Question about Roxio Creator 2010 Full Version for PC (244000)
Trying to build image file from dvd creation, after clicking on the burn button , deselecting Burn to disc and checking the box to create disk image file, then clicking on the burn button, it goes through all the steps open project , render movie, rendor menu just fine right before it creates the image file , get the following error "Project_BuildToDevice() AuthorScript call failed. Error while  Writing Format
SOURCE: i have purchased roxio easy cd and dvd burning software
i already tried that site. it didnt help me much.
Posted on Jan 28, 2008
  • 108 Answers
SOURCE: burning a dvd
You could have a variety of problems but these are the most likely...a) you are missing a driver, b) your software is corrupt, c) it may not be compatible (without an update) with your operating system. Personally I would simply try another burner....Freewarefiles.com and many other sites have them...if you filter your results by "free" on cnet downloads you can find one that thousands of folks....if not millions....are happy with. Try that....why...BECAUSE it's a lot less hassle and more than likely you will find something that works...by the way if you are running XP or later you have burn capability built in. Hope this helps..Tango
Posted on Feb 05, 2008
SOURCE: I am using Roxio Easy
Try uninstalling IE7.
Posted on Apr 25, 2008
  • 73 Answers
SOURCE: roxio dvd disk type doesn't match project type
Check the following parameters
- Type of disk--> it must be a DVD RW disk (Read and write), if the media is only DVD R, you can't burn it
- Your DVD driver--> Check if it accepts DVD RW(-) or DVD RW(+) or both. With this information, check if the media matches the driver capability
- Roxio settings--> In the Main Menu select--> Disc--> Disk information--> confirm that the right driver is selected (drive D or E or the letter your computer uses for the DVD driver)
Posted on Nov 07, 2008
20YrsCompExp
  • 227 Answers
SOURCE: will not complete movie burn to dvd ''write error - Hardware error
In the program temp file path has enough space and Your drive should indicate (written on the front the drive door) a -R or +R make sure you are using -R or +R DVDs. also make sure you finished product does NOT EXCEED the capacity of the given media. They all hold diferent amounts. Multi layer discs, DUAL layer, High capicity.... Which should also be indicated on the drive door!!!! Hope this helps
Posted on Mar 27, 2009
I have benq combo cb523b my problem is combo not writ dvd
Hi Dear,
First Install the burning software and then try to write the DVD, may you have try to burn without burning software.
Click hear and get the Burning software, see the instruction of mention below.
Data Compilations
  • Burn, backup or copy your files to CD, DVD or Blu-ray Discs.
    Supports recording from command-line and BAT scripts for automating routine actions.
    Supports CD-R/RW, DVD-R/RW, DVD+R/RW, BD-R/RE and DVD-RAM media, including high-capacity double-layer media.
    Supports UDF (Universal Disc Format 1.02-2.60), Bridge and ISO9660 (Level 1-3, Romeo), including Joliet Unicode extensions.
  • Create Bootable CD or DVD. Use it as a very big floppy boot disc for recovery purposes.
    El Torito creation support with advanced options: emulation type, sectors, platform, load segment and boot message.
  • Append or update Multisession discs.
Multimedia Compilations
  • Create Audio CDs. Play a CD on your traditional CD player or car stereo.
    Supports MP3, WAV, WMA, OGG, M4A, AAC and FLAC audio formats and M3U playlists.
    Supports title and track CD-Text, including Unicode.
  • Create DVD-Video discs and MP3 CDs/DVDs.
Disc images
  • Make and burn standard or boot disc images.
    Supports ISO and CUE/BIN image files.
  • Copy disc to ISO image. This feature can be used for disc backup, as well as for disc copying.
Utilities
  • Erase re-writable CD, DVD or Blu-ray discs.
Thanks
Mar 31, 2012 | Computers & Internet
When attempting to burn project in MY DVD8 an error appears 800402007 while encoding. I am therefor unable to burn disc
Generally, defragmenting your hard disk will resolve this issue. To defragment your computer:
  1. Go to Start--> Programs --> Accessories --> System Tools --> Disk Defragmenter.
  2. When the Disk Defragmenter window opens, choose Defragment.
If defragmentation doesn't resolve the issue, burn your project as a data file, and then burn your project as a data disc using Disc Copier or Creator Classic. To create a disc image/data file:
  1. After clicking the Burn button, the Burn Project window opens.
  2. You have two data burning options:
    • Image file - this option will save your project as an .ISO file. To burn this file you will need to use the Burn Image option in Creator's Copy section.
