Question about Weiser Lock POWERBOLT ELEC DEADBOLT
My lock works in reverse - Weiser Lock POWERBOLT ELEC DEADBOLT
  • 963 Answers
Here is a link to the Frequently asked question page for your lock:
http://www.weiserlock.com/Support/Faq/50160000000HhmZAAS.aspx
I have installed your Powerbolt, but when I push the Lock Button, it unlocks? What should I do?
First remove the cover on the inside of the Powerbolt unit. On the right hand side under the batteries, you will notice that is says "Door Direction Jumper". If the cap is mounted on Prongs 1 & 2, carefully remove it and move it over so that it mounts Prongs 2 & 3. A is right handed, B is left handed.
Here's a link which tells you how to remove the cover, and reprogram the lock codes:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Posted on Mar 05, 2011
My singer 4210 will only work in reverse
The reverse button may have loosened check for looseness and tighten if possible
Oct 30, 2014 | Singer Inspiration 4210 Mechanical Sewing...
Bobbin bunching in reverse, I have adjusted all tensions and ONLY in the reverse I get a "rats nest" under my fleece fabric. Stitches beautifully but once you ask for a reverse, it is a mess
For all machines that I have experience the reverse button or control is only use to lock the finishing end of your sewing & if reverse all the way would not work right.
Oct 28, 2013 | Sewing Machines
Kwikset lock works in reverse
Yes, it does work in reverse. For more information make sure to read this: Schlage Connect vs Kwikset Kevo
Feb 16, 2013 | Weiser Lock Powerbolt 1000 Lock
Quantum ENERGY PTI E10PTI The anti reverse
It isn't the anti reverse. It is actually the clutch assembly. The internal bearing only spins one way and is press fit into a gear of sorts. The anit reverse locks and unlocks the gear. The design is absurd because the internal bearing fit within the gear breaks free. This allows the bearing to spin inside the gear. The anti lock is working but the bearing is spinning inside. The part is no longer available. The new reels also have a new design.
Jun 29, 2011 | Sport & Outdoor - Others
Have all gears that work find but will not go in reverse it a 5 speed
Is this a new truck to you? Some manual's have a manual reverse lock-out, meaning you have to engage the lock-out to shift into reverse. This is usually done by pulling up on a small lever just under the shift knob.
Otherwise, the lock-out is inside the transmission and if that breaks, the transmission has to be removed to fix it.
The other possibility is that you don't have a synchronized reverse gear. It will not automatically sync with the engine speed. Try lightly putting it in reverse while letting the clutch up to the engage point, you know, right where the clutch first starts to grab.
Jun 07, 2011 | 1992 Nissan Pickup
Somehow the lock thinks that when the door is locked it is open, and when it is open, it thinks that it is closed. Did I somehow put the lock on in some reverse order? Or can I somehow program the lock...
Take the lock back off and flip the back portion of the lock so the locking lever is reversed you have that on backwards. If that doesn't work reset the lock back to factory settings and reprogram the lock!
Aug 11, 2010 | Schlage Camelot Deadbolt Keypad, Satin...
2002 Mercury Grand Marquis. Backup lights won't work
Does pushing the trunk release button make the back up lights illuminate? Has the car been serviced or wrecked before this problem? Have you been golfing and put clubs in the huge trunk. Either the ground wire for the trunk lid devices is bad or the trunk release wire (purple/orange) and the reverse lamps wire (purple/white) have been reversed.
Mar 22, 2009 | 2002 Mercury Grand Marquis
Weiser Lock POWERBOLT ELEC DEADBOLT Logo
338 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
Jim Goldsmith
Jim Goldsmith
john h
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
