Question about Omnifi DMP1
I want to know if all 4 pin DIN connectors for car stereos would be wired the same ............my reason for that question is because I have recently been given an Omnifi DMP 1 and the previous owner said the controller knob now longer performs the intended scroll function and I am wanting to purchase a head unit that can control the DMI like a cd changer.
    Top Expert:
  • Omnifi Master
  • 76,164 Answers
The connector is standard, however the wires in the connector vary with car stereo maker
Posted on Aug 21, 2010
I have a Jensen car stereo m 9213 with no wire harness power /speaker plug for the back of the unit, I need to know witch pin is the Power pin, and all the pin destination are,
Find the harness. Your best bet. Hit the wrong wire with power(those pins are really close together) and you will no longer have a Jenson stereo.
Oct 17, 2016 | Jensen 1-DIN In Dash 7" DVD Receiver w/...
Logitech z3 wiring
I have a logitech z3 subwoofer with a mini-DIN-9 connector socket. It also has a volume control and 110V power cord. As best as i could trace the circuit, and using the TDA7377 stereo bridge amplifier chip datasheet, the pinout for the mini-DIN is as follows (untested):
1: L in (to vol.)
2: R in (to vol.)
3: Power (12V from transformer)
4: Standby (5V to play, 0.05mA; 0V to standby)
5: L out
6: R out
7: Ground
8: Ground
9: Ground
Connecting 3 to 4 with a large resistance (~20K ohms) should enable speaker. Pins 1 and 2 might be swapped; pins 5 and 8 might be swapped. Mini-DIN socket pin holes are numbered right to left, bottom row to top row:
9 8 7
6 5 4 3
2 1
Sep 03, 2012 | Logitech Z3 2 Speakers
I have and old Peavey Mark IV bass head. I want to know if it is possible to remove the crazy 8 or 10 pin footswitch input and replace it w/ a 1/4 in plug. There is only two wires running to this craz
2 wires plus ground needs a stereo 1/4 plug. Don't know Mark 4, but Mark 3 has 2 button fs with 3 wires plus ground. Schematic here: http://el34world.com/charts/Schematics/files/peavey/peavey_mark_3_bass_with_pa.pdf
shows 3 wires plus ground. Stereo plug does not have enough connections, only ground plus 2 wires.
Count the pins of socket and find DIN plug with proper pin-out for socket. Search google for DIN plugs.
May 02, 2017 | Music
Vizio VZ42L. HDTV has stereo speakers connected by what appears to be 5 pin DINS to the television. I would like to use one of the two speakers as my "center" speaker for the surround sound. Is...
Hello
Your Vizio has a 5 pin din connector to take the speaker connection out. There is a 'noch' in the din socket from which count towards left; the first is pin number [1] second is pin number [4]; third is pin number [3]; fourth is pin number [5]; and fifth is pin number [2]. Out of these, pin numbers [2.4&5] has no connections from inside, that is [NC]; not connected. Pin numberes 1&3 are two speaker positve terminals, and the body of the 5pin din pin will act as negative to both channels, that is common.
The company has provided only two channel stereo sound from it to out. There is no provision to get a center speaker out of it. OK.
Feb 12, 2011 | Vizio 42 in. LCD TV
My mothar board are pspe.vm so i know which ram add my mothar bord 512mb ya 1 gb ya 2 gb sopart my motharbord
ASUS P5PE-VM - motherboard - micro ATX - i865G specifications
General
Product type (AE)
Motherboard
Form factor
Micro ATX
Width
9.6 in
Depth
7.6 in
Compatible Processors
Pentium 4 , Celeron D , Core 2 Duo , Pentium D
64-bit Processor Compatibility
Yes
Mainboard processor socket
LGA775 Socket
Mainboard / Multi-Core Support
Dual-Core
Chipset Type
Intel 865G / Intel ICH5
Data bus speed
800.0 MHz
BIOS type
AMI
Storage key information
Serial ATA-150 , ATA-100
Power connectors
4-pin ATX12V connector , 20-pin main power connector
Processor
Installed Qty (Max Supported)
0.0 ( 1.0 )
Memory
Cache Memory Type
None
Supported RAM Technology
DDR SDRAM
Supported RAM Integrity Check
Non-ECC
RAM Installed ( Max )
0.0 MB / 2.0 GB (max)
Supported RAM Speed
PC2700 , DDR266/PC2100 , PC3200
RAM Features
Dual channel memory architecture , Unbuffered
Video
Graphics Controller
Intel Extreme Graphics 2 Dynamic Video Memory Technology 2.0
Audio
Audio Output
Sound card
