-X Motherboard
Heatsink fan spins without pushing power on button, no display asus p4xp-x, reseat video adapter, ram, remove connector power and signal to optical disk only mouse keyboard ram and video adaptr
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this will help don
Mar 11, 2011 | ASUS P4XP-X Motherboard
Had my motherboard changed by local repair shop. Both fans are now running constantly & it is deafening, also power light no longer comes on and was told it was "no big deal". Have 2 like computers,...
Ok so what fans? the case fans? the cpu fan? The power supply fan should always run. The case fan can be wired to the mother board and do an speed step system (slow to fast) depending on heat, same with cpu fan. As for the power light its just an matter of pluging in the wire from frount panel to the mother board pins for pwrled. Asus has an download for your board to get the pin outs.
http://dlcdnas.asus.com/pub/ASUS/mb/socka/sis741GX/e1766_a7s8x-mx.pdf
Feb 25, 2010 | ASUS A7S8X-MX Motherboard
CASE WIRES TO PANEL1 CONNECTIONS
The hdd red wire gooes to pin #1 the hdd white wire goes to pin #3 the power sw orange wire goes to pin #6 the power sw white wire goes to pin #8 The reset sw blue wire goes to pin #7 the reset sw white wire goes to pin #5 the power led green wire goes to pin #2 the power led white wire goes to pin #4.
Now the layout of the pins is the long row (5) pins are the odd number pins 9 being the odd one and 1 is the other end of the row. 2 through 8 start at the pin accross from 1 : : : : . I hope this helps you.
Aug 22, 2009 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
Motherboard failure
If the system appears to power on, but you do not see anything on the screen, there are several methods to determine the problem at hand.
Make sure the cooling system is fucntional.. a bad CPU fan has been known to make the computer power on, but halt and do nothing to protect the CPU. Some CPU fan's have speed sensors, and other do not, some motherboards require the speed sensor to be functional, or resistance in the line.
Some mainboards will function enough to power the system up, but go no further due to onboad componant failures such as bad / broken SMR, SMC, or capacitor. If you are sure the mainboard works, and the monitor is known to function, proceed with the following troubleshooting tips.
1) Remove everything but the memory, GPU, CPU, and HDD, see if boot is successful, if not Step 2)
2) Replace the Power supply, under powered PSU's can make a system unresponsive / fail to make it to POST, if fails step 3)
3) Replace Memory, if fails, 4)
4) Replace GPU.. if fails, 5)
5) Replace CPU, a non-funtional CPU will alow everything to power up, but will not allow POST in some machines.
6) Replace Motherboard, if fails, start at step 1)
May 29, 2009 | ASUS P4XP-X Motherboard
My pc don't have sound after format. my motherboard is ASUS P4XP-X
You can dlaod the sound drivers and any other drivers you may need from the asus website here:
http://support.asus.com/download/download.aspx?modelname=P4XP-X&SLanguage=en-us
just make sure you select your OS
Thanks for posting and please rate
Sean
Mar 30, 2009 | ASUS P4XP-X Motherboard
Gigabyte GA-8INXP Motherboard Problem- front connector pins
If the wires from the reset switch is white/blue the blue wire is positive, Hdd red/white red is positive power Green/white Green is positive etc. The wires on the speaker connector will be red/black/black/white - red is positive. The colored wire is always positive. On all GA mb's the positive connection is always towards the back of the MB and are marked with a + on the base of the pin as you can see on the photo. Hope this help.
Sep 19, 2008 | Gigabyte GA-8INXP Motherboard
Need graphic driver (Nvidia geforce2 Mx/Mx 400) for asus p4xp-x
You need to manually find the driver through this website http://www.nvidia.com/Download/index.aspx?lang=en-us
Please rate me SOLVED
Nov 23, 2007 | ASUS P4XP-X Motherboard
ASUS P4XP-X Motherboard Logo
1,711 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
