My c drive is full but my d drive is empty. how do i start to fill up my d drive?
    Sergeant:
  • 221 Answers
Assuming you have two hard drives installed in your computer, when you save a document, in the drop down list at the top of the save window, click on D:, then select a folder where you would like to save the file.
However, if you do not have two hard drives, then your D: is usually the recovery partition. Windows will not allow anything to be saved to this partition.
If this is the case your best bet would be to format your hard drive and reinstall windows.
Posted on May 03, 2008
  • 32 Answers
If your cd drive is full you should move media files like movies and music to the D drive. Just drag the files from the folders on C drive to your D drive. You should make folders on the D drive so you can keep things organized. It's critical to get a nice chunk of free space back on the C drive. If the operating system is installed on the C drive it will run slow when the drive is too full. You may also want to start archiving files on burnable media such as cd or dvd or place files on an external hard drive.
1997 ford Aerostar. full gage problem. all of a sudden last week it started malfunctioning.
The problem could be big and expensive mine solution is drive 300 km and fill up( 200 m. ) Presently I am doing.
Jun 10, 2017 | Ford Cars & Trucks
2003 honda crv fuel guage below empty when actually full
The float is sinking. This could be from alcohol used in gasoline.
Apr 20, 2013 | 2003 Honda CR-V
My gas gage go from full to empty
Chevy has a very common problem with their fuel sending units (the thing that sends the fuel level info to your computer). The only way to fix it is to replace the fuel pump/sending unit assembly which is very pricey (over $1000 if you go to the dealer). If you can just zero your trip odometer every time you fill up and don't drive more than say 250 miles before you fill again you should be able to drive without running out of gas.
Jan 29, 2012 | Chevrolet Cars & Trucks
Transmission fill, how do you fill
If adding from empty, (just installed new or used unit) put at least four or five quarts in (through dipstick tube). Then, start the engine, leave it in park on a level surface and continue filling 'till it reads full on the dipstick. After it's full put the rear on jackstands and run it in drive and let it shift gears, idle down and shut it off. Don't attempt to put it into park 'till the rear wheels stop turning. Then put it on the ground and re-check level.
If adding to a low unit or after a filter change, just fill on a level surface running till it reads full. In either case, when finished, drive it and when you return re-check level. Always check for leaks.
May 18, 2011 | 1987 Dodge Ram 50
Yes it is normal just no hot air
1. When setting the temperature to MAX, blower level to FULL and outside air Vent CLOSED, no hot air comes out after 2-5 minutes?
If YES, when did you last flushed your radiator and is it full?
2. if more than 5 years ago, flush radiator system, instructions are usually in Owners manual. Use a bottle of Radiator cleaner, run egine hot for about 10-15 minutes, carefully open petcock in bottom of radiator to flush out radiator, WARNING, careful as flushed coolant would be boiling hot. As sson petcock is open and water start to flow out, carefully open radiator cap to enhance flushing flow. Use garden hose to fill radiator while flushing until water coming out from petcock is cold and clear.
Once clear, start engine, turn heter full and blower full blast and keep hose in radiator flowing full, leave petcock open until clear water flows out again. Once clear waters comes out, turn off engine,turn off garden hose and let water drain empty radiator. Once it stops flowing out, close petcock snug and put radiator cap on, pull off radiator coolant catch bottle, clean bottle for any debris and dirt. Drain any water, leave bottle empty and put it back onto its place.
3. Fill radiator with 1 gallon (4L) of concentrated coolant, top up radiator until full, fill catch bottle with concentrated coolant, start engine and keep it overflowing until no bubbles comes out and the radiator is fully hot. Once it is flowing good, close and connect everything. Drive with it and keep catch bottle filled as necessarry.
Good luck. Give as vote and good comment if this advise solve youor problem. Thank you.
Jan 05, 2011 | 2000 Chevrolet Suburban
How many quarts of coolant?
completely empty, including block, most systems hold about 10 quarts, sometimes just a bit more. if adding after a repair, you can use an inexpensive hydrometer to check the concentration (should be base-lined at 50/50) In very cold climates you can go a bit heavier and re-adjust when summer comes. If adding to a new (empty) engine, just use 50/50 and fill it till it's full. Begin by filling with engine off, then start it up and continue filling with heater on high heat. Turn the engine off just before it reaches full operating temp and leave it off for about three minutes, then re-start and continue filling. That allows the thermostat to open and limits back-up that happens just before that. Always check carefully for leaks...running with cap off, then with cap on and again after a short test drive. It only takes a few minutes to do and can save you big problems later on down the road.
Aside from being a conversation point, knowing how much the system holds isn't half as important and getting it full after working on it!!
Dec 10, 2010 | 2001 Jeep Grand Cherokee
Gas gauge/tank
I am very familiar with this problem, u will need to replace the gas gauge sending unit in the fuel tank.
Jun 17, 2009 | 1996 Ford Ranger SuperCab
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
