Question about GE 24 in. Profile PDW7800 Built-in Dishwasher
Water will not drain from bottom of GE Profile PDW7300 dishwasher. I checked the service mode feature by depressing the cookware and the heated dry keypad simultaneously for 3 seconds and did not hear any activity from the dishwasher when I activated the drain pump and when I activated the main pump. Other service mode features did activate when I checked them (i.e. activate water valve, open active vent, etc.).
SOURCE: Will not drain
the selenoyd is bad take front bottom cover off you will see the problem selenoyd with 2 wires conected to it
Posted on May 03, 2008
  • 3422 Answers
SOURCE: GE Profile Dishwasher not draining
HI,
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Posted on Jul 29, 2008
  • 38 Answers
SOURCE: water pooling on bottom of dishwasher
Check the drain pump for debris that might be stopping the drain pump from working. Also could be faulty drain pump.
Posted on Feb 20, 2009
jmgldsmth
  • 1889 Answers
SOURCE: GE Profile Dishwasher with water in bottom, won't drain
find the grille above the pump remove the grille and unclog the pump
Posted on Apr 28, 2009
SOURCE: I have a leak from the bottom of my GE Nautilus
i am having the same problem but i think it has to do with the seal
Posted on Jan 17, 2010
I have a ge profile dishwasher that does not drain well and dosent do the best job cleaning .could it be the drain
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
Dishwasher Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Dec 28, 2010 | GE Profile PDW8400J Built-in Dishwasher
I have standing water in the bottom after using
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
Please note that dishwashers don't drain out the complete water such that heating element doesn
Oct 20, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
The GE Profile Dishwasher does not drain completely. The bottom drain shows no obvious clog and the screens are clear. The overflow drain in the back of the washers the only reason the dishwasher does not...
Uncouple the drain hose connection under the sink and use a wet/dry vacuum to **** out the drain hose and the stub on the sink drain plumbing to clear any possible clogs. There may be a blocked check valve near the pump that might have to be cleaned or replaced. Check the hose itself for any kinks or collapsed section. There might be a damaged drain impeller on the pump. Hope this helps!
Mar 11, 2010 | GE Profile PDW8400J Built-in Dishwasher
Condensation in dishwasher
Make sure you aren't selecting the eco setting to conserve power. Running a dishwasher in that mode disables the heating element that dries the dishes at the end of a cycle. Here a few ideas you can try,... with an empty dishwasher.. start a cycle and make sure you do not use that ECO mode if it has that feature.. then stop the dishwasher when it near the end of the cycle and open the door ./.. check to see if the water has been drained and that the heater element is on and hot. If there is a high volume of water in the bottom of the dishwasher, make sure the darin filter screen is clean and not restricting water flow... If that is clean.. and you have a lot of water in the bottom pan, you could have a problem with the pump, a hose in line with the pump or your house drain system is restrictive.. Good luck... and Hope this helps you..
Nov 29, 2009 | Kenmore Dishwashers
Low detergent light does not come on indicating the GE profile dishwasher is out of detergent.
It is probably because your Smart Dispenser is full of water and there may be a clog of some type in the pump. Try purging your Smart Dispenser and see if it fixes the problem!! It fixed ours!!
How to Purge Smart Dispenser
The purge routine operates the bulk dispenser pump continuously to drain the bulk dispenser tank when an incorrect liquid was poured in the tank. The process consists of setting up the dishwasher to run the purge mode, running the purge mode and then cleaning up the purged detergent.
Follow these steps carefully to have a successful purge run.
For Top Control Models:
  1. Make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
  2. Press Heated Dry and Down Arrow buttons together for 3 seconds. All LEDs will illuminate.
  3. Press Added Heat and Up Arrow buttons together for 3 seconds. The Anti-bacteria LED will illuminate
  4. Press Start button one time
  5. Select Normal and make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
  6. Press Start button one more time and dishwasher will run a complete cycle without the main motor running. Cycle is complete when the Clean light illuminates. This should take approximately 60 minutes.
  7. Open door and wipe up excess detergent from the door and tub
  8. Flush remaining detergent off by pouring water on the door and tub where there is detergent residue.
  9. Remove SmartDispenser cap and fill tank with water and then replace cap.
  10. Repeat Steps 1 through 9 one time.
  11. Then, repeat Steps 1 through 6. When the Clean LED illuminates, the system is purged and ready to be refilled with the correct detergent.
Front Mount Controls (same as above except for the changes in the two below steps):
2. Press Heated Dry and Cookware together for 3 seconds. All LEDs illuminate.
3. Press Added Heat and Cookware together for 3 seconds. The Anti-bacterial LED illuminates.
Jul 09, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Purging ge profile smart dispense dishwasher
How to Purge Incorrect Liquid Detergent from the Bulk Dispenser
Jul 05, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
GE dishwaher leaks with standing water in bottom
Check to make sure regular dish soap did not end up getting inside the dishwasher. This will create a lot of suds that will overflow onto the kitchen floor. Standing water from not draining can mean the drain hose is clogged somewhere or the check valve has something caught in it. If you remove the front kick plate, you will be able to check those.
http://tclaundryrepair.com/
Feb 26, 2009 | GE 24 in. Profile PDW7800 Built-in...
Water pooling on bottom of dishwasher
Feb 20, 2009 | GE 24 in. GSD4320Z Built-in Dishwasher
GE Profile PDW7300, Leaves 2 - 3 inches of dirty water in bottom
check for a clogged discharge hose where it connects to the plumbing under the sink...this is the most common area for a clog. if no restriction is found, the discharge valve will need to be tested
Feb 20, 2009 | Dishwashers
GE 24 in. Profile PDW7800 Built-in Dishwasher Logo
201 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