    • Folder Set - burning a folder set will create a Video_TS folder that you can burn using Creator Classic. Burning a folder set to DVD will create a fully functional DVD. Do NOT rename the Video_TS folder other wise it will not play! Simply place it in a folder that is the name of your project if you need to keep track.
      Tip: Either of the above options are a great way to not only back up your projects, but make multiple copies to reduce encoding time!
Mar 03, 2008 | Televison & Video
Tip
Ways to burn Discs with Finder and Disk Utility in Mac (versions OS X 10.4 -...
Without purchasing new disc burning software, there are actually 3 ways to burn CDs & DVDs in your Mac OS X system (Mac OS X 10.3-10.6)
There are methods using Finder and Disk Utility.
Both are easy to do and when set up to use will have you burning music, video, data, and image files (ISO) to CDs or DVDs in no time at all.
BURNING DISKS WITH FINDER
1.) Create a Burn folder and burn a CD/DVD
* The easiest way to burn a disc with Finder is to create a Burn folder with Finder. Here's how you do that:
* Click on any blank space on your desktop and in an instant, Finder will appear on the Apple menu bar next to the Apple menu icon.
• Click on File and select from the drop down menu
* This distinctive folder will now appear on your Desktop
* Now insert a blank CD or DVD and in moments, you will see this window pop up:
• Just click the OK button.
* In a few more moments
on your desktop, you will see this Untitled DVD (or "CD: for CD-ROM Disks) icon:
• Now you can either drag and drop files into the folder, or just double-click the folder and also drag and drop files into the open Burn Folder window
* If you notice, each file you drag (or copy and paste) into the Burn Folder window will have a small curved arrow at the bottom left corner of the file.
That is merely a designation that the file is a image of the actual file and ready to be burned to the CD or DVD you use.
* Notice the Burn button (highlighted in the red box). This is the button you will press, to commence the burn (or copying) of the data you have placed in the burn folder to be copied to disk.
• Click the Burn button, name your disk and that is all it takes. When the process is complete, you will now see a formerly Untitled Disk icon on your desktop replaced with a "Your_new_disc_name" DVD.
(Additional Note: If you wish, you can also simply bypass creating a Burn folder, insert a blank CD or DVD and simply drag and drop or copy and paste files into the open window of the Untitled CD as well.)
BURNING A DISC WITH DISK UTILITY
There are actually two ways to burn data to an DVD or CD with Disk Utility:
1.) Burn a disk in Disk Utility
* Simply open Disk Utility by either clicking anywhere on a blank space on your Desktop window and Finder will appear near your Apple menu, select Go >Utilities and that will take you to the Utilities Folder which is the default location of the Disk Utility application.
* Or you can click the Finder icon on your Dock, open a new Finder window, click on "Applications" listed in the side window and select the Utilities folder
* Either way, you will land here.
• Insert your CD or DVD.
* Once you open Disk Utility, you will see this main window
* Now all you need to do is click the "Burn" button located on the Disk Utility toolbar.
* For an example, I am striving to burn a copy of my Quicken .dmg file to CD.
* Once I have selected the file, then I click the Burn button located at the bottom right corner of the Finder window.
* Follow the onscreen instructions to start the burn process.
2. Creating a multi-session disk using Disk Utility:
Now it is known, that one cannot burn more than once with a single CD-R disc, but it can be done as provide from the knowledge base of Apple support:
  • In the Finder, create a folder for the session and drag the items you want to burn into the folder.
  • In Disk Utility, choose File > New > "Disk Image fromFolder." Then select the folder you created in the dialog and clickOpen.
  • Type a name for the image, choose a disk format, and click Save. Mac OS Extended allows burning the disc more than once. Formats such as ISO allow burning the disc only once.
  • When the disk image is complete, select it in the Disk Utility list and choose images > Burn or click Burn in the toolbar.
  • Insert a blank CD in the optical drive.
  • Select the "Leave disc appendable" checkbox. If you don't see this option, click the triangle in the top-right corner.
  • Click Burn.
What is really nice about this CD/DVD burn feature of DIsk Utility, is that now you can come back later and add more files to the same CD without having to waste all the space on a new CD-R.
