Question about Samsung SCX 4200 All-In-One Laser Printer
Replaced toner cartridge with compatible from inkgrabber.com. Printing is very noisy feeding paper and output has white horizontal strips (looking at it in portrait mode).
  • 360 Answers
Hello replae the toner or you have to clean charger roller on toner cartridge
Posted on Aug 23, 2010
My phaser 6180 color printer, toner not adhering to paper
hi.it could be your print cartridge.end of life.and very costly
Nov 19, 2013 | Xerox Phaser 6125 Laser Printer
Printing with a HP5500dtn and I'm getting a white horizontal line towards the top of my paper when printing.
Check the ETB belt for a horizontal scar.
Next check your toner cartridges. One of the drums may have a scar.
Under DIAGNOSTICS Menu, run PQ Troubleshooting.
See if any of the colors give you the white line.
Because you said that only one line occurs, I'm inclined to go with the ETB belt.
Check it good for the horizontal line.
Apr 06, 2011 | Office Equipment & Supplies
HP4+ print quality was perfect, but printer was jamming, so I replaced all the roller parts in the Maintenance Kit, which corrected all jamming! All the paper rollers and the transfer roller is now...
Run the 1/2 test.
Load paper in the manual feed tray.
Print anything that requires more than 2 sheets.
As the paper enters the printer open the top cover.
Remove the toner cartridge.
Look down at the paper.
If it looks like the problems you described, change the toner.
If it looks good, reinstall the old transfer roller and rerun the test.
If transfer roller doesn't fix it, you have a bad fuser. Put the old one in and repeat.
Jan 09, 2011 | HP LaserJet 4 plus Printer
Our copies are streaky like the drum is not clean.... help! There is black streaks on the top of all of our copies on our canon imagerunner 3300.
A) Black Streaks, Shadows, And Ghosting
Adjust the printer's lightness/darkness setting to 2-3 different variables and see if problem disappears. Look at the fusing assembly - is the roller torn or does it have any black buildup? Use caution!!! It gets HOT!
Try another toner also.
Feb 17, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
I have smudges that appear horizontially in a repeating patter
Hi fpugliese630:
1. Remove the paper tray and look inside the printer on the upper part and you see two rubber feed rollers, (they should be a white color) if they have toner on them that could be one of you problems,you would have to clean or replace them if they are worn.
2. you can run whats called a half test, print any document and while the document is printing open the front cover when you think that the paper is under the toner cartridge so the printer will stop. look at the printed page to see if the mark is there. If the mark is not there than you have a problem with the fuser assemble.
Note*
Make sure that the paper path is clean.
Jan 08, 2009 | Lexmark T632 Laser Printer
I am having trouble printing out plates (on a coated glossy stock) for our printing presses. Sometimes I will get a ghosting line across the plate, other times there will be marks across the plate like the...
I know you have replaced the toner cartridge but have you replaced it with the HP Brand. Also, what model do you have? I have taken many, many calls on remanufactured or compatible toner cartridges for steaks, reprinting and and even paper feed problems because they leak.
Nov 03, 2008 | HP Office Equipment & Supplies
Paper Jam Problem in Canon LBP 2900
I have a same problem .... somebody help us. :(
May 23, 2008 | Canon LASER SHOT LBP-2900 Printer
Ricoh Aficio cl2000
Most of the time when I find this happening on a printer, not just Ricoh's it turns out to be the PCU (photo conductor unit). The color PCU is one unit and the black is a seperate unit. Hope this helps.
Dec 17, 2007 | Ricoh Aficio CL2000 Laser Printer
Samsung SCX 4200 All-In-One Laser Printer Logo
46 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
