Question about Coleman Mach 15 Air Conditioner
My air contioner runs but not cold, do you think i need to add coolant ? and if so what kind do i add ?
  • Coleman Master
  • 43,501 Answers
You may need freon, but don't attempt it yourself...
How to add Freon to a Air Conditioner or Refrigeration System
http://www.fixya.com/support/r5638346-add_freon_air_conditioner_or
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Aug 21, 2010
Where do I start to look at when engine overheats when air conditioner is on
The A/C causes the engine to work harder (that's why fuel economy suffers when it is run).
If your car has an electric fan - make sure it runs when the engine is hot. If it does not - you may have trouble w/o the A/C running if is gets warmer outside. Look for fail fuses, disconnected plugs, etc.
You may also have flaky thermostat that is not opening fully when needed to exchange hot water in the engine block with cooler water in the radiator.
First, check the coolant level. You should find a semi-transparent reservoir / tank located under the hood that has a cap marked "Coolant". The side of the tank should have two indicator lines - one for HOT and one for COLD. If the engine has been run up to normal temperature (so that it can provide heat in the car), you should see the coolant level at or slightly above the HOT line. If the engine is cold - first thing in the morning or after sitting for several hours - the coolant should be at or slightly above the COLD line. View these levels while the engine is off and the car is parked on a flat, level surface. If there is not enough coolant - you will need to add the CORRECT type for your car.
Hot Engine
(1) With the engine hot, add enough coolant to the tank to bring the level to the HOT line. You may have to check the tank several times after driving if the coolant level in the radiator is down a great deal. NEVER open the radiator cap when the engine is warm or hot!
or:
Cold Engine
(2) With the engine cold, add enough coolant to the tank to bring the level to reach COLD line. Additionally - with the engine cold - you can add coolant directly to the radiator by removing the cap. Start the engine, set heat in car to HOT and add coolant mixture to radiator until level comes up to the bottom of the filler neck. Once the engine is HOT (getting heat in the car) check and top off radiator as needed and put cap back on radiator.
Check the levels in the TANK several times over the next few days when cold. If the tank ever empties -you'll need to have this looked at by a mechanic.
Apr 09, 2015 | 2009 Dodge Journey
1990 dodge caravan heater blowed cold air
Could be a faulty thermostat, low coolant, or a faulty blend door under the dash.
Dec 08, 2012 | Cars & Trucks
Cooling system
Raise the car front end as high as possible with a floor jack, fill the coolant tank to the top, run the engine until it reaches just short of overheating, shut it down and run water over the radiator, this will burp the air out. Repeat as needed. Don't let the coolant recovery tank run dry during procedure.
Aug 31, 2012 | 2000 Jeep Cherokee 2WD
My heater isnt working, the temperature gage flucuates, and it keeps telling me it has low coolant even though I just added coolant
low coolant sensor is probably just dirty. cold air could also indicate n air bubble in the line. could also be thermostat. try that first.
Nov 30, 2011 | 2000 Pontiac Grand Am GT
No my alero is overheating. I have replaced the thermostat and waterpump and put a new cap on reservior and im losing coolant out the overflow
YOU NEED BLEED AIR OUT THE COOLING SYSTEM.WAIT TO ENGINE COOL DOWN.YOUR VECHICLE YOU HAVE TO POUR COOLANT IN THE COOLANT OVERFLOW JUG UNTIL COOLANT LEVEL STAY AT THE FULL COLD MARK.THEN START ENGINE LET IT IDLE A FEW MINUTES WATCH COOLANT IN THE OVERFLOW JUG WHEN IT DROPS ADD MORE COOLANT UNTIL COOLANT LEVEL STAY AT FULL COLD MARK.WHEN COOLANT LEVEL STOP DROPPING IN OVERFLOW JUG.SCREW RADIATOR CAP BACK ON OVERFLOW JUG WATCH ENGINE COOLANT TEMPERATURE GAUGE AS COOLANT TEMPERATURE START CLIMBING TURN OFF ENGINE LET IT SET A WHILE KEEP FROM GETTING SCALDED.TAKE LARGE RAG PLACE OVER COOLANT OVERFLOW JUG CAP SLOWLY OPEN RADIATOR CAP A LITTLE AT A TIME UNTIL PRESSURE RELEASE.REMOVE OVER FLOW JUG CAP.ADD MORE COOLANT UNTIL COOLANT LEVEL AT THE FUL COLD MARK ON THE OVERFLOW JUG.THEN SCREW CAP BACK ON THE OVERFLOW JUG.START ENGINE LET IT IDLE AGAIN WATCH ENGINE COOLANT TEMPERATURE GAUGE WHEN TEMPERATURE GAUGE START CLIMBING.TURN OFF ENGINE WAIT A WHILE.CHECK COOLANT LEVEL IN THE OVER FLOW JUG.DO THIS PROCEDURE UNTIL THE COOLANT LEVEL IN THE COOLANT OVERFLOW JUG STOP DROPPING AND STAY AT FULL COLD MARK,WHEN THE TOP RADIATOR HOSE GET HOT THERMOSTAT OPENING AIR IS OUT THE COOLANT SYSTEM. WHEN ENGINE COOLS DOWN.CHECK COOLANT OVERFLOW JUG COOLANT MUST BE IN THE COOLANT OVER FLOW JUG AT THE FULL COLD MARK WHEN ENGINE COLD. DONT .DONT OVERFILL COOLANT OVERFLOW JUG.KEEP COOLANT IN THE OVERFLOW JUG IF YOU LET COOLANT OVERFLOW JUG RUN DRY AIR WILL BE DRAW IN COOLANT SYSTEM CAUSE ENGINE TO OVERHEAT.
