Question about Curtis DVD6041 System
I lost my manual, now I'm setting it up in a new location. I can get audio to the DVD but no picture or audio to TV. I also have a direct TV reciever which seem to be working fine. I have Toshiba CZ32V61 TV. Thank you for your assistance.
  • 104 Answers
Download your manual here
http://www.devicemanuals.com/guide/Television/Toshiba/Toshiba-CZ32V61-User%27s-Guide-TVRNeE56QT.html
Posted on Aug 21, 2010
I have direct satalite tv VR 6050 kenwood surround sound tuner vizio tv, dvd player, and a vcr, Im confused on how its hook up and what order should it go something like sat in to sat box to kewood...
that reciever is not going to carry a hi definition video signal, it doesnt have either hdmi or component video inputs.
you can still use it, but if you run the picture through the reciever, it will have poor quality.
heres how you are supposed to hook it up:
find the single,m yellow video jack on your sattelite box, and hook that up to the "tv" video input, then hook the laft and right audio outputs from the cable box into the "tv" audio left and right inputs on the receiver. hook up the dvd player and vcr in the same manner, using "dvd" and "VCR" (if labeled as such) inputs on the reciever.
finally, send the tv video and audio outputs to the composite video in and left/right audio inputs on the tv. the video will be running through the reciever, and when you use the reciever to switch the sound source, the video will also be changed. you could get better picture quality if you ran the video directly to the tv using component (seperate green, red and blue) outputs/inputs, and bypassing the reciever on the video end, but then you would have to change inputs on the tv AND reciever to change from your cable box to your dvd player.
Nov 25, 2010 | Kenwood VR-6050 Receiver
How do I get my Panasonic sa-pt670 to play all the speaker. watching tv and with ps3
Does you Tv set have optical out? If so might I suggest running HDMI into your television set from the PS3, then run an optical audio line out from the tv into the optical line in on your HTIB
Feb 24, 2010 | Panasonic Home Theater System System
Denon avr-1908 no picture from dvd player which is a panasonic...using hdmi cable
if your not getting a picture make sure you have change you signal setting on the reciever if you have done that. and you know your connections are right and you you are going from your dvd into the reciever and then the reciever to the tv with hdmi check you tv as well make sure you have switched your input signal to to the video source were your plugged into the tv i dont know what kind of tv you have but you may need to double check that
Nov 11, 2009 | Denon AVR-1908
No sound when the tv is on and the mute is turned off
I still am unclear as to your hook up but lets try this, if you have your DVD/VCR plugged into the TV audio and video and a audio cord from the tv monitor out to an input on the reciever, this way you should hear the sound at the tv and reciever.
However if you have your DVD/VCR plugged into the reciever first audio and video connections made at the reciever you should just have a video cord fromthe monitor out of the reciever to the tv and your audio will come from the reciever
Feb 25, 2009 | Panasonic PT-52DL10 52" Rear Projection...
Denon AVR-488 , problems routing cable box through receiver to tv
If you don't have one, the manual is available online: http://static.highspeedbackbone.net/pdf/AVR-488-OM-E_101.pdf
Suggestions:
1. Reset to default values. Per page 36 of manual: 1. Turn off Power. 2. Press Power while simultaneously pressing Speaker A and Speaker B. 3. Once the display starts flashing at intervals of about 1 second, release the two buttons.
2. Make sure you have AM or FM radio reception. This makes sure your speakers, amps, etc are connected and working correctly.
3. Connect DVD player to HDMI 1 in and TV to HDMI Monitor Out.
Play a known good DVD that works when you connected the DVD directly to the TV via HDMI.
Select the DVD/HDP input on the receiver and play the DVD. You should not have to perform any input assignments, etc. It should just work, as HDMI1 is the default system setting for DVD.
4. If possible, obtain a STB with HDMI out & repeat step 3 using the HDMI2 TV/CBL input. Keeping the signal path all digital (HDMI) will give you a better picture quality than forcing several analog to digital conversions (component video is analog).
4A. To use the component connection, first test by connecting the STB directly to the TV via component video/audio if possible. This tests that the component video output of the STB is working correctly.
Next, remove direct connection and connect via receiver. Connect STB to receiver as shown on page 13 in manual. Connect component video output from STB to component video input #2 (tv/cbl) on receiver. Connect the STB audio output to the corresponding tv/cbl audio inputs.
Make sure nothing is connected to the HDMI2 input or to any other TV/CBL inputs (composite video, s-video, digital coax audio).
Now select the TV/CBL input and turn on the STB. You should have both audio & video.
Mar 08, 2017 | Electronics - Others
Best way to connect new system
After trying several ways, we decided the best picture was to run the blue ray (out) directly to the TV (in) with an HDMI and another HDMI from the sat. box(out) to TV(in), then optical audio from TV (out) to receiver (in). This way you don't have to change channels on the reciever when switching from TV to DVD. Remember that HDMI is one cable that supports audio and video. If you are using all Samsung products and want to use one remote, using the Anynet feature, I think it has to be connected with an HDMI. I'm going to try connecting an HDMI too from the reciever to the TV to see if this feature will work. It does with the Blue Ray.
Nov 21, 2008 | Samsung HT-AS720ST Theater System
Onkyo TX SR 702 AV Receiver
don't run you video from the projector to the reciever. just run it to the dvd and run the sound from the dvd through the reciever
Jun 01, 2008 | Onkyo TX-SR702 Receiver
KLH R7000 Component Video Problems
I have lost my remote and instruction book where? do is it worth it replace
Mar 07, 2008 | KLH R7000 Receiver
Trying to hook up dvd player with sanyo tv. Also hook this up to satellite and surround sound. No picture, just audio.
Well are you ready for this I hope you can under stand if not maybe I can draw a diagram. Starting with your stereo take the component video out and goto component on the back of your tv to component in then the stereo coaxial in to the digatl audio out on the DVD player then DVD player anntena out to TV anntena in then DVD anntena in to reciever anntena out and Sat cable to reciever. also s-video on Dvd componet to s-video on TV DVD player Audio out to Audio in on TV. Set Stereo to TV and DVD player to channal 3 or do auto scan and TV will work on 3 with the reciever and also TV works with Video 2 I hope this works for you good luck
Jan 03, 2008 | Sanyo DS31590 31" TV
Curtis DVD6041 System Logo
111 people viewed this question
Top Curtis Audio Players & Recorders Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
240cpa
Are you a Curtis Audio Player and Recorder Expert? Answer questions, earn points and help others
