Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
7920 ProHeat replace red pulley on the pump
I need to replace the red pulley on the pump that the belts connect to. The brush belt burned the gears. Where can I get the part? thnx, Rabar
    Problem Solver:
  • 3 Answers
I did ALL the suggested things and then discovered the belt was stretched because the Red thing on the pulley of the pump is stripped. Its not turning the shaft in the pump. I am going to put glue in mine and see if that works, if not, ill order a new pump assembly.
Posted on Mar 31, 2012
    President:
  • 1,673 Answers
Pulley only comes with the pump. So you have to replace it, 2107181 it will cost about $30
Posted on May 13, 2008
HOW DO i FIX bISSELL pROHEAT BELT
Hi, it's Cindy from Crucial Vacuum.
Your Bissell 9200 Proheat 2x vacuum's brushroll is connected to the motor by two different sized geared belts. Over time, the belt's gears wear down and stretch out losing the grooves and tension that turn the roller. Another cause could be there is debris stuck on the roller and/or bearings. To gain access to your belts, follow the steps listed below:
1. Step on the release pedal and recline the handle down.
2. Remove the Tank-In-Tank and SmartMix Tank.
3. Using a flat head screwdriver to gently pry the access door, remove belt access door located near the floor cleaning switch nearest to the handle.
4. On the bottom of the machine, use a Phillips head screwdriver to remove the red retainer plate.
5. Remove the black brush arm holding the brush in place.
6. Locate and adjust the two belts.
You can purchase direct your replacement belts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com viewers, use code: FIXYA10
http://www.crucialvacuum.com/bissell-proheat-steamer-belts-2pk.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Cindy Yuk
Crucial Vacuum Customer Care
Apr 23, 2014 | Bissell 7920 ProHeat Pro-Tech Upright...
I have a bissell 7901-1 carpet cleaner and the gear the runs the beater bar is loose how does it connect to the pump thanks
turn your unit over so you are looking at the bottom (side towards floor) on either side of the brush are a phillip's screw- one side will show a larger red piece- take that phillips screw out, it will show you the pump you can take the belt access cover off and see the one belt, the belt to the beater brush is gear like- take the belt that connects to the brush and loop it over the gear on the pump- then put the brush belt over the brush and seat it back into the protector- I would suggest you hand spin the brush to ensure both belts and the pump are turning otherwise You may do like I did and burn the other belt- I replaced both belts just because it made sense- reseat the red piece you removed then replace and tighten the screw-
Nov 22, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
The brush is not turning
That pulley is part of the pump, you will have to replace the pump.
Jul 31, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Where can I get a hard copy of manual for Bisell 7920 ProHeatr
Try bissell.com, part number for the owner manual is 2105811. It has 2 belts, one for the pump and a cogged belt for the brush roll. Take off the belt cover on the left side and you can see the flat pump belt, if it looks ok, then turn unit over, remove the red arm retainer, has one screw, then the you can pull the arm loose and off, the cogged belt is there. If not broke, then look at the end of the pump, it is a double pulley, the inner one is for the flat belt, the outer one has a cogged pulley, the cogs may be worn down, or it has broken off, in which case you will have to replace the pump, the pulley comes only with the pump.
Jul 09, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell Proheat Shampooer
Take off belt cover on the left side of the top cover, turn cleaner over, take out screw from red lock and remove, pull cap and brush roll out, unhook the cogged belt, then you can replace the pump belt thru that opening. Put belt over the pump pulley and stretched to go over the motor shaft. Then check the cogged belt and the cogged end of the pully to make sure that there are cogs, replace belt if there are cogss missing or belt is broke, if no cogs on the pulley, then you will have to replace the pump. Pulley only comes witht he pump.
Jul 03, 2008 | Bissell 1699 ProHeat Clear View Upright...
How to change pump belt on bissell pro heat
First take off the cover on the left side oif the top cover, then turn it over, remove the screw holding the red lock and pull the cap and brush roll out, remove the cap, remove the cogged belt, then you can put the new pump belt thru that slot, put over the pulley on the pump and then stretch it to go over the motor shaft. Then put back together.
May 05, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
How to fit new drive belt
May 02, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell Proheat Clearview - Belt and pump keep melting
Is the brush roll turning freely? Is there something binding the pump pulley or belt casuing it to not turn? Was the replacement pump a new one? If you replace these parts again, after doing so, try turning the pump pulley by hand to see if it will turn the brush roll easlly, if it doesn't then there is a problem.
Apr 15, 2008 | Bissell 1699 ProHeat Clear View Upright...
No suction
I had exactly the same problem with my five-year old my Bissell 7920, and it's probably a broken pump belt.  See page 19 of your instruction manual for how to replace.  The Bissel ProHeat belt accessory pack costs $3.99 and you get a pump belt and a brush belt.  Since you have to first remove the brush belt to get to the pump belt, you might as well replace both. The first time I did this it took me 15 minutes, but now that I know the drill, doing a belt replacement would take about 3 minutes.
Apr 10, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
No carpet cleaner coming through
Apr 06, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
183 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
