Question about HP psc 1310 series
Went to scan paper and it comes up with error, check your cartridges. both new and had printed just before. can't cancel and tried to shut off and same error comes up
I want to operat window 7 capable to hp psc 1310. Please confirm
Posted on Sep 09, 2010
MY HP printer can print but does not copy
Same thing just happened to my fairly new 7520 Hp.
I shut my machine first with the shut off button and then unplugged
it for about 5 minutes. Sounds like you tried this and I believe this did not work for me either so I just went into the HP official site and downloaded my printer again. Downloading your printer from their
site is easy and quick instead using the cd. It automatically removed my old printer and installed the printer again. The problem has not returned.
Another problem I just had and because I think one of my new
cartridges (yellow) is somehow damaged. I got a black line down
my pages with a note that my yellow ink is missing. Had black line only when printing and not copying. I reinserted the yellow ink and took a light damp qtip and slightly wiped the machine screen on each ink cartridge.(this screen meets the new opening from each
new cartridge. The black line left.
Hope this helps.
Jan 02, 2015 | HP PhotoSmart Office Equipment & Supplies
Loaded new print cartridges went through alignment check /scan error message none alignment.Reloaded cartridges went through same proceedure same result.unable to print anything
Are you checked working condition of scanner before replacing the cartridges?. If scanner is not working align process could not completed..cancel the align process then you can able to take prints..
Sep 10, 2011 | HP Photosmart 4180 All-in-One Printer
The HP Photosmart c3180 prints a color test sheet every time I turn it on even if only to scan a document. How do I prevent it from doing this?
1. Turn on the HP all-in-one.
2. Disconnect the USB cable from the all-in-one.
3. Press the sequence of front panel buttons below to initiate the print cartridge alignment process. The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
a. Press and hold Cancel.
b. While holding Cancel, press On.
c. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
d. Press Cancel again.
e. Press Copies.
f. Press Paper Type.
g. Press Color Start Copy.
h. The alignment page will begin printing. If the alignment page does not print, repeat the button-press sequence in this step.
4. Once the alignment page is printed, place the page face down on the scanner glass and press Scan. The alignment is complete when the On light stops blinking. 5. Reconnect the USB cable.
Mar 15, 2010 | HP Photosmart C3180 All-In-One InkJet...
I JUST CHANGED THE TONER AND THE COPIES ARE PRINTING OUT WITH A HEAVY THICK LINE ON THE SIDES
Indication Cause and remedy Page
Drum replacement
required indicator
Steadily
lit
Replacement of drum cartridge will be needed
soon. Prepare a new cartridge. 70
Blinking Drum cartridge must be replaced. Replace it with
a new one. 58
TD cartridge
replacement
required indicator
Steadily
lit
Replacement of TD cartridge will be needed
Blinking TD cartridge must be replaced. Replace it with a
new one. 57
Misfeed indicator Blinking
A misfeed has occurred. Remove the misfed
paper referring to the description of "MISFEED
REMOVAL".
63
SPF misfeed
indicator Blinking
An original misfeed has occurred in the SPF.
Remove the misfed originals referring to the
description of "D: Misfeed in the SPF".
67
Power save indicator is
steadily lit.
The unit is in the preheat mode. Press any key to
cancel the preheat mode. 54
The unit is in the auto power shut-off mode.
Press the start ( ) key to cancel the auto power
shut-off mode.
54
The paper tray indicator is
blinking.
The paper tray is not installed properly. Push the
tray into the unit securely. –
"CH" is blinking in the
display.
The TD cartridge is not installed. Check if the
cartridge is installed. 57
"CH" is steadily lit in the
display.
Side cover is open. Close the side cover
securely by pressing the round projections near
the side cover open button.
"P" is blinking in the display.
The paper tray or multi-bypass tray is empty.
Load paper. 15, 17
A misfeed has occurred in the paper tray or
multi-bypass tray. Remove the misfed paper. 63
A letter and a number appear
alternately.
The scan head locking switch is locked. Unlock
the scan head locking switch. 9
alternately.
The unit will not function. Turn the power switch
off, remove the power cord from the outlet, and
contact our Technical Assistance Department at
1-(630)378-3590 in the USA or 905-568-7140 in
Canada.
May 13, 2009 | Sharp Office Equipment & Supplies
X2480 unable to bypass print/scan of alignment page
Here is the way I bypass the alignment when I get a new cartridge: When the screen comes up that is asking for it, it does not have the option to "cancel" the printing of it. I just take the paper out of the printer and press "print". Since there is no paper in it, it cannot print. This will make the same screen come up again, but this time it has the "cancel" option. Now, every time I want to print something out, the screen that wants to print a alignment page comes up, and I just click on "cancel" - after that I can do my printing. This is a bit annoying, but it saves me some ink.
Mar 23, 2009 | Lexmark X2470 All-In-One InkJet Printer
My printer keeps printing test pages
unplug it and plug it back in this should fix it
Jan 28, 2009 | HP PSC 1510 All-In-One InkJet Printer
HP 1210 all in one printer does not have a maintenance button to allow me to align cartridges. Prints landscape pages out of alignment; I have tried taking the cartridge out and putting it back but it...
On the printer hold down the CANCEL button then press and hold the ON/RESUME button until the CHECK PAPER and CHECK PRINT CARTRIDGE LIGHT both blink simultaneously.
When both lights are blinking press CANCEL, COPIES, PAPER TYPE, and COLOR START COPY one after the other. All this must be done in under 10 seconds for it to work. Once this sequence of buttons is completed correctly in under ten seconds an alignment page will print.
Apr 09, 2008 | HP Office Equipment & Supplies
Have canon mf5700 says check paper size and only prints one page of several page job
go to control panel> printers> and make sure in preferences its set to LTR (letter)
Hope this helps
Dec 21, 2007 | Office Equipment & Supplies
Aligning printer after new ink cartridge inserted
SOLUTION: Start the cartridge alignment by performing a series of button presses from the front panel of the product.
  • HP PSC 1200 and 1300 series:
    1. Turn on the HP PSC 1200 or 1300 series product.
    3. Press the sequence of front panel buttons below to start the print cartridge alignment process. The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
      1. Press and hold Cancel .
      2. While holding Cancel , press On .
      3. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
      4. Press Cancel again.
      5. Press Copies .
      6. Press Paper Type .
      7. Press Color Start Copy . The alignment page will begin printing. If the alignment page does not print, repeat the button-press sequence in this step.
    4. When the alignment page has printed, place the page face down on the scanner glass and press Scan . The alignment is complete when the On light stops blinking.
CAUSE: This can occur if the cartridge alignment is canceled or times out without a valid print cartridge alignment stored in memory.
Oct 29, 2007 | HP PSC 1350v All-In-One InkJet Printer
Hp psc 1219
try pressing repeatitivly the red cancel button
Apr 16, 2007 | HP PSC 1210v All-In-One InkJet Printer
Computers & Internet Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
