Question about Celestron NexStar 114GT (269 x 114mm) Telescope
Hi, Bought a used telescope with a GT mount. The polar adjustment will not go below 46 degrees without binding. The binding screw only turns 1/4 turn in each direction and appears to be binding the movement to lower than 46 degrees.
  • 3,186 Answers
This scope does NOT need to be polar aligned --
Here is the manual:
http://www.celestron.com/c3/images/files/downloads/1228334587_nexstargt.pdf
This is an ALT AZ goto scope. Read the manual above. You use the hand controller to move the scope in Altitude and Azimuth(left-right).
You must align it on 2 stars in order for it to has successful gotos.
Posted on Aug 22, 2010
Bought it used and don't know how to use it. no instrustions
good statement but you forgot a question along with details like what it is ,make , model year
ask the question again and include those facts
Jan 17, 2016 | Meade Polaris 114EQ-D (36 x 114mm)...
Tip
You Just Bought an EQUATORIAL Telescope Mount!
Even though we warned you not to do this, you bought one anyway! Beginners should never buy an EQ telescope mount as their first telescope. It's too late now; so I guess we will need to teach you how to use it!
Equatorial mounts move in a way that seems not to very intuitive. Unlike the easy Alt AZ mount which moves up and down and left and right, the EQ mounted telescope seems to move in TWO dissimilar directions at the same time.
Additionally you must first polar align the mount on the North star Polaris before you can use it. SEE! we told you not to buy it!
Here are the steps to roughly polar align the telescope so you can use it. If it is motorized the single Right Ascension motor will keep the sky object inside the eyepiece for long periods of time. If you do not have a Right Ascension motor, the slow motion RA knob can be slowly turned to keep the sky object centered in the eyepiece.
Begin by leveling the mount and tripod. Move the entire mount and tripod so it is pointing roughly to North, as close as possible using the steps below or a compass. Don't forget to adjust for your magnetic deviation. My location's compass reading is about 5 degrees away from true North. This is called magnetic deviation. You can find your location's deviation on the internet. Then proceed with the steps below.
First, adjust the Declination to the latitude for your observing site. Declination is the angle that the scope is pointing UP, and it's the same as your latitude. For example Dallas, Texas is about 32 degrees North latitude, adjust the scope so the small indicator reads 32 degrees. By the way, the North star in Dallas, TX is about 32 degrees above the horizon. Your latitude matches the elevation of Polaris (the North star) above the horizon.
Second, either look through the polar alignment scope buried in the axis of the telescope mount, or look along side the axis, and get the star Polaris lined up in the cross-hair of the polar alignment scope, or as best you can by looking along the side of the mount axis, or lining it up using your compass.. This will put the scope to within about 3/4 of 1 degree of the TRUE North celestial sphere. This is good enough for VISUAL observation, but NOT good enough to do astro-photography..
Adjust the DECLINATION up or down, and move the entire mount left or right until you can see Polaris as indicated above, or it is lined up as close as possible.
Now you are roughly polar aligned. Now you can move the tube around by loosening the Right Ascension lock, and or the Declination lock until your sky object appears in the small finder scope mounted on top of the main telescope tube.(DO NOT MOVE THE MOUNT, and the counter weight should never be higher than the telescope tube) Lock down the scope in both axis and use the fine adjustment RA and DEC knobs to center the target. Again, DO NOT move the mount or tripod. The mount should still be pointing at Polaris.
This web site illustrates this procedure:
http://www.astronomy.net/articles/4/polaralign.html
also this web site
http://www.telescopes.com/telescopes/polaralignmentarticle.cfm
You should be able to keep an object within the field of view of the eyepiece by slowing turning the Right Ascension slow motion control knob-------- IF you are actually accurately polar aligned. Small adjustments may also be needed with the DEC slow motion knob since you are not exactly polar aligned using this rough alignment technique.
