Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
GE Profile- Freezer/ Fridge at 56 wont go cooler!
Hello, I went to take out something from the freezer this morning and noticed that everything was warm and misty. I opened the fridge to look at temp- a startling 38 degrees. The fridge temp is 56- i choose the option for cooler and it will go down for like 1 second and reset itself at a warm number. I am panicking- everything is melting. I unplugged the fridge at least 5 times to reset- no luck! we have a ge profile arctica model #PSS29NGNA BB. The freezer temp. is 25 and the fridge temp. is 44. We pulled the fridge out from the wall and cleaned the back of the fridge. We unplugged it to reset it last week and the freezer went down to 5 after a couple days and fridge went down to 38. Since then it goes back up a couple of degrees to where it is now. We had to throw away all the stuff in the freezer. When we turn the setting down they go right back up.
    Guru:
  • 1,342 Answers
More good into HERE
Posted on May 03, 2008
    President:
  • 2,712 Answers
Hello jonkey,
Things to check:
1. Is the condenser fan running and the condenser clean?
The condenser is the black coil like thing at the very bottom of your fridge, right above the floor (unless your refrigerator cools its condenser by natural-convection, in which case, the condenser would be mounted on the back of the refrigerator cabinet and you wouldn’t have a condenser fan). If the condenser fan isn’t running or the condenser is
dirty, you could have a warm fridge.
2. Is the evaporator fan running?
That’s the one in the freezer; you won’t see it but you can hear it. On some models, it stops running when the freezer door is opened, but you’ll hear it when the door is closed. All the cold air is made in the freezer and that fan blows some of it into the fridge. If this isn’t working properly, then you could have a warm fridge.
3. Does the evaporator itself look abnormal? Either too much frost build-up or too little? Too much frost indicates a defrost system failure = easy, inexpensive fix that’s definitely worth doing. Too little frost means either a freon leak or a worn compressor, which can be a bit expensive.
4. Check the thermistor.
The newer GE refrigerators use a thermistor to sense temperature. The motherboard on the back of the refrigerator sends an electrical pulse to the sensor to measure its change in resistance and thus sense the change in temperature of the refrigerated space. If this does not function properly, it could also lead to warm fridges.
You can download a copy of the service manual HERE, if you wish. But these are the 4 main things to look for. If its any one of the 4, don't attempt a Do-It-Yourself job, but get a qualified technician to service the machine.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
    Genius:
  • 3,422 Answers
HI,
All i can say is you will require a tech to get this fixed.
check freezer for frost build up and if fan is blowing, check condenser, make sure its clean, and fan blowing,
check vents in refrig. make sure no blockage, controls should be in the middle setting,
check make sure compressor is running.For this you will require a tech..
Goodluck.
Hi, My Amana fridge this morning stop working and when i checked the freezer i notice little frost, called a repair guy and after he inspect it he said it`s contorl board. around an hour ago I noticed...
Hello Ben, When the technician was there did he take apart the freezer to melt the built up frost,if he did it will work till the frost builds up again, If it wasnt defrosted perhaps jostling the wires has temporarly fixed the problem with the control but real soon it wont work once again
Gene
Aug 05, 2011 | Amana ABB1927DE Bottom Freezer...
The refrigerator and freezer are not getting cold but I can hear the motor running.
Hello there:
If the compressor is running and you can hear it than you are going to have the refrigerant recharged in the unit.
If you continue to run the unit without refrigerant you will end up with the compressor quitting and this you do not want ok?
I hope this has been very helpful for you ok?
best regards michael
Nov 05, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Fridge works but doesn't isn't cooling
I will help but you need to confirm your model number. Is your model the one listed above your post? Let me know, Sea Breeze
Jun 19, 2009 | GE Profile PFS22SBSS Bottom Freezer French...
Freezer then Fridge not cold enough
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Apr 06, 2009 | GE Profile PTS22LCSCC 33" 21.7 Cu. Ft....
GE bottem freeze- not cooling
It is not so much the freezer motor icing up but the drain trough that takes the water from defrost down to the pan.Possibly your drain trough is clogged and needs dethawing and cleaning.
eeggman
Dec 05, 2007 | GE GDS20KBS Bottom Freezer Refrigerator
check freezer for frost build up and if fan is blowing, check condenser, make sure its clean, and fan blowing, check vents in refrig. make sure no blockage, controls should be in the middle setting, check make sure compressor is running
Aug 25, 2007 | GE Profile PSW26P Stainless Steel Side by...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
574 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