Aug 12, 2011 | 1999 Oldsmobile Alero
Need to know if i need to bleed the cooling system, after installing the radiator?
ADD COOLANT IN THE COOLANT OVERFLOW JUG UNTIL COOLANT LEVEL STOP DROPPING AND COOLANT LEVEL STAY AT THE FULL COLD MARK.PLACE COOLANT OVERFLOW JUG CAP BACK ON JUG.CRANK VECHICLE UNTIL ENGINE START WARMING UP. STOP ENGINE WAIT FOR A WHILE UNTIL COOLANT COOL DOWN TO KEEP FROM GETTING SCALDED. USE A LARGE RAG OVER THE OVERFLOW JUG CAP OPEN OVERFLOW JUG CAP A LITTLE AT A TIME REMOVE OVERJUG CAP CHECK COOLANT LEVEL ADD MORE. COOLANT IN THE OVERFLOW JUG.THEN START VECHICLE AGAIN.LET ENGINE IDLE UNTIL TOP RADIATOR GET HOT.THEN THERMOSTAT WILL BE OPEN.WHILE ENGINE IDLING WATCH THE TEMPERATURE GAUGE IN VECHICLE IF TEMPERATURE GAUGE START CLIMBING IN THE HOT ZONE.TURN OFF VECHICLE LET IT SET A WHILE THEN USE LARGE RAG REMOVE OVERFLOW JUG CAP.ADD MORE COOLANT, PLACE CAP BACK ON START VECHICLE AGAIN KEEP DOING THIS PROCEDURE UNTIL TEMPERATURE STOP CLIMBING HOT ZONE.AND WHEN COOLANT LEVEL STOP DROPPING IN THE COOLANT OVERFLOW JUG.AIR IS OUT THE SYSTEM, BUT KEEP COOLANT LEVEL IN THE COOLANT OVERFLOW JUG AT THE FULL COLD MARK.DONT OVERFILL.DONT LET COOLANT OVERFLOW JUG RUN DRY IF SO AIR WILL ENTER COOLANT SYSTEM BECAUSE COOLANT LEVEL WILL BE LOW ENGINE WILL START OVERHEATING.
Jul 24, 2011 | 2006 Dodge Grand Caravan
When my car need coolant do I have to add it to the coolant recovery tank and the radiator
Both, I recomend you add the coolant to the radiator untill it tops off, with the car on, and then add to the recovery tank untill the fill line. NOTE: ensure the engine is not hot before removing the radiator cap, if it was running let it cool for a while before opening it and if you add cold coolant to a very hot engine the engine block can crack.
Mar 01, 2011 | Heating & Cooling
CAR RUNNING HOT AFTER I CHANGED A BAD RADIATIOR OK RADIATIOR HAD A WHOLE IN IT WE CHANCED IT BUT NOW ITS RUNNING HOT HOW DO I PROPERLY REFILL THE RADIATIOR
CHECK COOLANT LEVEL STILL LOW.ADD MORE COOLANT.UNTIL RADIATOR OVERFLOW FULL AT COLD MARK.THEN CRANK ENGINE UP LET IDLE FEW MINUTES LOOK DOWN COOLANT OVER FLOW JUG ADD MORE COOLANT IF LEVEL DROPPED.WHILE ENGINE RUNNING KEEP EYE ON TEMPERATURE GAUGE.WHEN THERMOSTAT HOSE GET HOT.TURN OFF ENGINE WAIT A LITTLE WHILE TO KEEP FROM GETTING SCALD TAKE LARGE RAG PLACE OVER OVERFLOW JUG RADIATOR CAP.OPEN CAP A LITTLE A TIME.IF COOLANT TRIES BOIL OUT.LET VECHICLE SET A WHILE LONGER.ADD MORE COOLANT.WHEN COOLANT LEVEL CORRECT AND ALL AIR OUT THE COOLANT SYSTEM.IT WILL STOP OVERHEATING.LONG AS ENGINE RUNNING HOT TURN OFF THE ENGINE POUR IN MORE COOLANT UNTIL COOLANT LEVEL STOP DROPPING IN RADIATOR.KEEP COOLANT LEVEL IN OVERFLOW AT COLD MARK.DONT OVER FILL OVERFLOW JUG.
Jan 23, 2011 | 1996 Lincoln Continental
Adding Coolant
Wait til the car is cold and then open the cap on the RADIATOR by pushing it down while twisting. The coolant must be filled to the brim. Replace the cap and then fill the overflow tank to the "cold" mark. Use a 50/50 mixture of water and coolant.
Jun 27, 2009 | 1998 Chevrolet Suburban
My car has heat sometime......
air trapped in cooling system. loosen radiator cap (cold engine), fill with coolant. run engine with cap loose till warm to purge air. add coolant. repeat if nec.
Feb 22, 2009 | Mitsubishi Galant Cars & Trucks
Coleman Mach 15 Air Conditioner Logo
160 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
