Question about Sony KV-35V36 35" TV
My tv does not come on it is a 1998 sony kv 35v36
    Top Expert:
  • Sony Master
  • 14,553 Answers
Most common problem with this set is Horz. Sweep transistor shorts; also two reg transistors in power supply and .1 ohm resistor near them.
It is sometimes caused when set shuts off and you turn it back on by bad solder connections at Horz. driver transformer.
To be honest, even with generic parts the repair will be well over 150 dollars--set may be too old to make this kind of investment in: some parts for it are no longer available and if you fix you run the risk something else may fail and the part be unavailable etc.
I do not like giving bad news--these were great sets but I am being truthful here.
If this told you something you did not know rate this solution as very helpful as I do it here for free.
SD TECH
Posted on Aug 21, 2010
How can i get picture and sound? the tv is sony trinitron kv-35v36
you need to check for an open resistance at the crt board or a bad potentiometer for screen control.
Feb 12, 2013 | Televison & Video
We have a Sony KV-35V36 TV. Will watching TV and the power just went off. We get no power all all anymore. How do you ge the the fuse on this TV.
The fuse is inside the chassis and likely soldered. Unplug the TV, press and hold the power button for 30 seconds, repeat. Plug it back in and see if that has reset it.
Is the outlet good, or did the power outage trip the breaker?
Apr 22, 2011 | Sony KV-35V36 35" TV
No picture or sound
Often these errors are related to a bad solder joint on the main-pcb or crt-board or what was once just a solder connection failure to the vertical circuit is now a full cascade failure of the vertical output circuit. You can check this by tapping on some parts on these pc's with an isolated screwdriver. Whenever you tap, and the picture goes dark, you're sure it's a bad solder joint and you'll need to re-solder it. Also bad solder connections around the flyback transformer as well as in the vertical sweep circuits. Please If you have no TV repair experience, call in a tech to assist you in this repair. Good Luck and let us know how you made out with this repair.
Best Regards,
Beach TV Repair
Treasure Coast, FL
Jul 04, 2010 | Sony KV-35V36 35" TV
Cant get the cable picture dont know what happened to the cable behind the tv but no picture or sound is present.
Check the F-connector. Unscrew cable from set make sure F-connector has not slid forward on cable and that copper center wire extends out.
Jul 08, 2009 | Sony KV-35V36 35" TV
Blinking/standby timer
Sony Trinitron TV. Worked well last evening. Now picture won't go on. When power is turned on, standby/timer red light flashes, but picture or sound does not work.
Jul 01, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Fuse
Good day.
You need to open your unit and just follow the wire that you are plugging to the power source.
regards,
chris
May 13, 2008 | Sony KV-35V36 35" TV
Sony kv35v36 tv no power
Good day.
It is an internal problem particularly in the power supply section. But you can try checking on the fuse. It may have been blown.
chris
Mar 22, 2008 | Sony KV-35V36 35" TV
SONY Trinitron TV doesnt turn on
TWO Blinks
B+ over current protection (OCP) , unit goes to the standby
mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Nov 09, 2017 | Sony KV-27V40 27" TV
Sony 35inch Trinitron Color TV
Hi. I dont recognise that model number. Take a look at the rear of set & see if there is a chassis number eg AE1. AE1A, AE1B, AE1C, AE2, AE2A, AE5, AE3B, BE2, BE2A,BE3, DE1, F1, FX, These are some of the common older chassis. You say led flashes does it flash 2, 3, 4, 5, times etc then pause then repeat ?
Sep 23, 2007 | Sony KV-35V36 35" TV
Televison & Video Logo
82 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