However it can be used successfully for visual observation. Your scope will now track the motion of the stars as they move across the sky.
Hope that helps you!
Clear Skies!
TelescopeMan
www.telescopeman.tumblr.com
on Dec 29, 2009 | Optics
Tip
Frequently Asked FIXYA Questions about Telescope
Here are the most frequently asked questions in the Telescope topic on Fixya.
1. Everything is upside down when I look through the telescope.
Yes, all astronomical telescopes have upside down images. There is no up or down in space! AND- to erect the image would take more glass in the light path making those dim sky objects harder to see. You can buy an "erecting diagonal" for terrestrial viewing.
2. I just purchased this XYZ Telescope, It is a 60mm with 575 power magnification. I cannot see anything through the telescope!
First, this scope is 60mm about the same aperture as a pair of binoculars! They LIED TO YOU! The maximum magnification of any telescope is about 50 times aperture. Your scope is about 2 inches, so 100 power is the maximum you can achieve in PERFECT sky conditions! Magnification is the least important factor -- LIGHT GATHERING is the most important factor along with quality optics.
All things being equal the BIGGER the hole in the telescope the MORE you can see. We say, "Aperture Rules!". They LIED to you when they said it was 575 power magnification. Sorry --------- :(
So put the eyepiece with the largest number written on it into the telescope. This is your LOWEST magnification. Throw away the 3x barlow they gave you with the telescope as you will never be able to use it to TRIPLE the magnification of the standard eyepieces. Next time do not buy any telescope that advertises magnification.
3. I am looking for a manual for my telescope and cannot find one.
First, you probably will NOT find a manual for your small telescope. However Meade maintains all their manuals here: Look under REFRACTOR or REFLECTOR heading:
http://www.meade.com/manuals/index.html
and Bushnell has a web site here:
http://www.opticsplanet.net/bushnell-warranty.html
They all assemble in a similar fashion, depending on the type and the mount. REFRACTOR style telescopes have a lens in the front, usually a diagonal in the back with an eyepiece stuck into the diagonal.
A Reflector has a mirror on the bottom, and the focuser near the top of the tube. POINT the focuser end toward the sky. Take off the lens cap, and go outside during the daytime and practice focusing on a distant object until you can easily do this. DO NOT use the 2x barlow if you have one, just use the eyepiece with the largest number written on it until you learn how to focus.
Probably what you really mean is that you just assembled the scope and you DO NOT KNOW what to do next. You have zero knowledge of the night sky. You don't realize that the bright star outside (along the ecliptic) is actually a PLANET! or that the Andromeda Galaxy is actually visible without a telescope from a dark sky site!
You don't need a manual, you need to buy several Astronomy books like "Turn Left at Orion" and "Nightwatch:" and start reading. Both are available on amazon.com. Again your local Astronomy club could help you learn the sky, and how to use your telescope. You can also download a free monthly star chart here:
http://www.skymaps.com/downloads.html
Start reading Astronomy links on the internet and join the free (with registration) forum on:
www.cloudynights.com
4. I just bought this XYZ telescope and the focus knob fell off and broke. Or-- a screw is missing, or the tripod leg broke! What do I do now!
Take it back to where you bought it and stop buying junk $79 telescopes from a department store. For a simple screw or nut visit your local well stocked hardware store for a replacement. If the tripod is broken it's probably NOT economically wise to replace the tripod. Most tripods are more expensive than your entire telescope! Usually around $100- $150 dollars.
Meade, Bushnell, and Celestron have customer service contact web sites listed below; if you own these brands those companies may be able to sell you a replacement part. Contact them!
http://www.meade.com/support/index.html MEADE
http://www.opticsplanet.net/bushnell-warranty.html BUSHNELL
http://www.celestron.com/c3/home.php
Here are FOUR good internet retailers that sell REAL telescopes and accessories.
http://www.optcorp.com/
http://www.telescope.com/control/main/
http://www.agenaastro.com/
http://www.astronomics.com/main/Telescopes_and_Telescope_Accessories.asp/catalog_name/Astronomics/category_name/Home
5. I just bought this EQUATORIAL mounted telescope. I cannot figure out how to point it? Where is Polaris?
Beginners should NEVER buy an EQ mount as their first telescope. Many retailers sell these mounts. Usually the mount is too small for the telescope and will cause the image to shake whenever you touch the scope.