This especially useful, if the image file you are need to burn is small in capacity. Just pop the previously burned CD in your drive and add that file or files until that CD is filled to capacity- that is all it takes.
So there you have it, a quick tip on how to use Finder and Disk Utility to burn any data to your CD and DVDs.
Thanks for viewing my Mac OS X tip from FixYa Support. Stay tuned for more tips for how to make the most of your Mac OS X systems!
Regards,
-Mactechtrainer
on Feb 23, 2010 | Computers & Internet
Tip
Make osx dvd image in mac
Making a DVD Image...............
Step 1. Insert the retail Mac OS X Install DVD into your drive.
Step 2. Launch Disk Utility (Applications > Utilities).
Step 3. In Disk Utility, you will notice a white pane on the left hand side. In the pane, select the Mac OS X Install DVD by clicking on it once.
Step 4. Click New Image on the Disk Utility toolbar.
Step 5. A dialog box will appear. Give the new image a name. I used 'Mac OS X Install DVD'. Select the destination where you wish to save it. LeaveImage Format at Compressed (default) and Encryption at None (default).
Step 6. Click Save to begin creating the image.
Step 7. Once your image has been created DO NOT mount it. Leave the image alone and proceed to the next section.
Burning the Image...................
Step 1. Launch Disk Utility (Applications > Utilities).
Step 2. Click Burn on the Disk Utility toolbar (upper left).
Step 3. Navigate to where you saved the DVD image created in the previous section. Click on the image file, then click the Burn button. Do not drag and drop the image file into Disk Utility during this step.
Step5. Insert a DVD when prompted and proceed to Burn it. (use good quality media)
Using these exact steps I was successfully able to create a personal backup copy of Mac OS X Tiger. I hope this tutorial helps. Enjoy the newfound features in Tiger!
on Feb 05, 2010 | Computers & Internet
I cant burn my music onto CDs and my computer tells me i dont have a cd burning software when i should have one
you could use this burnaware its totally free if you dont like it just uninstall it also there are plenty of free burning sofware cnetdownload.com or majorgeeks
http://www.majorgeeks.com/BurnAware_Free_d5839.html
BurnAware Free is one of the most popular free CD, DVD, Blu-ray Disc burning software available for Windows.
Using this program you can easily create and burn Audio and MP3 CD, Data and DVD-Video disc, ISO and Cue Image,
erase or format rewritable disc, copy your CD or DVD to ISO image.
http://www.majorgeeks.com/CDBurnerXP_d4242.html
http://download.cnet.com/active-iso-burner/3000-2646_4-10602452.html
Active ISO Burner will allow you to burn an ISO image file to CD-R, CD-RW, DVD-R, DVD+R, DVD+R DL(Dual Layer), DVD-RW and DVD+RW (including double layer, DL). Active@ ISO Burner software accepts command line parameters to automate ISO images burning process.
http://download.cnet.com/instant-cd-dvd-burner/3000-2646_4-10393316.html
Burn audio, video, and data CDs/DVDs and create and burn ISO files. Instant CD & DVD Burner is the ideal choice for anyone looking for a simple but full featured CD/DVD burner. Build and burn ISO files on the fly and compile all kinds of audio, video, and data CDs and DVDs from any kind of file (MP3, WAV, AVI, MPEG, DIVX, XVID). Instant CD & DVD Burner supports all major drives including CD-R, CD-RW, DVD-R, DVD+R, DVD-RW, DVD+RW, and DVD-RAM (SCSI, IDE, EIDE, and USB 1.0 and 2.0).
http://download.cnet.com/burn4free-cd-and-dvd/3000-2646_4-10217894.html
Burn4Free CD and DVD is a burning solution that's compatible with more than 3,000 DVD, Blu-ray and CD burners. Burn data and audio from different file types (WAV, WMA, MP3, OGG, FLAC, WavPack, and CDA). Burn and save ISO files, open and save your project to disk, verify content, print compilations, copy DVD, copy BLU RAY and import your audio compilation from M3U and ASX playlists. The drives supported include dual-layer DVD, CD-R, CD-RW, DVD-R, DVD+R, DVD-RW, DVD+RW, and DVD-RAM, BD-R, BD-RE (SCSI, IDE, EIDE, and USB 1.0 and 2.0).
