Question about Maytag Neptune MDE6700A Electric Dryer
Our dryer is not heating up. I've checked the circuit breakers, cleaned the vent and everything dealing with this problem in the owners manual. Do you have any other idea's what the problem maybe?
  • Maytag Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Aug 22, 2010
Dryer wont heat up
Small 3oo f fuse mounted on the heater element is probo blown from over heat due to vent blockage.
Dec 30, 2015 | Roper REX3614KW Electric Dryer
Dryer has no heat
Check your breaker for the dryer. The breakers are usually tied in to each other, however, sometime they are not, and one breaker can trip while the other stays on.
Mar 06, 2015 | Dryers
Kenmore cloths dryer no heat --- drum and air but no heat ---think it is therma fuse clean vents
Well it runs so that is not the thermal fuse. I would check the limits on the heater or maybe the heater itselfthemobilian_2271.jpgthemobilian_2272.jpgthemobilian_2273.jpgthemobilian_2274.jpg
If these components check ok and yall still have no heat then the timer may be bad.
or the dedicated house dryer circuit breaker is gone on the heat load side.
The motor works on 120 volts or L-1 and neutral. The 5000 watt 240 heating element needs both sides of the breaker to operate correctly. Heat can be iffy or none at all if this is the case.
I have service manual and more HERE
May 02, 2011 | Kenmore Dryers
Dryer drum loose not lining up properly making a huge thumping sound
Identification of Dryer Problems
Signs that an electric dryer may need some repairs include the dryer not heating, clothing not drying fast enough, overheating of the dryer, the door not locking shut and the dryer not starting at all. Any of these are signs of an underlying problem that can usually be solved without the help of a repairman.
Effects of Dryer Issues
If an electric dryer doesn't heat properly, it prevents the clothing from becoming dry in most cases. Restricted venting can cause clothing not to dry fast enough, as the dryer will cycle the heating. Overheating dryers can ruin clothing or cause burns. If the door on a dryer wont close, it is impossible to get any laundry dried. A dryer not running at all can be very frustrating and lead to owners needing to use a laundromat.
Considerations for Solving Common Problems.If the dryer wont heat up, owners should check the circuit breaker to see if it's down. The voltmeter at the wall plug should read 240 volts. Checking the power cord can show owners if the wires are burned where they meet the dryer.Clothing not drying fast enough and overheating are signs of restricted venting. Removing the vent hose from the dryer can help owners decide if this is the cause of clothing not drying. If the hose is removed and the dryer runs normally, the vent should be cleaned.White plastic or thin foil ducts can also lead to overheating. Only metal ducts should be used with dryers. Kinks in the vent hose can also lead to heating issues. Overheating can also be caused by a shorted heater coil, a bad operating thermostat or worn drum seals.If the door on an electric dryer will not close, it is usually a problem with the door catch. This can be solved easily by purchasing a replacement door catch for the dryer.
When a dryer wont run, it could be a number of issues. The circuit breaker may be down or the wires at the plug may be burned. It may be an issue with the door switch. The door switch should click when closed. The thermal fuse should be checked for any issues.
Preventing Dryer Problems
The electric heating element, thermostats, fuses and thermal cut-off should be checked regularly for continuity. Dryer vents should not exceed 18 feet without a helper blower in the duct. Vents that are run vertically need to be cleaned out once a year. A meter can be purchased and used to diagnose problems with your electric dryer.
Warnings and Tips.Inexperienced people should never try to fix electrical problems at home. A professional should always be used if dryer owners suspect a more serious problem. Dryer owners can purchase kits to make cleaning dryer vents easier.
Mar 11, 2011 | Whirlpool Dryers
Kenmore 80 series dryer approx 7 years old not heating anymore. Cleaned the vent pipe using semi-rigid vent tube only three feet to outdoors. Vent on exterior blowing cool air forcefully. It is an...
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it.
Here is a link to a video that will help you.
Nov 26, 2010 | Dryers
Heating element is not working
I would say it could be one of two things. The heating elements could be bad, not likely though as the were working when the dryer was reset. You may want to try changing your circuit breaker, as your heating elements work off of the 2 phase 240 voltage while everything else in the dryer works off 120V. Check the voltage on each phase of the breaker in your electric panel see if your putting out the full 110-120V per phase.
Jan 09, 2010 | Frigidaire GLER331A Electric Dryer
The dryer works but no heat.
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jun 18, 2009 | Whirlpool GEW9250 Electric Dryer
Works but no heat
if the dryer is gas the first thing to check is the igniter the most common solution. If it is electric the first thing to do is check your circuit breakers it takes to for an electric dryer one to run one to heat.
Jan 01, 2009 | Dryers
Kenmore 64942300 Electric Dryer runs, no heat
This may seem too simple of an answer based on your extensive troubleshooting thus far, but the most common reason for cold air running of any electric dryer is a broken heater coil. This is simply a coil of wire that is heated to warm the air in the fan duct. These often overheat and break if the vent duct is blocked, too long, or has odd bends that can restrict flow. Recommend replacing heater coil and use smooth wall vent pipe. Avoid coil type flexible duct.
Jul 03, 2017 | Kenmore 64942 Electric Dryer
Dryer runs, tumbles clothes, but does not heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Aug 09, 2008 | Maytag SDG4606A Gas Dryer
Maytag Neptune MDE6700A Electric Dryer Logo
57 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