AND--- they must be POLAR ALIGNED to work properly. You do know how to polar align an equatorial mount using the star Polaris??? That's what I thought- NO you don't know how to do this!
Beginners should start-out with an easy to operate mount like the ones listed below with up-down, left-right movements. Since you went and bought one anyway, READ my TIP in my profile about how to use an Equatorial mounted telescope.
http://www.telescope.com/control/product/~category_id=classicdobs/~pcategory=dobsonians/~product_id=08942
Check out this web site for a description of the different types of telescopes.
http://www.texasastro.org/telescope.php
6. How far can I see with my telescope.
I always chuckle when I see this question. Did you see the SUN today? If you did you were looking across 93 MILLION miles of outer space! WITHOUT a telescope! AND-- you can see the Andromeda Galaxy, without a telescope, which is 2.5 MILLION light years away from a dark sky observing site if you know exactly where to look.
A 6 inch or 8 inch Dobsonian reflector can show you thousands of sky objects from a dark sky observing site. However you must point the telescope EXACTLY at the sky object to see it. Most appear smaller than the tip of your finger held at arms length. Telescopes have VERY small fields of view.
7. The image in my small finder scope is not the same as the main telescope?
You must align the finder scope with the main telescope. Put the main telescope on a bright star or distant object. Without moving the telescope adjust the finder "cross-hair" and center the same object using the adjusting screws on the finder scope.
8. I can find the moon and it looks great, but I cannot find anything else!
Yes, sky objects are very tiny, and many are very dim. The scope must be pointed directly at them to see them and your eyes should be dark adapted. So turn off any lights you can and do not LOOK at any white light source for at least 20 minutes or you will immediately loose your dark adapted eyes. That's why you should buy a red flashlight. RED does not affect your night vision.
You also need to learn the sky using a small star chart so you can FIND objects. Download this free monthly star chart:
www.skymaps.com
9. I opened up my eyepiece to clean it. How do I put it back together!
First, NEVER disassemble an eyepiece. Most manufacturers void the warranty when you do this.
Second, only the front outside lens should ever need cleaning, not the internal surfaces.
You can try to put the "flat" sides of the lenses together and try that for simple eyepiece types. However, with more complicated designs having 3 or more internal lens elements we really cannot help you. Send it back to the manufacturer if you can, and NEVER EVER take one apart again!
Read this to learn how to clean optical surfaces:
http://www.televue.com/engine/page.asp?ID=143
10. Where can I buy a new eyepiece for my telescope?
There are many on-line retailers that sell eyepieces. There may also be a regular retail Astronomy Shop if you live in a large city.
Eyepieces come in 3 sizes. .965, 1.25, and 2 inch sizes. Most amateur telescopes will take the 1.25 inch size, some may also take the 2 inch size. Measure the hole at the focuser and buy the appropriate size. Here are several on-line retailers that sell eyepieces. A Plossl type eyepiece will work just fine for most telescopes. Many "toy" department store telescopes can only use the .965 size. Just one more reason why you should not buy a department store telescope.
http://www.optcorp.com/category.aspx?uid=30
http://www.telescope.com/control/telescope-eyepieces
If you cannot return the telescope then READ my Equatorial "TIP" article on my Profile page. It has instructions for polar aligning an equatorial mount. Polaris is the last star in the handle of the LITTLE dipper -- in the Constellation Ursa Minor.
See this web site to learn how to find Polaris- The North Star:
http://www-istp.gsfc.nasa.gov/stargaze/Spolaris.htm
Clear Skies!