http://download.cnet.com/burnaware-free/3000-2646_4-10878661.html?tag=mncol;8
BurnAware Free is a full-fledged disc burning tool - fast, lightweight, feature-packed and, most importantly, 100% free. The program burns all types of CD, DVD and Blu-Ray discs containing data, digital photos, music and video. With BurnAware Free, you will be able to create bootable or multi session CDs and DVDs, high-quality audio CDs from your collection of MP3, WAV, WMA, OGG, M4A, AAC and FLAC files, burn disc images, copy discs to backup ISO images and do a whole lot more.
http://download.cnet.com/Ashampoo-Burning-Studio-Free/3000-2646_4-10776287.html
Multi-disc file backup and restore on CDs, DVDs and Blu-ray discs; create compressed backup archives with powerful password protection; split archives automatically across multiple CDs, DVDs or Blu-ray discs; restore archive contents to their original locations; integrated Audio CD ripper store your audio tracks as WMA or WAV files; new option for setting the number of copies you want to burn (available for all disc formats); discs can now be verified immediately without being ejected first (if the drive supports this feature); numerous other small improvements that make the program easier to use and more effective; burn files and folders on data CDs/DVDs/Blu-ray discs; burn Audio CDs from WAV, MP3, FLAC, WMA and Ogg Vorbis files; burn MP3-CDs from your MP3 files; burn Video DVD, Video CD (VCD) or Super Video CD (S-VCD); create and burn CD/DVD/Blu-ray disc images; burn speed and other options can all be set automatically.
http://download.cnet.com/Macrium-Reflect-Free/3000-2242_4-10845728.html
Macrium Reflect Free Edition. An award winning disk imaging solution for free. A complete disaster recovery solution for your home and office. Protect your personal documents, photos, music and e-mails. Upgrade your hard disk or try new operating systems in the safe knowledge that everything is securely saved in an easily recovered backup file. Macrium Reflect supports backup to local, network and USB drives as well as burning to all DVD formats. This version is for non-commercial home use.
http://download.cnet.com/ImgBurn/3000-2646_4-10847481.html
ImgBurn is a lightweight CD/DVD/HD-DVD/Blu-ray burning application that has several modes, each for performing a different task: Read - read a disc to an image file; Build - creates an image file from files on your computer or network (you also can write the files directly to a disc); Write - write an image file to a disc; Verify - ensure that a disc is 100% readable (you can also have ImgBurn compare it against a given image file to ensure the actual data is correct); and Discovery - used in combination with DVDInfoPro, you can check the quality of the burns your drive is producing.
Apr 19, 2011 | HP Computers & Internet
My dvd burner dont burn every time i tried it says error i have a 2 year extended service protection
dvd burners require alot of space and memory while doing so. try this download the Imageburn software. then instead of choosing burn to disc, select burn to file. this will create a (NTSC) file folder, will have a audio and a video file in it. open image burn and choose >(create image from files and folders) seen in picture below
audioaholic_0.jpg load the folder you created earlier into this, and make whats called a disc image. once you do this then re-open the image burn and click on (write image to disc) and same as before load the disc image into the window, click burn and there should be a succesful burn!!!
this is a long way to acomplish the same result as burning straight to disc, but this way is less stressful on the system, and almost guarrantees a succesful burn every time!!
Jan 28, 2011 | Computers & Internet
I can not play my dvd on sony dvd player i get message canot play.i have a sony dvd recorder in which my laproscopic surgeries are recorded.if i play my unedited dvd on player it runs or plays very well...
My guess is the Pinnacle software isn't writing correctly. Read this from the Pinnacle support site.
Use this FAQ to troubleshoot any problems where Studio is failing during the process of burning the DVD.
  1. INSTALL THE LASTEST PATCH:
If you have Studio version 12, download the latest version here.
If you have Studio version 11, download the latest version here.
Note: Studio 11 patches will only patch a previous install of Studio 11.
If you have an older version of Studio (Studio 9, 10, or 11 etc), it is advised for you to update to the current Studio software. The current version is Studio 12. Click Here to go to the Studio 12 Upgrade page.
How to download and install a patch:
  • When downloading the patch make a note of where it is being saved to. We recommend saving the patch to the desktop.
  • Before installing the patch, make sure that you do not have any other programs running. Studio must not be running.
  • Once it is fully downloaded, double-click on the patch to begin the installation.
  • Follow any on-screen prompts to complete the installation. Reboot the computer after applying the patch.
