My Epson 810 runs continuously printing some with gibberish and some plain run through. You can only stop it by turning the machine off or taking the paper out. It receives no command from the computer nor will it scan. I have a Mac Snow Leopard upgrade. I have installed the driver required. It has been printing. Just went wacky.
  • 2,973 Answers
The drivers of the device are malfunctioning. Please uninstall the device from Control Panel->Add Remove Program. Reboot the computer and the reinstall the drivers. Follow the link below verbatim.
http://www.fixya.com/support/r3559995-installing_devices_on_pcs_and_laptops
Posted on Aug 21, 2010
Printing report
Hi there. Very cool website!! Man .. Beautiful .. Wonderful .. I will bookmark your site and take the feeds also...I'm happy to locate a lot of useful information right here within the post. Thank you for sharing.
Nov 22, 2013 | Canon Laser Class 810 Plain Paper Fax
My Epson Artisan 810 prints horizonal light blue lines on all printed materials. How to remove the blue lines?
To resolve this issue, you need to print a nozzle check pattern and then determine if print head cleanning is need.
To print nozzle check, follow the steps below.
  1. Turn off the Artisan Series and your computer, if connected.
  2. Disconnect any connected USB cables.
  3. Load plain paper in the main tray.
  4. Press the On button to turn the Artisan 800 Series on again.
  5. Press Setup.
  6. Select Maintenance.
  7. Select Nozzle Check.
  8. Press Start.
  9. The Artisan Series begins printing the nozzle check pattern.
  10. If there are no gaps, select Finish Nozzle Check.
    If there are gaps, select Head Cleaning.
If the nozzle check pattern page prints correctly, the problem may be with your software settings, the interface cable, or your computer.
Oct 31, 2011 | Epson Artisan 800 All-In-One InkJet...
Shows code U165
This section explains the way to confirm the ink status and the procedure to replace ink tanks. When ink runs out or other errors occur, an error message is displayed on the LCD to inform you of the error. See "An Error Message Is Displayed on the LCD".
When printing from your computer, error messages appear on your computer screen as well.
NOTE
Be sure to install the ink tanks in the correct order indicated by the label on the Print Head Holder.
The machine will not print if an ink tank is installed in the incorrect position.
With the LCD of this MachineMake sure that the machine is turned on, then press the COPY, FAX, SCAN, or MEMORY CARD button. The current ink level will be displayed on the LCD for a few seconds.
g0011480_tcm14-605381.png(A) Confirm whether any symbols are displayed here.
g0011482_tcm14-605375.pngColor or black ink is low. You can continue printing for a while, but we recommend you to have a new ink tank available.g0011483_tcm14-605376.pngColor or black ink may have run out. See"An Error Message Is Displayed on the LCD".
REFERENCE
The ink status information is also displayed on the screen that appears during printing.
An error message may be displayed on the LCD during printing.
g0011494_tcm14-605377.pngMachine detected ink out condition. See "An Error Message Is Displayed on the LCD" and take appropriate action.
(B) Empty ink tank.With the Ink LampsYou can confirm the status of each ink tank by the ink lamps. Open the Scanning Unit (Printer Cover) of the machine to confirm how the ink lamps light or flash.
  • Ink lamp is on
The ink tank is correctly set and there is enough ink remaining to print.
  • Ink lamp is flashing
Flashing slowly (at around 3-second intervals)
Ink is low. You can continue printing for a while, but we recommend you to have a new ink tank available.
Flashing quickly (at around 1-second intervals)
The ink tank is inserted in the wrong position or it is empty. Ensure that the ink tank is in the correct position as directed by the label on the Print Head Holder. If the position is correct and its lamp flashes, it is empty. Replace it with a new one.
  • Ink lamp is off
The ink tank is not set properly or the function for detecting the remaining ink level is disabled.
If the ink tank is not set properly, press the g0009324_tcm14-605384.png mark on the ink tank until the tank clicks into place. If it does not click into place, make sure that the orange protective cap has been removed from the bottom of the ink tank.
If the function for detecting the remaining ink level is disabled, replace the ink tank with anew one. See "Replacing Ink Tanks".
If the lamps are still off after reinserting the ink tanks, there has been an error and the
machine cannot print. Check the error message displayed on the LCD. See "An Error
Getting the Clear Ink Status InformationClear ink is used only when printing on plain paper.
When Plain paper (Cassette) is selected for Media type and printing begins when clear ink (PGI-9Clear) is low, a message will be displayed in the LCD.
g0011497_tcm14-605385.png(A) Confirm whether a symbol is displayed here.
g0011502_tcm14-605378.pngThe clear ink is low. You can continue printing for a while, but we recommend you to have a new ink tank available.g0011503_tcm14-605379.pngThe clear ink tank is empty. See ""The clear ink tank is empty. Replacing the ink tank is recommended." U045" and take appropriate action.
NOTE
  • The ink status information is also displayed on the screen that appears during printing.
  • Clear ink is used only when printing on plain paper. Therefore, it is possible to print on photo paper, or any type of paper other than plain paper, loaded in the Rear Tray, even if clear ink has run out.
The following error message will be displayed on the LCD when the clear ink has run out during printing on plain paper.
g0011506_tcm14-605380.pngRefer to "Replacing Ink Tanks"If you continue printing under the clear ink out condition, see ""The clear Ink has run out. Replace the ink tank." U165/U166" and take appropriate action.When the clear ink hasrun out, printing on plain paper from the Cassette is not possible. The fax, which is received under the clear ink out condition, will be stored in memory.
NOTE
It is possible to print on photo paper, or any media type other than plain paper, loaded in the Rear Tray, even if clear ink has run out.
Oct 01, 2011 | Canon PIXMA MX340 Wireless Office...
