Question about Yahoo Mail
I have an account,so does another user on same computer his always open
  • 22 Answers
The other person is not signing out and has checked "Stay Logged On". All you need to do is log him off, and tell him to stop checking the box "Stay Logged On".
Posted on Aug 21, 2010
Does not log in to my acc on linux
when setting up a linux computer you need to set up a root account and a user account.
use the user account for your every day work and the root account to administer the computer
a common mistake people make is mistyping passwords or hitting the capslock key when the were going for thr shift key.
this is why i recommend all passwords be either lower case or caps
always choose a password that you will always remember.
Aug 19, 2013 | Computers & Internet
Tip
Using UAC in Windows Vista
Windows Vista has the built-in ability to automatically reduce the potential of security breaches in the system. It does that by automatically enabling a feature called User Account Control (or UAC for short). The UAC forces users that are part of the local administrators group to run like they were regular users with no administrative privileges.
Although UAC clearly improves the security on Windows Vista, under some scenarios you might want to disable it, for example when giving demos in front of an audience (demos that are not security related, for example). Some home users might be tempted to disable UAC because of the additional mouse clicking it brings into their system, however I urge them not to immediately do so, and try to get used to it instead.
Anyway, if required, you can disable UAC by using one of the following methods:
Method #1 - Using MSCONFIG
  1. Launch MSCONFIG by from the Run menu.
  2. Click on the Tools tab. Scroll down till you find "Disable UAC" . Click on that line.
  3. Press the Launch button.
  4. A CMD window will open. When the command is done, you can close the window.
  5. Close MSCONFIG. You need to reboot the computer for changes to apply.
You can re-enable UAC by selecting the "Enable UAC" line and then clicking on the Launch button.
*Recommended: Speed up Vista boot times by reducing the number of programs that load at startup. Control your Vista startup list with this Vista app
Method #2 - Using Regedit
  1. Open Registry Editor.
  2. In Registry Editor, navigate to the following registry key: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Policies\System
  3. Locate the following value (DWORD): EnableLUA and give it a value of 0.
    disable_uac_2.gif Note: As always, before making changes to your registry you should always make sure you have a valid backup. In cases where you're supposed to delete or modify keys or values from the registry it is possible to first export that key or value(s) to a .REG file before performing the changes.
  4. Close Registry Editor. You need to reboot the computer for changes to apply.
In order to re-enable UAC just change the above value to 1.
Method #3 - Using Group Policy This can be done via Local Group Policy or via Active Directory-based GPO, which is much more suited for large networks where one would like to disable UAC for many computers at once.
If using Local Group Policy you'll need to open the Group Policy Editor (Start > Run > gpedit.msc) from your Vista computer.
If using in AD-based GPO, open Group Policy Management Console (Start > Run > gpmc.msc) from a Vista computer that is a member of the domain. In the GPMC window, browse to the required GPO that is linked to the OU or domain where the Vista computers are located, then edit it.
  1. In the Group Policy Editor window, browse to Computer Configuration > Windows Settings > Security Settings > Local Policies > Security Options.
  2. In the right pane scroll to find the User Access Control policies (they're down at the bottom of the window). You need to configure the following policies:disable_uac_gpo_2.gif
  3. You'll need to reboot your computers.
Method #4 - Using Control Panel
  1. Open Control Panel.
  2. Under User Account and Family settings click on the "Add or remove user account".
  3. Click on one of the user accounts, for example you can use the Guest account.
  4. Under the user account click on the "Go to the main User Account page" link.
  5. Under "Make changes to your user account" click on the "Change security settings" link.
  6. In the "Turn on User Account Control (UAC) to make your computer more secure" click to unselect the "Use User Account Control (UAC) to help protect your computer". Click on the Ok button.
  7. You will be prompted to reboot your computer. Do so when ready.
In order to re-enable UAC just select the above checkbox and reboot.
on Apr 29, 2010 | Microsoft Windows Vista Home Premium...
Tip
Disable UAC (Universal Access Control)
Using Control Panel
1) Open Control Panel.
2) Under User Account and Family settings click on the "Add or remove user account".
3) Click on one of the user accounts, for example you can use the Guest account.
4) Under the user account click on the "Go to the main User Account page" link.
5) Under "Make changes to your user account" click on the "Change security settings" link.
6) In the "Turn on User Account Control (UAC) to make your computer more secure" click to unselect the "Use User Account Control (UAC) to help protect your computer". Click on the Ok button.