  1. MAKE DISC SETTING, SAFE MODE BURN OPTION: In Studio, click on Setup -> Make Disc. Under the box marked Burn Options, select "Safe Mode: create disc content and then burn" by clicking on the radio button in front of the setting and then click OK. While troubleshooting this problem, always use this setting.
  1. RESTART STUDIO: Shut down Studio, then relaunch it. Try to create the DVD again using the safe mode setting above.
  1. RESTART THE COMPUTER: Try opening the door of the DVD burner. If it won't open, then shut down Studio, then restart the computer. Launch Studio and try to create the DVD again using the safe mode setting.
  1. MEDIA:
BLANK MEDIA IN THE DRIVE: Make sure that there is a blank, write-once media or rewriteable media in the DVD burner.
TYPE OF DVD: Make sure that your DVD burner supports the media you use. As for any problem with burning a DVD, we recommend customer use rewriteable media to reduce the number of wasted DVDs when they have to troubleshoot a failure while burning DVDs. In this case, if you have only used rewriteable media, (RW) we would also recommend trying to use a write once (-/+ R) DVD and erasing the RW media.
BRAND OF DVD: Pinnacle recommends using a name brand of DVD, i.e. Sony, Apple, Memorex, etc. Also we recommend trying a DVD from a different manufacturer to see if the problem is related to the brand of DVD that is being used.
NOTE: Check with the following site to find information on the media being used.
http://www.videohelp.com/dvdmedia
  1. LOWER THE WRITE SPEED: In the Make Disc settings try lowering the Write Speed to the lowest possible setting.
  1. GET THE LATEST FIRMWARE: Ensure that the DVD burner being used has the latest firmware update from the burner manufacturer.
  1. CHECK DISC SPEED: Make sure that the disc media speed (printed on the media or on the media box) is compatible with the DVD burner. Some burners may not work with media that has a higher maximum supported burn speed. For example, if the burner being used supports 4x disc media, do not use 16x disc media.
  1. DELETE AUXILIARY FILES: Try deleting the Auxiliary Files for the current project. To do this, go to File -> Delete Auxiliary Files and select "Delete auxiliary files for current project." Press OK and try to re-render and burn the project.
  1. ALWAYS RE-ENCODE: Go to the Make Disc settings and check the box called "Always re-encode entire movie".
  1. SAFE MODE: Try burning with the safe mode option selected. To do this, go to the Make Disc settings. In the Burn options are select the option called: "Safe mode: create disc content and then burn.". This step does not apply if you are using Studio 12 since this is the default burn method.
  1. CREATE A DISC IMAGE: In Studio, click on Setup -> Make Disc. Under the box marked Burn Options, select "Create disc content but don't burn" by clicking on the radio button in front of the setting and then click OK. Then click the Create disc button in the Make Movie section to begin the image creation process.
    If the image is not created, it is likely that the problem is a Render problem rather than a burn problem. Click Here to see the FAQ on Render problems.
    If the disc image file is created successfully, burn the disc from the new disc image by selecting "Burn from previously created disc content" in Burn Options.
    NOTE: When troubleshooting all burn or playback issues, it is recommended to use rewritable media to avoid wasting discs.
Nov 04, 2010 | Sony DVP-NS530 DVD Player
How to create bootable cd?
The following items are required:
  • A copy of the original Windows CD/DVD or ISO.
  • A copy of the Boot Files (Downloaded Below).
  • A minimum of 1GB available hard disk space for CD's.
    A minimum of 5GB available hard disk space for DVD's.
Create a folder called OS on your hard drive (C: is used in this example).
In this folder create two sub-folder called BOOT, and ROOT.
Copy the entire Windows 2000/XP/2003 CD (or extract the ISO) into folder ROOT.
1.) Download boot file. (bootfiles-from-tacktech-website.zip ~1.34KB)
2.) Extract the BootSector file (boot.ima) from bootfiles-from-tacktech-website.zip
into the folder C:\OS\BOOT
Start Nero Burning ROM.
Select File > New... from the menu.
1.) Select CD-ROM (Boot).
2.) Select Image file from Source of boot image data.
3.) Check Enable expert settings (for advanced users only!).
4.) Set Kind of emulation: to No Emulation.
5.) Set Load segment of sectors (hex!): to 0000.
6.) Set Number of loaded sectors: to 4.