TelescopeMan
TelescopeMan RSS Link to his Astronomy podcasts
on Dec 27, 2009 | Optics
Manual for TwinStar 1000mm focal length telescope and equatorial mount
Equatorial mounts need to be polar aligned to work correctly. Once the scope is polar aligned (see manual or look online for polar alignment instructions), turn on the RA motor. Loosen your RA and DEC locks and find a object you want to view, The motor should keep the object in view for a while (depends on how good the motor tracks and how good your polar alignment is.) Spending 10 minutes polar alignment on my C8 keeps the object in view for about an hour without adjustment.
Dec 16, 2011 | Celestron Optics
How to adjust and use this telescope?
If it is like the picture next to your question-- this is a reflectro style telescope on an equatorial mount. The mount must be polar aligned in order to be used.
See this:
http://www.optcorp.com/product.aspx?pid=3050
And read my equatorial mount TIP on my profile page.
Jan 01, 2011 | Galileo (G118DX) Telescope
How do i set up a tasco telescope
Here is the manual:
http://www.tasco.com/products/manuals/46060675_TML-722.pdf
This is a very small refractor on an equatorial mount. The mount must be POLAR aligned before you can use it. We NEVER recommend this to a beginner.
However you bought one anyway! SO--- go to my profile page and read my TIPS on polar aligning an EQ mount. Several of the other TIPS will help you.
Also read this:
and this about polar aligning an EQ mount-
http://www.astro-tom.com/tips_and_advice/precision_polar_alignment.htm
Aug 21, 2010 | Tasco Astronomical 302675 Telescope
Celestron 114EQ polar setting and Equatorial settings
The ALTITUDE adjustment matches your LATITUDE. I live at 32.5 degrees North latitude. So the scope is first adjusted to 32.5 degrees UP.
Then the Right Ascension is point to Polaris the North star by MOVING the entire scope and mount.
Read my Equatorial mount TIP on my profile page, and read this web site.
http://www.astro-tom.com/tips_and_advice/precision_polar_alignment.htm#Rough%20Polar%20Alignment
May 05, 2010 | Celestron PowerSeeker 114 EQ Telescope
Polar alignment with cg5 mount in the tropics
Wait what? You just have to remove the front bracket for the alt screw and you can go lower than 30 degrees.
Feb 21, 2010 | Celestron CG-5 Mount Telescope
I am struggling to set the telescope us as the
Is it like THIS telescope?
http://www.opticsplanet.net/konus-knonusmotor-130-telescope-1786.html
The focuser mechanism is at the FRONT end of the telescope. The Mirror is in the back-end or bottom of the telescope. This scope is on an equitorial mount, which means it must be POLAR ALIGNED in order to work. You can get a rough polar alignment by using the star Polaris (the North star).
We never recommend an EQ mount to beginners. Polar alignment introduces an additional beginner frustration with using the telescope. Read these web sites to get an idea of polar aligning a telescope.
Their are TWO knobs on the telescope that control Right Ascention and Declination movement. Declination IS your latitude, so the angle must be set to where you live. I am at latitude 32 degrees N --- so the angle is 32 degrees, which is where Polaris is above the horizon.
Read these:
http://www.tucsonastronomy.org/observing-resources/Polar%20Alignment.pdf
Dec 04, 2009 | Konusmotor 1796 (200 x 130mm) Telescope
Aoc monitor 7Vlr
Dear Jamez,
Please fix properly your equitorial mount screw.I think some screw is loos.
Thanks.
Dhananjay
Aug 24, 2008 | Bushnell Tasco Telescope Galaxsee 675x60mm...
Celestron NexStar 114GT (269 x 114mm) Telescope Logo
123 people viewed this question
Top Celestron Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Vernon Taylor
Lawrence Oravetz
Are you a Celestron Optic Expert? Answer questions, earn points and help others
