Question about Skagen Signature Mesh watch
I dont know how to make my grenen watchband larger
  • 831 Answers
Skagen has their instructions at the following link:
http://www.skagen.com/service/watchInstructions.fx#adjustment
Posted on Aug 21, 2010
Need the replacement strap for Timex watch M805
Timex Watchband - watchbands.com
www.watchbands.com/Departments/Timex-Watchbands.aspx
Original Timex® Replacement watchbands and straps designed to fit Casio, Seiko ... Currently the Timex bands we have are below. Leather Timex Watch Bands.
Jan 01, 2016 | Timex Watches
NEED LARGER WATCH BAND FS2700
I suggest buying it at a local shop, but if you want to buy online you can buy here
www.watchbands.com
Jul 28, 2008 | Fossil Watches
How do I add a link to the wristband?
Thank you for contacting FixYa.
  • Turn your watch on its side so the links are vertical. On the inside of the links closest to the clasp you can see arrows, which point in the direction that the pins must be pushed out. Only about four links on either side of the clasp have arrows, because these are the only links with removable pins. On the edge of the links on the opposite end from where the arrow is pointing you will see a small circle where the pin is inserted.
  • 2
    Place the tip of your pointed tool on the small circle mentioned in Step 1. Push downward on the pin in the direction the arrow is pointing. Once the pin starts to come out of the link, use your fingertips or a pair of tweezers to completely remove the pin from the link. You may need to use force, but be careful not to scratch your watchband. Use a pointed tool from a jeweler's or hobby kit or watch pin removal tool.
  • 3
    Slide the links apart where you removed the pin so there is a gap in the watchband. Slide your new link into the gap and fit the neighboring links into the new link so it matches the rest of the watchband.
  • 4
    Insert the new pin into the watchband. You will need to insert two pins, the pin you moved in Step 2 and your new pin, into the two empty pin holes. You need to insert the pin small end first so the larger pin head does not pass through the link. Insert the pin against the direction of the arrow rather than in the direction the arrow is pointing like you did in Step 2. Use your pointed tool and your fingertips to push the pins completely in the links until the pin head is flush with the edge of the link.
  • Best regards. Jewel
    Sep 16, 2010 | Nixon District Watch
    How do i install additional links to this model watch? the company mailed me 2 additional links but no installation instructions Fossil model ES1967
  • Place the tip of your pointed tool on the small circle mentioned in Step 1. Push downward on the pin in the direction the arrow is pointing. Once the pin starts to come out of the link, use your fingertips or a pair of tweezers to completely remove the pin from the link. You may need to use force, but be careful not to scratch your watchband. Use a pointed tool from a jeweler's or hobby kit or watch pin removal tool.
  • Slide the links apart where you removed the pin so there is a gap in the watchband. Slide your new link into the gap and fit the neighboring links into the new link so it matches the rest of the watchband.
  • Insert the new pin into the watchband. You will need to insert two pins, the pin you removed in Step 2 and your new pin, into the two empty pin holes. You need to insert the pin small end first so the larger pin head does not pass through the link. Insert the pin against the direction of the arrow rather than in the direction the arrow is pointing like you did in Step 2. Use your pointed tool and your fingertips to push the pins completely in the links until the pin head is flush with the edge of the link.
  • Aug 18, 2010 | Watches
    Two watches: can not find a 22 in wrist band for this one
    Watchband Solutions can probably help you. Their website is
    www.watchbandhq.com
    Hope this helps,
    Ken
    www.yellowstonewatch.com
    Apr 11, 2010 | Peugeot 288BK Wrist Watch
    Hi. I've got a Grenen mesh watch band and need to move the clasp mechanism further down on it to make it tighter, but I can't figure out how to loosen it to move it. Can you help?
    Grenen watches are made by Skagen exclusively for Kohl's. Here is the link to the their website instructions for watch band adjustment.
    Apr 11, 2010 | Watches
    Where can I find a watchband? mine broke
    Use this link:
    https://buy.garmin.com/shop/shop.do?pID=10527#accessoryTab
    If you dont see the part you are after, use the tabs on top of the page to sort the problem.
    Rate me, please.
    Jul 30, 2009 | Garmin Forerunner 50
    Changing a Rolex metal watchband to a leather watchband
    Put the watch face down and examine the point where the band is connected to the watch case. you will find two holes and through them you will see sprinbar ends insertyed into watch case lugs. Take the tiny screwdriver and push the springbar end inwards,then do the same at the other lug reaching them through those holes.
    Then repeat the same at the other end of the band.
    Measure the distance between watch case lugs- this will be exact size for your new leather band.
    Rate me, plesae.
    Mar 23, 2009 | Rolex Daytona 116528 Wrist Watch
    Seiko Watchband to long
    Kept looking thru Google and found THIS site that seems to answer the question for MANY styles of METAL watchbands.
    http://www.geocities.com/watch_crazy/index.htm
    Dec 06, 2007 | Watches
    Skagen Signature Mesh watch Logo
    554 people viewed this question
    Top Skagen Watches Experts
    Jimmy Accardi
    Gary Nitowski
    Are you a Skagen Watch Expert? Answer questions, earn points and help others