7.) Set Platform identifier: to Intel x86 compatible.
8.) Press the Browse... button.
Locate the BootSector file (boot.ima) in the folder C:\OS\BOOT.
Click the Open button.
Click on the ISO tab.
- Set File name length to Max. of 31 chars (ISO Level 2).
- Set Format to Mode 1.
- Set Character Set to ISO 9660 (standard ISO CD-ROM).
- Check the Joliet check box.
- Check all Relax ISO Restrictions.
- Check Allow more than 64 characters for Joliet names.
Click on the Label tab.
Remove the check from Also use the ISO 9660 text for Joliet.
Enter the Volume Label into the ISO 9660 and Joliet text boxes.
Click the More fields button.
- View Windows 2000 CD Labels (TTID# 269)
- View Windows XP SP0 CD Labels (TTID#226)
- View Windows XP SP1 CD Labels (TTID#283)
- View Windows XP SP1a CD Labels (TTID#312)
- View Windows XP SP2 CD Labels (TTID#342)
- View Windows XP SP3 CD Labels (TTID#422)
- View Windows 2003 Server RTM CD Labels (TTID#292)
- View Windows 2003 Server SP1 CD Labels (TTID#355)
- View Windows 2003 Server R2 Disc Labels (TTID#387)
Enter in the Volume Label into the System Identifier, Volume Set, Publisher,
Data preparer, Application
text boxes under ISO 9660 and Joliet.
Click the OK button.
Click the Burn tab.
- Check Write.
- Check Finalize CD (No further writing possible!).
- Set Write Method to Disc-at-once. (We have had Track-At-Once work as well.)
- Click the New button.
- Locate the folder C:\OS\ROOT.
- Select everything in the folder and drag it to the ISO compilation panel.
Note: Some files are not show in the following image.
- Click the Write CD Dialog button.
Click the Boot tab.
- Verify the settings. Correct if needed.
- Click the Burn button.
Wait for Disc creation to finish.
Click the Done button.
Process completed. You're done.
Regards
Pcs365.8
Jun 01, 2010 | Microsoft Windows XP Home Edition
In Roxio Creator 10, I attempt to burn a disk of a slide show. I receive an error message 8004520C When I check production it reports no problem. This is repeatable.
May 25, 2010 | Roxio Easy Media Creator 10 Suite
Writing bottable disk
Here are the instructions, taken right out of Nero's manual for Burning ROM 8. page 42:
9.3 Creating and Burning a Bootable Disc
To create a bootable disc, proceed as follows:
1. Click on the New button in the main Nero Burning ROM screen.
�� The New Compilation window is opened.
2. If you want to create a bootable CD, select the entry CD from the combo box and the entry
CD-ROM (Boot) from the list box. If you want to create a bootable DVD, select the entry
DVD from the combo box and the entry DVD-ROM (Boot) from the list box.
�� The tabs for the bootable disc are displayed; the Boot tab is in front.
3. If the template data for the bootable disc should originate from a logical drive:
1. Select the Bootable logical drive option button in the Source of boot image data area.
2. Select the entry you want from the drop-down menu.
If the logical drive you want does not appear in the drop-down menu, the reason for this is
that the drive is bigger than the space available on the disc. Please note that for operating
systems as of Microsoft® Windows® 2000 you need to have administrator rights in order to
be able to access drives directly, which you will need to do if you are to create bootable
discs.
4. If the template data for the bootable disc should originate from an image file:
1. Select the Image file option button in the Source of boot image data area.
2. Click on the Browse button and select the desired image file.
3. Select the language that should appear while the system is booting from the Boot locale
drop-down menu.
4. Check the Enable expert features box and select the emulation type for the image file
from the Emulation type drop-down menu.
5. Select any other options required on the tabs (see New Compilation Window).
6. Click on the New button.
�� The selection screen is displayed.
7. Select the files/folders that should be written to the ISO part of the bootable disc and drag
them into the compilation area.
�� The files/folders are displayed in the compilation area and the capacity bar indicates how
much storage space is required on the disc.
�� You have now created the bootable disc and can start the burn process (see Starting
the Burn Process).
Feb 06, 2008 | Computers & Internet
Roxio Creator 2010 Full Version for PC (244000) Logo
223 people viewed this question
Top Roxio Computers & Internet Experts
Are you a Roxio Computer and Internet Expert? Answer questions, earn points and help others
