Question about Apple Computers & Internet
I need to install a new CD/DVD drive in White 17" intel iMac?
    Genius:
  • 1,456 Answers
Hi there
To replace an iMac Superdrive(which is the same as the CD/DVD drive) you will need to partially disassemble the computer to reach the existing drive.
Shut down the system and unplug all of the cables from the back of the Apple iMac computer.
Set the iMac computer face down on a towel or soft cloth. Remove the three screws along the bottom edge of the iMac case that hold the back panel in place.
Lift the panel upwards and remove it from the iMac computer. Touch any metal object connected to the ground to release the built-up static electricity in your body.
Remove the three screws at the upper-left end of the iMac that hold the Superdrive in place. Lift the Superdrive straight upwards and remove it from the iMac.
Set the replacement Superdrive into the open port on the iMac. Push it down gently until it clicks into place. Attach the three screws to hold the new drive in place.
Set the panel onto the back of the iMac computer and push it down until it clicks into place. Reconnect the three screws at the bottom edge of the case.
Reconnect all of the cables to the back of the iMac computer. Power the computer on and use the Superdrive to ensure it was installed correctly.
Please note that; If you don't ground yourself before touching the internal components of your iMac computer, you can potentially damage the Superdrive or the iMac's logic board.
Only remove the brass colored screws on the inside of the iMac. If you remove the silver screws you will void the warranty provided through Apple.
Posted on Aug 21, 2010
TRYING TO INSTALL MAC OS VIA TARGET DISC MODER
The issue you are having is one in Intel, the other is G3.
This is how to do it. 1. put the cd/dvd into the laptop and restart the laptop in Target mode.
2. connect the laptop to the iMac with a Firewire cable.
3. Start the imac and immediatle hold down the alt/option key.
4. after a moment you will be offered a choice of start-up discs - one of which will be the CD/dvd in the laptop.
5. Start from the CD and then when asked, select the iMac drive as the destination. This ensures that the imac loads the correct version of the OS for its processor. Should work without a hitch.
Mar 03, 2012 | Apple iMac G5 Desktop
My sreen on my imac 17' intel the sreen have a big white bar i need i new sreen for this imac where can i find one
Before buying one, call Apple (1-800-My-Apple) I just got my screen on my iMac (out of warranty and about the same vintage) replaced for free. There is a Special Warranty for this problem. It my not be the same for yours, but try.
Sep 10, 2010 | Apple iMac 17" Desktop
Imac intel dual core dvd drive will not mountunable to load a cd or dvd it keep ejecting them. I have tried to boot with the OSX CD, but still it eject it out. I notice the problem when I tried to...
Installing Parallels should not change the way your optical drive works.
Try resetting the SMC as per the following article:
http://support.apple.com/kb/HT3964
If that doesn't work, try resetting the PRAM:
http://support.apple.com/kb/ht1379
If these do not resolve the issue you will likely need repair.
Jun 20, 2010 | Apple iMac Z0CY Desktop
Just got an lg ge20 not working on mac
I wish I could tell you that your Mac is compatible with the LG GE20 20X DVD Burner but unfortunately it is not.
Here are the system requirements for this burner
LG GE20 20X DVD Burner Technical Specifications
The CD included is not the only item that is not compatible with the Mac, it is also the DVD burner itself. It is only windows compatible I'm afraid.
However, I do know that the Apple.com online store, has a comparable DVD+RW burner, the
LaCie 22x d2 DVD+RW with LightScribe
which will work with your iMac.
This is a genuine incompatibility issue.
If you had an Intel iMac, there actually is a workaround process where virtual machine software, like VMWare Fusion or Parallels, could be installed, with a version of Windows XP, Vista, or 7, display as a 2nd terminal within a Mac OS X desktop.
What's makes this effective, is that the LG GE20 could work with a windows virtual machine and because software like VMWare for example, can share devices, including optical CD/DVD drives, the Mac could share that drive with the windows virtual machine.
But since you do not have an Intel iMac, unless I am reading the description of your Mac computer(Apple iMAC Mac Notebook) incorrectly, the LaCie burner information, I provided above, would be the best option for your model of iMac.
Again, if I have described your model of Mac incorrectly let me know and I will be glad to assist further.
Regards,
-Mactechtrainer
Feb 01, 2010 | Apple iMac Notebook
I have an intel based iMac Core 2 duo. I replaced
The gray wire is one of the antennae leads to the wireless card on the motherboard. The other lead is either white or black. Or the card may have three leads for the "N" speed. Wireless cards have white, black and gray wires for the antennae.
Jan 07, 2010 | Apple iMac 17" MA199LLA Desktop
CD burnber
I've never used this drive but there are two references to a Macbook Air and iMac user having success with this drive on amazon. Here's a link <http://www.amazon.com/Sony-DRXS70U-External-Portable-Slim-Line/dp/B001BSM954>. Just search on the page for "Mac". Good luck.
Dec 31, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Apple imac HDD install
Pretty sure any size, but they use 3.5" SATA drives, not 2.5 laptop drives. iMacs only use desktop drives so get as big as you want, or can afford with a big cache. The 17 imacs are hard to get into so search the internet on how to get in and replace it and to put the heat shield back in right. Be careful not to break the clips.
Sep 26, 2009 | Apple iMac 17" MA199LLA Desktop
Using a MacBook as an external HD
Try reading here: Apple
Even though the article refers to Leopard, it should work for Tiger.
Here is the catch: The iMac needs a FireWire port
Mar 26, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Computers & Internet Logo
150 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
