Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
Bissell proheat 7920 replacement pump
How do I get a replacement pump for a 7920 bissell that's 5 yrs old?
    President:
  • 1,673 Answers
Part number is 2107181, it will cost around $30. Most local shops shoul have this part or can order it for you. You could try bissell.com.
Posted on May 13, 2008
New replacement pump on Bissell ProHeat Protech not working
Not sure if I have the same model but this is what I found on mine this morning - wire to switch in the handle came off. Un-plug power cord. Unscrew top two screws on upright handle and remove the front cover above the trigger. see if wires are connected. top connector is not used - if you do solution will spray all the time. Good luck!
Jul 09, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
WATER PUMP
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
eyhj
May 08, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Can't get the water to spray out when I turn it on?
When it doesn't dispense water or solution that means that the pump belt needs to be replaced. You can get a replacement and view the manual here:
Bissell 7920 Pump Belt and Manual
Dec 09, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
How do I take apart my Bissell 7920 ProHeat Pro-Tech
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
heatman101
Jul 16, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Fit a pump to Bissell proheat 7920e
heatman101
wtqy
Jan 09, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 7920 Problem
heatman101
fghj
Jan 08, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
No suction
I had exactly the same problem with my five-year old my Bissell 7920, and it's probably a broken pump belt.  See page 19 of your instruction manual for how to replace.  The Bissel ProHeat belt accessory pack costs $3.99 and you get a pump belt and a brush belt.  Since you have to first remove the brush belt to get to the pump belt, you might as well replace both. The first time I did this it took me 15 minutes, but now that I know the drill, doing a belt replacement would take about 3 minutes.
Apr 10, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
No carpet cleaner coming through
Apr 06, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
104 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
