Question about Microwave Ovens
Kenmore Elite microwave model #665.61682101 went dead after starting. Fuses, switches, and temperature sensors are good. Any ideas?
  • Microwave Ovens Master
  • 9,085 Answers
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
So don't let that fool you.
You can usually find exploded views and order parts by entering your model number at the Sears parts site.
BUT once you have the part number from the Sears site, you can often get the parts cheaper here.
Let us know if you more help.
Posted on Aug 23, 2010
Our microwave keeps blowing fueses. Model MS305SS Why would this be?
Aug 19, 2010 | LG Microwave Ovens
Kenmore Elite worked fine for months, then went dead. No screen, no power, nothing. Cord is plugged in, fuse is fine, circuit breaker is fine also. Any ideas?
This will require trouble shooting with power present and a qualified individual should do this. Verify power at the plug and trace to the board. It could be a bad wire, loose connection, open cavity thermostat, or a failed board assuming power is available and the fuse is good.
Eric
Apr 10, 2010 | Kenmore 63792 Microwave Oven
Maytag Microwave Model#MMV4205BAB
My LCD read is dead. can not read any numbers.
Nov 06, 2008 | Microwave Ovens
How to replace thermal fuse/flame sensor
GE JES 1358 WK 01 microwave:
I recently had the same problem with a "flame sensor, " aka "thermal switch." My microwave is a "throwaway" model, very few repair parts available. I didn't want to replace it, so I did a little bit of research into thermal switches. I actually found one that would replace it for about $5 (plus $5 shipping).
Mine uses a "bimetal" thermal switch. There are three kinds of bimetal thermal switches: automatic reset, manual reset, and "one time use." The really interesting thing is this: the "one time use" resets (!!!) if the ambient temperature is below 0 degrees C, or 32 F (freezing); or, in some cases, -31 C, or about -22 F.
I put my "dead" flame sensor in the -10 F part of the freezer for about 20 minutes...
Checked it with my multimeter, and the once-dead sensor now read continuity (zero ohms)!!!
Reinstalled it in the microwave, and now it works fine.
So if you have a dead sensor- try freezing it...
Sep 21, 2008 | Microwave Ovens
Kenmore 565.6050.9990 microwave dead
Start taking all screws out until you can access fuse.
Sep 17, 2008 | Kenmore 62622 Microwave Oven
Kenmore elite microwave
Does the digital display light up at all? Is it completely dead? Are you sure it has power? Have you tried another outlet? If the outlet is good and the unit is completely dead, the internal fuse may have blown. You can try to take the cover off (with the unit unplugged) and look for a blown fuse. Try replacing the fuse with an EXACT fuse of the same rating. Try plugging the unit back in again and see if the unit comes back on. If not, you may have a power supply issue or defective Magnetron.
Please let me know what you find and we'll go from there.
Good Luck,
- Jim
Jan 28, 2008 | Kenmore 62702 Microwave Oven
Kenmore elite microwave oven
A microwave can be dead for many reasons.
thermostat to open.
When it cools, it closes the circuit and allows power through again.
If it's random, it may be a bad connection, usually on the control board or fuse holder.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body
of the oven.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site,
linked here on Fixya: http://tinyurl.com/yzjozk
Oct 23, 2007 | Kenmore 63792 Microwave Oven
Stainless Steel Kenmore Elite 36 in. 2.0 cu. ft. Microhood Combination Model 63763
Generally the F9 code indicates a problem with the door latch (usually upper) or with the control board. You can do a Google search for my text file "doorsw.txt" to help you diagnose and repair door switch trouble. BUT - since it always stops at 53 seconds, that leads me to think you have trouble with the control unit (circuit board / controller assembly). Once you read and digest the info on door switches, please feel free to do an updated post and I'll be happy to help you further. It may be corrupted ROM in the control unit. But let us know what you find out. - online they call me "William E. Miller, AS-EET"
Oct 15, 2006 | Kenmore 63763 Microwave Oven
Display Screen / Control Panel BLANK
Please provide the correct model # complete. It is located With the door open, mounted to the door jamb near the control panel, or Mounted on the rear of the microwave
Aug 20, 2006 | Kenmore 80809 Microwave Oven
Microwave Ovens Logo
248 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