My Artisan 810 ADF gets jam error. There is no paper there. The motor just whirls and then gives ADF jam error. My 810 is near new, less than 300 sheets printed, less than 100 scanned using...
Just fixed my problem today. It was the ADF assembly motor. The spur gear had cracked open where it can no longer grip tightly to the center rod when the motor spins. I bought a new motor assembly from CompassMicro for the total amount of $23 and my printer is back in running order like normal again. Beats taking it to a repair center and get ripped!
Sep 10, 2010 | Epson Artisan 800 All-In-One InkJet...
Replaced the ink cartridge now it will not print
*** I'll be more than happy to help you on that.
there is a great possibility that the nozzles of your printer are clogged by dried inks.maybe cause by the previous inks that you just replaced. we can check that by printing a nozzle check pattern.
1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX110 Series. 3. Hold down the nx110_tx110_ug.1.98.1.jpg Stop button as you press the nx110_tx110_ug.1.98.2.jpg On button to turn the Epson Stylus NX110 Series back on. When the nx110_tx110_ug.1.98.3.jpg On light begins to flash, release the nx110_tx110_ug.1.98.4.jpg Stop button. nx110_tx110_ug.1.98.5.jpg 4. Check the nozzle check pattern that prints to see if there are gaps in the lines. nx110_tx110_ug.1.98.6.jpg 5. If there are no gaps, the print head is clean and you can continue printing. If there are gaps or the pattern is faint, clean the print head. Using the Control Panel 1. Load a few sheets of plain paper in the sheet feeder. 2. Make sure the Epson Stylus NX110 Series is on and the ink light is off. 3. Hold down the nx110_tx110_ug.1.99.1.jpg Stop button for three seconds to start the cleaning cycle, which lasts around one minute. The nx110_tx110_ug.1.99.2.jpg On light flashes throughout the cleaning cycle and stays on green when the cycle is finished. Caution:
Never turn off the Epson Stylus NX110 Series during a cleaning cycle or you may damage it. 4. Run a nozzle check to confirm that the print head is clean. You may need to clean the print head up to 4 times. You can also turn off the Epson Stylus NX110 Series and wait at least 6 hours. Then try printing again.
Feb 16, 2010 | Epson Stylus NX115 All-In-One InkJet...
PLSE HELP IM TRYING TO PRINT BUT NOTHINGS HAPPENING, IT IS ALL SET UP
test the printer first, so that we can isolate the issue. print a nozzle check to eliminate the possibility that the nozzles are clogged by dried inks. if nozzle check prints blank page or it printedr but w/ gaps or breaks, do head cleaning
Check the Print Head Nozzles: 1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus CX4400 Series. 3. Hold down the cx4400_ug.1.79.1.jpg Stop button as you press the cx4400_ug.1.79.2.jpg On button to turn the Epson Stylus CX4400 Series back on. Hold down both buttons until the cx4400_ug.1.79.3.jpg On light begins to flash, then release the buttons. cx4400_ug.1.79.4.jpg 4. Check the nozzle check pattern that prints to see if there are gaps in the lines. cx4400_ug.1.79.5.jpg 5. If there are no gaps, the print head is clean and you can continue printing. If there are gaps or the pattern is faint, clean the print head. Clean the Print Head Nozzles: 1. Load a few sheets of plain paper in the sheet feeder. 2. Hold down the cx4400_ug.1.80.1.jpg Stop button for at least 4 seconds to start the cleaning cycle, which lasts around 1 minute. cx4400_ug.1.80.2.jpg The cx4400_ug.1.80.3.jpg On light flashes throughout the cleaning cycle and stays on green when the cycle is finished. Caution:
Never turn off the Epson Stylus CX4400 Series during a cleaning cycle or you may damage it. 3. Run a nozzle check to confirm that the print head is clean. You may need to clean the print head up to 2 times. You can also turn the Epson Stylus CX4400 Series off and wait at least 6 hours. Then try printing again.
Feb 15, 2010 | Epson Stylus DX4450 All-In-One InkJet...
Does not print
***hi there,il be willing to help you on that. ****
the nozzles of the printer might be clogged by dried inks thats why when your printing, its feeding the paper, as if its printing but no inks on the paper. print a nozzle check to see which part or color have clogs, if there are gaps or breaks, do head cleaning untill no more gaps then try printing.
Running a Printer Check
1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 4. Check the nozzle check pattern that prints to see if there are gaps in the lines. nx100_tx100_ug.1.96.5.jpg 5. If there are no gaps, the print head is clean and you can continue printing. If there are gaps or the pattern is faint, clean the print head. If your printouts are unexpectedly light, or dots or lines are missing, you may need to clean the print head. This unclogs the nozzles so they can deliver ink properly. Print head cleaning uses ink, so clean it only if quality declines.
You can also clean the print head by holding down the stop button on the printer for three seconds. (This only works when the red ink light is off.) Run a nozzle check to confirm that the print head is clean.
Caution: When you don’t turn on your printer for a long time, print quality can decline, so turn it on and print a few pages at least once a month to maintain good print quality. ***if my troubleshooting steps are helpful, pls vote for me, i will appreciate it, so that I can be a part of fixya, thanks, Godbless****
Jan 10, 2010 | Epson Stylus NX100 InkJet Printer
Prints gibberish
print a selftest:
turn printer off then hold down the feed button, turn printer on and release feed button whenever it prints something.
pls reply back with info on printout, such as baud rate, parity and other info specially interface, thanks
May 13, 2008 | Epson TM-T88III Thermal Printer
Epson stylus photo 810 won't print
Is it just not printing on the paper and feeding it thru, or will it just not do anything? I need more info?
Dec 05, 2007 | Epson Stylus Photo 810 InkJet Printer
22 people viewed this question
jasbo
jasbo
