Question about Kenmore 15864/15862 Top Load Washer
While filling and while running machine leaks the water out.
    Champion:
  • 245 Answers
If it leaks out the front it is your water pump probably. Leaks out the back it is either your inlet valve or your hoses are leaking.
Posted on Aug 21, 2010
2 Suggested Answers
  • 327 Answers
SOURCE: water leaks under machine when filling
Hello, if your washer leaks only when filling then you have to check these:
Air-gap device- The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
THE TUBE - There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak
inlet spout- Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tube. If the spout cracks or breaks free of it's mounting, it can cause a leak.
Thanks
Posted on Jun 04, 2010
I have SE showing on my Samsung washer/dryer please respond with any suggestions
Samsung washing machine no workeing ? dL
The door was unlocked while the washer was running
dS
The door was opened while the washer was running
d5
FL
The washer failed to lock the door
Hr
Washer temperature control problem
Heater Relay Failure (on main PCB)
LO
The door will not unlock
5E
Washing machine has failed to drain the water
4E
Water fill time out
ND
Water Does Not Drain From Washer
NF
Water fill time out = No Fill
dE
Washing machine door detected as being open
UE
Washing machine has detected an imbalanced load
DC
Washing machine has imbalanced load and will not spin
3E
Motor fault detected
bE
Motor short error
OE
Washing machine has detected an overfill situation
LE
Water leak - Excessive SUDS - Bad water level switch
HE
Water heating error detected
tE
Water heating sensor (thermistor) error detected
IE
Water level sensor fault
CE
Abnormal water temperature detected
E1
Not filling in allocated time
E2
Pump won't empty - not draining
E3
Overflow - overfilling with water
E4
Out Of Balance (OOB) detected
E5
Water temp rising or falling too quickly
E6
E7
Pressure switch
E8
Temp too high on low temp washes
E9
Water leak, Water level has reduced
EA
Motor generator error
EB
Motor error
Sep 30, 2016 | Samsung Washing Machines
Water run in tub when washer is off and leaks all over, this is a built in whirlpool dishwasher
If it's clean water the fill valve is bad turn water supplies off see if leak stops. Is it still leaked with water supply turned off check drain hose could be to low causing drain water to back fill into tub
Mar 30, 2016 | Washing Machines
My whirlpool just started leaking from the bottom of machine onto the floor. This happens when the machine is OFF and no clothes in machine. Is it a switch
The drain hose has to be higher than the water level at its highest point. IF there is water coming into the machine when it is not running then you may have a bad water inlet valve. They develop leaks like any faucet or valve. It could be some other things too, like the voltage to the valves is not completely cutting off. There is also some water that stays in those machines because it cannot all be pumped out. What is the model number?
Oct 29, 2017 | Washing Machines
Lg top loader ie error message, fills ok, but water running out of bottom of machine
Hi IE means Inlet Error. The machine thinks that it is not filling (as a certain time has passed without reaching level it wants).
This makes sense if water is running out the bottom.
You will need to find the leak. Maybe the tub to pump hose, or the drain pump itself. Once you stop the leak and the machine can fill in the correct amount of time, you shouldnt see the IE error any longer.
Cheer
Jun 01, 2014 | LG WD-1045FH Front Load Washer
My Kenmore 700 series washer has been leaking water. When the tub is filling with water, water seems to leak along the front bottom edge of the machine in several areas. I'm left with a huge puddle of...
First ck to see if your water pump is leaking. It normally leaks when the machine is running not just filling. Also look at all the attaching rubber hoses under the machine and see if water is leaking down the back right side of the machine and then running around the frame to the front long shot but possible.
Aug 11, 2010 | Kenmore 15864/15862 Top Load Washer
Roper washer leaks when filling
It's in the drain hose somewhere,during the fill the water gets as deep in the drain hose as it does in the washer,during the wash the pump runs in reverse keeping the water level in the hose low,during the drain the hose is filled again.
Prop the washer up in front on a couple bricks or boards,start putting in water until it starts to leak and take a peak under the machine.
Sep 27, 2009 | Washing Machines
During the fill cycle, the washer leaks water?
I've repaired leaks from bad rubber washers on the fill hoses as well as loose hose clamps on the back of the fill solenoids that run into the tub. Check closely.
Jun 27, 2009 | Maytag Washing Machines
WATER LEAKING FROM UNDER THE WASHING MACHINE
follow the hose from where it connects into the washer.. take off that panel and pinpoint leak. more than likely a hose is unattached
Apr 15, 2009 | GE WWSE5200B Top Load Washer
Water leaking from bottam while in running cycle
water leaking from under the machine while running. Also will not stop filling in the rinse cycle.
Jun 14, 2008 | GE WHRE5260E Top Load Washer
Water coming from bottom of machine
If this only happens when the machine is filling the hose leading to the top of the tub may be leaking. Before it fills this hose is disconnected from the water supply by a closed solenoid valve. There are two valves which feed into a common hose that comes up to the top of the tub where the water runs into the tub. The leak does not happen after the tub fills because all the water leaks out and no new water runs in. These hoses are usually very small and very inexpensive and held on with clamps. They can usually be replaced by removing a small panel near the hose attachment location.
Nov 30, 2007 | Zanussi FJS1225W Front Load Washer
Kenmore 15864/15862 Top Load Washer Logo
120 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