7) You will be prompted to reboot your computer. Do so when ready.
on Jan 04, 2010 | Computers & Internet
I cant get in to my othere user act on my compter..
Well there are two ways to do this.
1. Login to your account, go to the start menu, control panel, user accounts
click on the user account you cant login to, click change password, change the password and logout. Login to the account with the new password. (Only works if you have a admin account)
Or
2. Go to the start menu, click on RUN. Type control userpassword2 . Uncheck the checkbox that says "Users must enter a user name and password to use this computer. Click apply, restart the computer. All set (Always works)
Have a nice day!
Aug 20, 2011 | Computers & Internet
Want to delete old account and make knew one
Hi carolgard276...
Left click on "Start">left click on "Control Panel">left click on "User Accounts">left click on "Change an Account".
You probably already know that only computer adminitrators can delete user accounts. But even if you are a computer administrator, you can't delete your own acount. You'll need to ask someone else with a computer administrator account to do this for you.
If there are no other computer admistrator accounts on your computer, you must first change someone else's account type to "computer administrator", and then ask that person to delet your account.
This ensures that there is always at least one person with a computer admimistrator account who can manage all user accounts and make system-wide changes to the computer.
Please take time to rate me
How do i delete all the user accounts and make a new one
To open the User Accounts tool, open Control Panel from the Start menu, and then double click User Accounts.
To Create a New User Account
  1. Click Create a new account in the Pick a task list box.
  2. Type the name that you want to use for the account, and then click Next.
  3. Select the desired account type, and then click Create Account.
To Make Changes to an Account
  1. Click Change an account in the Pick a task list box.
  2. Click the account that you want to change.
  3. Select the item that you would like to change:
    • Click Change the name to change the name that appears on the Welcome screen for the account.
    • Click Change the picture to change the picture that is used to represent the user account. You can use any image file on the computer for the user's picture.
    • Click Change the account type to change the account type to increase or decrease the user's rights on the computer.
    • Click Create/change the password to create or change the password for the user and create or change the password hint.
    • Click Delete the account to delete the user account from the computer. When you delete the account, you are given the option to save the user
Nov 10, 2010 | Computers & Internet
Changing users on same computer
If you want to change Facebook user accounts on the same computer, you can do one of three things:
1) Simply click on Account and Logout, then log in with the new user.
2) Use a different browser, like Firefox, so that the first user doesn't need to log out before the second user can log in - the second user simply opens the Internet in Firefox instead.
3) Create a new Windows user account. The second user would then log out of the first person's Windows account and log in to their own and open Facebook there.
Aug 19, 2010 | Facebook Social Network
Anti spy on yahoo says i need administrative rights to work?
If you are using XP or later and you have established user accounts on your computer, or someone who actually controls your computer has created user accounts, there is a good possibility you do not belong to the "Administrative User group". If this is your computer, you will need to log in as an administrative user with the proper password, if you assigned one. If the computer is actually controlled by another person, you will have to get that other person (mom, dad, sister, brother, son, daughter, boss, neighbor, dude down the street, other person) to change you from "limited" to "administrative" user.
It is not my intention to be negative when I make reference to the person who controls your computer. If you cannot get in as administrator, evidently you forgot the process or someone else doesn't want you to be installing programs on the (their) computer.
These changes can be made by going to the control panel and opening USER ACCOUNTS (in XP). If you do have administrative rights, you can make the changes, if you don't, well then, Windows will not allow it.
I hope this information helps you
Thanks for using FixYa.com
Please vote
positive comments always welcome
thanks
a
Dec 06, 2009 | Computer Associates CA Anti-Spyware 2008...
I want to know how to delete a standerd user account?
I you are using Windows, click "Start" then "Control Panel" then "User Accounts," then "Change an Account." Choose the account you wish to delete, then click "Delete Account" it will ask you if you want to keep the account's files, say yes only if you had something important on that account. NOTE:you can only delete accounts if you are a administrator.
If you are using a Mac, click "System Preferences" then "Accounts" then select the account you wish to delete and click the little minus sign at the bottom. NOTE: Like Windows, you can only delete accounts if you are an administrator.
Aug 22, 2009 | Computers & Internet
Logon doesn't work
You need to log in to windows with SafeMode at startup. When you first see the curser flashing hold the "F8" key to enter safemode. Then select safemode with networking. Then go into user accounts from Control Panel and open up your user name file and change the password. Good Luck.
Jul 29, 2009 | Acer Aspire One PC Notebook
Yahoo Mail Logo
43 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
