Question about Philips Magnavox 27MS343S 27" TV
Philps 60P8341A I have a 60 in. projection tv that is haveing picture problems. There seem to be halo's around everything and the edges around the screen are darker than the rest. There is also a red tint to everything. Does anyone have any ideas. Thank you......Daryl
I have a 60 in. Philip Magnavox tv that it haveing sound problems.It,s sounds when is in dvd ,but not when is in tv the model no.is 9p6040 c104. Does anyone have any ideas to fix this problem? Thank you........Lucy
Posted on May 04, 2008
SOURCE:
I have a PTV916 Model # 60P8341A. I cleaned the lenses and the mirror inside the TV however, I can see alot of dust inside the actual lens. Is it possible to clean the inside of the lenses?
ll projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 13, 2011 | Philips 50P8341 50" Rear Projection...
Yes my 60 in phillips rear projection tv model # 60p8341a the screen is a reddish orange color and wanted to know how to fix it
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
Dec 19, 2010 | Philips 60P8341 60" Rear Projection...
My Mitsubishi VS-60621 seems to have a convergence problem
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2010 | Mitsubishi VS-60621 60" Rear Projection...
Have a rear projection tv 55pp9352. Has green halos around objects on the screen. Checked convergence and all red and blue line up except that on the outside edges the convergence crosses are somewhat...
yes, you need remplace the liquid in the picture tube green and blue, and need remplace 2 parties stk-392-120 and resistences 6.8 ohms at 1/2 watts
Jan 05, 2010 | Televison & Video
White halo on picture
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Jan 25, 2009 | Televison & Video
I have a phillips 60'' and has yellowish color around the edges
hi the problem the picture tube of ur tv has got repaired. pls rate me
Jan 18, 2009 | Philips 60PP9363 60" Rear Projection...
Need tv help
The sympton for contaminated CRT coolant is objects having a halo effect on the effected CRT color. The Blue and green are the CRTs most often contaminated. But to answer the question changing coolant does help. You can look into the crt with it turned on to see if the coolant is congealed. Just be carteful not to touch any components as you look into the CRT lens.
Feb 20, 2008 | Philips Magnavox 9P6034C 60" Rear...
Yellow tinted halo
you need to have the lcd pannels cleaned
Feb 26, 2007 | Hitachi 60V710 60" Rear Projection HDTV
Philips Magnavox 27MS343S 27" TV Logo
57 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
