Question about Skil Saws
I'm trying to replace the power cord on my circular skilsaw. How do you get the wires from the old cord to release from the trigger switch?
  • billwingate Aug 26, 2010
    I tried using a small screwdriver. I'll try the paper clip next.
  • 2,176 Answers
Using a paper clip straighten one end and insert next to wire and push down and while doing so lift the wire out.
Posted on Aug 26, 2010
Where do you wire power cord on skil circular saw 5400 to switch
Very easy to tell the short wires go to the cord side. The longer ones go to the motor. The wire will be same color as the cord wires. They will come from the back of the switch as it sets in saw.
Mar 30, 2014 | Skil 5400-01 7-1/4-in Skilsaw
Skilsaw wormdrive stops working but if I wiggle the cord at the handle it sometime starts and will run until I take my finger off the trigger. Now it won't start at all even after wiggling the co
Replace the cord. Cords get internal breaks by the handle or boot because that's where they have the most bending movement. The wires break inside where you can't see them. When you wiggle the cord the connection is remade, usually with a spark hot enough to hold them together for a short time. When the saw turns off and the cord moves again the weak point breaks again. You can test this by pluggin in the cord and checking for voltage where the cord attaches to the switch.
Jun 28, 2012 | Skil - Skilsaw 77 Saw Hook - / Bosch...
How to open replacement switch for 5250 skilsaw
Sometimes the wires are push fit and are held in with a sprung wire. If they are on this one try using a very fine jewlers screwdriver or stiff piece of thin wire to release the wires in the switch.
May 26, 2012 | Skil 5250 Circular Saws
On a skilsaw 5150, I'm just trying to see if it
Hello, No such thing as a "dumb question"... everybody learns something for the first time. The safety is a button located just behind the trigger mechanism ( about where your thumb would be during operation) and must be pushed prior to squeezing the trigger. Since it is a selling feature of any item to have an operator's manual with the item, I am attaching the link to the english version.
http://www.skileurope.com/common/manuals/_Private/5150/5150-GB.pdf
Hope this helps!AYEUH
Aug 19, 2011 | Skil Saws
No power when i squeeze the trigger on the hd77
Troubleshoot the problem. It could only be a few things: 1) defective trigger/switch, in which case you can replace it by getting the part from a specialty tool store; 2) the cord itself, either where it plugs into the saw or at the plug end there may be a loose wire; 3) you've accidentally cut or nicked the cord--easily done--and there is a severed wire.
Jul 31, 2011 | Skil Circular Saw 7 14" HD77 Worm Drive
I sawed the power cord in half...! It was a skil saw brand But obviously I am 'unskilled'... The saw cost about $65. Can this be repaired or should I get a new saw...?
Yes it can be repaird. No offense, but can you do it? Take handle appart, may have torx screws, and remove old cord. You can buy a new exact replacement cord or a generic cordset to replace. Check wire size on your old cord.
Jul 25, 2010 | Bosch 7 - 1/4" Skilsaw Circular Saw
The switch is intermittent. The saw has #5375 on the nameplate. I t has the two-handed safety switch where you have to push the red one with one hand and squeeze the trigger with the other hand. Sometimes...
Simply the switch will need replacing and this can be obtained from the mfr or you can get it repaired at a local tool repair center. Get it replaced asap.
Sep 28, 2009 | Bosch 7 - 1/4" Skilsaw Circular Saw
I have a Skilsaw Model 77 Type 16 and I need the power switch
i think skil was taken over by ryobi some time back
Jul 26, 2009 | Saws
Table saw skilsaw model number 3400 15 amp
What you are describing sounds like the power is being interrupted somewhere. In my experience, this is usually casued by a bad switch. Try replacing the trigger switch.
Dan
Oct 19, 2008 | Bosch 7 - 1/4" Skilsaw Circular Saw
Saws Logo
462 people viewed this question
Top Skil Saws Experts
JOHN LAPIER
Tejodhar Atreya...
Tejodhar Atreya...
Are you a Skil Saw Expert? Answer questions, earn points and help others