Signal processor
Intel 865G
Audio codec
AD1988
Sound Output Mode
5.1 channel surround
Telecom / Networking
Modem
None
Networking
Network adapter - Marvell Yukon 88E8001 - Fast Ethernet , - Ethernet , - Gigabit Ethernet
Features
BIOS Features
SMBIOS 2.3 support , ASUS EZ Flash , WfM 2.0 support , ASUS MyLogo , Hyper-Threading Technology , DMI 2.0 support
Manual Settings
CPU frequency
Sleep / Wake Up
Wake on LAN (WOL) , Wake on ring (WOR)
Hardware Features
C.P.R. (CPU Parameter Recall) , Green Edition , CrashFree BIOS 2
Expansion / Connectivity
Expansion Slots Total (Free)
1.0 AGP 8x - LGA775 Socket , 1.0 Memory - DIMM 184-pin , 3.0 PCI , 2.0 Processor
Storage Interfaces
Intel ICH5 : ATA-100 - connector(s): 2 x 40pin IDC - 2.0 device(s) , Intel ICH5 : Serial ATA-150 - connector(s): 2 x 7pin Serial ATA - 4.0 device(s)
Interfaces
1.0 x Audio - RS-232 - Mini-phone stereo 3.5 mm , 1.0 x Network - Generic - 34 pin IDC , 1.0 x Parallel - IEEE 1284 (EPP/ECP) - Mini-phone stereo 3.5 mm , 1.0 x Keyboard - Line-out (center/subwoofer)/line-in - 4 pin USB Type A , 1.0 x Audio - Line-out - 6 pin mini-DIN (PS/2 style) , 1.0 x Serial - Generic - 25 pin D-Sub (DB-25) , 1.0 x Mouse - Line-in - 6 pin mini-DIN (PS/2 style) , 1.0 x Hi-Speed USB - Ethernet 10Base-T/100Base-TX/1000Base-T - Mini-phone stereo 3.5 mm , 4.0 x Audio - Line-out (rear)/microphone - 4 pin MPC , 1.0 x Display / video - VGA - 15 pin HD D-Sub (HD-15) , 1.0 x Storage - Floppy interface - 9 pin D-Sub (DB-9) , 1.0 x Audio - RJ-45
Additional connectors (optional)
4 x Hi-Speed USB
Miscellaneous
Compliant Standards
RoHS , Plug and Play
Hope this helps,
If I have helped you resolve your problem, please
consider giving me a good rating and a quick
thanks or good job.It will help me as well Thank
you.
Oct 23, 2010 | ASUS P5PE-VM Motherboard
Just wanted to know if the mother board 865GM3-LS supports 1Ghz of AGP graphics card..
Motherboard has a AGP 8x ( 1.5 V/ 0.8 V ) slot.
Check the specs on the graphics board you are going to install. Make sure that it meets these specs.
Here are the specs for your motherboard: General Product Type Motherboard Form Factor Micro ATX Width 24.5 cm Depth 24.5 cm Compatible Processors Pentium 4, Pentium 4 Extreme Edition 64-bit Processors Compatibility Built-in Processor Socket Socket 478 Chipset Type Intel 865G / Intel ICH5 Max Bus Speed 800 MHz BIOS Type Award Storage Controller ATA-100, Serial ATA-150 Processor Installed Qty (Max Supported) 0 ( 1 ) Memory Supported RAM Technology DDR SDRAM RAM Installed ( Max ) 0 MB / 2 GB (max) Supported RAM Speed PC2100, PC2700, PC3200 RAM Features Two DDR channels Video Graphics Controller Intel Extreme Graphics 2 Video Memory Shared Video Memory (UMA) Audio Audio Output Sound card Signal Processor Intel 865G Audio Codec Realtek ALC655 Sound Output Mode 5.1 channel surround Compliant Standards AC '97 Telecom / Networking Networking Network adapter - Realtek RTL8100C - Ethernet, Fast Ethernet Features BIOS Features Hyper-Threading Technology Expansion / Connectivity Expansion Slot(s) 1 ( 1 ) x processor - Socket 478
2 ( 2 ) x memory ( 2.5 V ) - DIMM 184-PIN
1 ( 1 ) x AGP 8x ( 1.5 V/ 0.8 V )
3 ( 3 ) x PCI ( 3.3 V/ 5 V ) Storage Interfaces Serial ATA-150 - connector(s): 2 x 7pin Serial ATA
ATA-100 - connector(s): 2 x 40pin IDC Interfaces 1 x storage - floppy interface - 34 PIN IDC
1 x serial - RS-232 - 9 pin D-Sub (DB-9)
1 x display / video - VGA - 15 pin HD D-Sub (HD-15)
1 x parallel - IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25)
4 x Hi-Speed USB - 4 PIN USB Type A
1 x audio - line-In - mini-phone stereo 3.5 mm
1 x audio - line-out - mini-phone stereo 3.5 mm
1 x microphone - input - mini-phone 3.5mm
1 x network - Ethernet 10Base-T/100Base-TX - RJ-45
1 x keyboard - generic - 6 pin mini-DIN (PS/2 style)
1 x mouse - generic - 6 pin mini-DIN (PS/2 style) Additional Connectors (Optional) 4 x Hi-Speed USB Miscellaneous Software Included Drivers & Utilities Compliant Standards Plug and Play
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 10, 2009 | Computers & Internet
Omnifi DMP1 Logo
48 people viewed this question
Top Omnifi Car Audio & Video Experts
xxxxxx xxx
Are you an Omnifi Car Audio and Video Expert? Answer questions, earn points and help others
