Question about Gateway Computers & Internet
Gateway zx6800-003 stuck cd no response from button, or eject program, no external hole for manual ejection. how do I get the cd out? thank you
Shutdown with a restart and as the machine is restarting, continue to press the eject button. Just did it and it works!
Posted on Jan 11, 2013
  • ctlyn Jan 11, 2013
Dvd drive door stuck
In case you're not able to eject the disc using the eject button, you can try right clicking on the CD/DVD drive under 'My Computer' and clicking on eject. If that fails as well, you can try to eject the disc manually by pushing a straightened paper clip or a pin into the tiny hole on front of the CD/DVD drive. You should be able to eject it using the last method.
GuruAid.com
May 31, 2014 | Gateway 830GM PC Desktop
Tip
Cdrom drive can not eject / Cdrom is stuck
How To Eject CD from CD-ROM drive if it is Stuck :
If you have a CD into CD-ROM drive and it is stuck and you are trying to eject tray of CDROM by pressing the eject button or windows eject command but CD won't eject as there is no command to eject a stuck compact disc from the CDROM drive then this article is for you.
Step 1: Switch off the computer.
5573fa0.jpgStep 2. On the front of the CD-ROM drive you may find a small hole called Emergency Eject hole below the tray of CD-ROM drive . Take a long pin around 3 inch, (also known as CD ejector) it must be hard enough, insert this pin inside the hole and push a little. The CD tray will slightly move to out.
Step 3: Now you may manually pull the tray and you are done. You have successfully ejected the stucked CD.
Step 4: Switch on the computer and you may work as usual.
Thanks
Proton
on May 12, 2010 | Computers & Internet
Loaded a cd to upgrade firmware, firmware would not load. eject button would not eject. read manual, says to push eject at the same time you plug in the electric cord,still would not eject. Any...
Please try in this way.
Disconnect power.
Connect power back, and keep REPEATEDLY pressing the eject button while you connect. If still no ject press power on button while you keep hitting the ehect button. You need to press eject on the unit, do not use the remote.
If that does not work, then the unit must be taken apart.
Dec 09, 2010 | Cameras
It doesn't open by pushing the button and I can't find a hole to manually open it. there is a hole for the cd drive underneath the dvd drive.
Try opening "My Computer" and right click on the drive - choose "Eject"
Be patient if it doesnt open straight away, if you press the button multiple times, or choose eject many times it can get stuck in a cycle of open/close routines.
Also try rebooting and then the 'my computer' eject way again
Oct 31, 2010 | Gateway 420GR PC Desktop
How do i get a stuck cd out of my dell laptop
There should be a tiny hole next to the eject button:
  • Straighten out a paper clip and push it into the little hole until you feel it "make contact"
  • Then, give it some "encouragement" (push it in farther) -- once you've pushed the paper clip in far enough, the CD drive should then manually eject itself
Hope that helps!
j
May 20, 2010 | Gateway MT3705 Notebook
How do i eject a stuck cd from gateway one 710 series I have tried the eject button on the keyboard but will not give it up...
Have you tried the eject button from the tray? If all that you need is a tool to eject the tray without touching the tower, I suggest you to go to this link and download the Eject-CD freeware runtime file EjectCD.exe - approx 30kB. Alternative if your tray is locked and can not open with the above methods, you have to locate a small hole in the front panel of the tray and put into that hole something like a connector (for papers) or a strong wire in order to push the internal system to open.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Apr 08, 2010 | Gateway ONE GZ7108 All-in-One Desktop PC
Drawer on cd drive won't open model is gateway digital media center gm5260
There are a couple of possibilities here, first it could just be stuck. If you hit the eject button and light flashes, there may be a stuck factor here. Look for the very small hole on the door by the eject button and push an opened paperclip in the hole, this will trigger the manual eject mechanism. With the tray opened feel the way the tray moves along its geared slide. If it seems too tight or it sticks there maybe something mechanical that has happened to it. Try to close it again and try the eject button and see if it will cycle. Also try to right click on the drive itself (Open "My Computer" to view the drives) and click on "Eject" and see if it triggers the command.
Jan 30, 2010 | Gateway GM5260 PC Desktop
Cd stuck inside laptop
There is a small hole, usually near the eject button. Unbend a paper clip and carefully push the paper clip into the hole, try to keep it straight. drive should pop right out.
Feb 20, 2009 | Gateway MT3705 Notebook
I have a Gateway 300x Micro-Tower case circa 2002 and I can not open the case, without breaking it. I'm trying to install a new audio card and can't get at the 300x innards. Help!
Most of these towers are vertical style, therefore the big button is just to the left of the Gateway symbol. Push it in and pull the left panel away from the case.
Jan 11, 2009 | Computers & Internet
My cd rom is stuck, when i click eject button it won't open.
There should be a small hole in the front, use a paper clip and push into the hole to eject tray mannualy. The cause of the tray not ejecting is that the belt from the motor that ejects the tray is worn, need to change it.cheers.
Dec 01, 2008 | Gateway (5502156) CD-ROM Drive
Computers & Internet Logo
474 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
