Question about Victory Freezer Freezer, Reach-In, 2 Door, 45 cu. ft.
Unit leaking water from the vent above any ideas?
  • Victory Master
  • 1,250 Answers
Check for clogged condensate drain. will leak water during defrost cycle as pan overflows.
Posted on Aug 21, 2010
I have a Hoshizaki Machain and it is leaking water above the door on the left side running down to the left leg when standing in front of the machin, what cause this to leak?
IF you are talking about a freezer, make sure the unit is level as the condensate pan may be overflowing. Also, if the door does not seal properly, it can cause "Sweating" as cold air is escaping and causing condensation at the door. Start with that first.
Sep 10, 2014 | Hoshizaki Freezer Commercial Ice Machines...
Why ismaytag bottom freezer leaking water?
Try clearing all vents - inside (make sure vents not covered - in fridge and freezer) and outside (gently vacuum - the coil areas in the back and bottom of fridge)
Sep 05, 2014 | Maytag MBF2258XEW 21.9 cu. ft....
Frigidaire FFHS2311LWD has water pooling up and freezing bottom drawer and lower vent. Drain tube doesn't seem to be clogged. Water leaks onto floor some days.
the drain tube is most likely clogged. if the lower vent is freezing up there is no way to confirm because it is covered with ice. the reason water leaks onto the floor is, the refrigerator goes into defrost, frost melts and runs down the ice to the door. use a hair dryer to remove all ice, then use hot water to check drain. drain tube may be up to a foot long and may have a trap. you may have to go in through the back to gain access to the drain
Oct 22, 2013 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Hoshizaki ice machine makes ice but won't drain. Makes ice but won't drain properly, after about 3 or 4 days water starts leaking out of the machine onto the floor. Removed all ice and water and repeated...
My first question is, does the drain have a vent in it? If not, you may need to install one to be able to break the vacuum experienced when the unit flushes after a drop of ice. The vent will be a tee off the drain and a stand pipe that goes up about 5-10" vertical. My next question is has the drain in the plumbing (not the ice machine) been flushed, snaked or tested to see if it can handle the amount of water the ice maching dumps?
Jan 17, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Refrig/freezer not cooling/freezing
your gonna have to let thr fridge defrost buy shutting it down because it soundsm like you have either a build up of ice it the vents in the back of the frezzer unit also check to see if you can hear the fan working in the frezzer if not that would be you main problem
Jul 26, 2009 | Freezers
LEAKS WATER WHERE WATER LINE GOES INTO FREEZER.
An easier fix is to redo the connection. Turn off the tap the supplies water to refrigerator, should be on your cold water line under the sink. Remove not on the solenoid valve(blue valve) slide the nut further up the vinyl tubing cut the tubing above the old connection. push the tubing into valve and tighten nut finger tight. turn the tap on a little and check for leaks at the solenoid. If no leaks open tap all the way. If leak tighten nut a little more only until leak stops. then turn tap on all the way.
Jul 12, 2009 | Freezers
I have a Kenmore upright freezer-model LFFH2067DW2 -the red light has been on for at least 12 hours and the freezer is defrosting-water is leaking on the floor-there is a vent insidethe freezer and the...
I was made aware of your concern and would like to offer a few ideas you may want to consider. Water dripping down is not a leak during defrost condition as this would be the ice melting. Normally, there would be a drain hose specifically to channel the melted ice/water to a drainage system. The amount of water would then be proportional to the amount of ice melting as with the length of time to completely melt, drain away.
Perhaps you could check the filter/drain screen as well as the drain opening for any blockage/clogging. You could also try checking the same on the drain hose as well as for possible kinks. Additionally, there would be a sensor behind a boxy cover that triggers the system back into operation. If there is still melted ice/water inside the freezer, then the sensor would prevent the unit from turning on completely. You may want to check this sensor and verify that it is dry.
An exploded parts diagram would help you identify/locate the above mentioned parts.
Good luck and thank you for using FixYa.
Feb 07, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Frigidaire upright 13.7 cf
Will it freeze water? The vent coming into the freezer may be blocked. Check that and see. Is the refrigerator keeping those items cool? You may also have a vent blocked by the fan cover (dusty). If all this is right, you may have a freon leak or worse a compressor or evaporator going bad.
Feb 02, 2009 | Frigidaire 13.7 cu. ft. / 388 liter...
Water leaking from underneath the unit
hi thanks for the question is there water inside the fridge or freezer if not then the leak is coming from the drain tray at the back make sure the drain hose is located in the tray not outside the drain tray thanks the appliance doc
Sep 27, 2008 | Freezers
Victory Freezer Freezer, Reach-In, 2 Door, 45 cu. ft. Logo
59 people viewed this question
Top Victory Freezers Experts
Dennis Boxerman
christian nielsen
David Emmel
David Emmel
Are you a Victory Freezer Expert? Answer questions, earn points and help others
