Question about Dell Inspiron 531s Desktop Computer
It will not go further than the opening dell logo
  • 1,472 Answers
Lkirbyjjpt_1
To clarify with you does the system just hang on the Dell logo or does the screen go blank. Also you should have some diag lights on the fround of the system (1234 or ABCD). Let me know if you see them and what ones are lite up.
Issken
http://www.fixya.com/users/issken
Posted on Aug 24, 2010
I have a dell laptop. When I turn it on Windows comes up and it stays on the screen that says windows and has the bar that goes from left to right to tell you it's booting. It never stops doing that. I...
Shut the system down by holding the power button for 5 seconds or more. Turn the system back on, as soon as the blue dell logo goes away tap f8 on the keyboard. This should bring you to a menu from which you can select "safe mode". See if it starts in safe mode. If so, troubleshoot further from there. If not press f12 on the dell logo and choose diagnostics. Run a quick scan, see if any errors are returned for the hard drive.
Feb 24, 2011 | Dell Latitude D600 Notebook
I have a dell inspiron E1405 laptop. when i am not using it for half an hour after opening it it is going into the following error: error code: 0148 message error code: 2000-0148 message unit:...
Go to
http://support.dell.com/support/0148
For further support as you have a hard drive error.
Hope this helps.
How to run PSA Diagnostics
Article Summary: Instructions on how to run the PSA Diagnostics, and an Error Code list with possible solutions. Table of Contents:
  1. Start the PSA Diagnostics
  2. Error Code List
Step 1: Start the PSA Diagnostics
  1. Restart the system.
  2. At the Dell logo screen, press <F12>.
  3. new_note.jpg Note: Some systems do not have an F12 key, to access the boot options you have to press the <0> (zero) key at the Dell logo screen.
  4. At the One Time Boot menu, press the <Down> arrow key to highlight Diagnostics, then press <Enter> to begin PSA.
  5. Write down any error codes listed.
  6. Use the list provided in the next section to see what the error code means.
Feb 16, 2011 | Computers & Internet
Note book locked on password and i cant open the notebook
Please check when you get the password, if you get a password after the Dell logo before the Windows logo then its the BIOS password. - You need to contact Dell for the same.
If you get the password after the windows logo - windows logon password, then you need to specify the windows version for trying to bypass the passwords.
Dec 25, 2010 | Dell Inspiron 1545 Notebook
I turn it on and the dell logo comes up and then the screen goes blank. Already had the hard drive looked at. All is good.
Try it on another PC, if it still does not work, please read below:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Replacement bd: www.lcdrepair.us
May 26, 2010 | Dell E173FPb 17" TFT LCD Monitor
Logo appears then a blank screen
You need to open it up and inspect the PCB for bad solder connection or over heated components. BenQ made monitors for Dell, so look at some pictures of failed Dell monitors here to get some ideas what could have gone wrong with your monitors, post back what you see so we can guide you further: http://s807.photobucket.com/home/budm/allalbums
Mar 22, 2010 | BenQ FP71E 17" LCD Monitor
My dell inspiron loads the dell logo but wont go any further
When the logo appears press F2 immediately and you will get into BIOS settings. Check to make sure that under BOOT DEVICE or DRIVE CONFIGURATION that a hard drive is listed. If it is then listen when you turn the laptop on that the drive is making some sound.
The drive may be bad but it also may have a corrupt start up file which can often be repaired using an install CD.
If you have important data you want to save, I recommend you get the drive out of the computer and use a portable back up drive case/connector to transfer the data to another computer. If the drive is just beginning to fail, this may be your last chance to save important data.
Let me know if I can be of additional help.
JC
Jan 31, 2010 | Dell Inspiron 2200 Notebook
Factory setting on my studio dell computer
Boot up press Ctrl + F11 @Dell Logo screen and the Dell pc restore by symantec will pop up
any further help let me know
Nov 05, 2009 | Dell Computers & Internet
Dell 8400 Refurbished by with WinXP Pro preinstalled will not boot up. Gets past Dell XP Logo, then goes to blank screen with curser...however, keyboard locks up and can not get any further? What's th
windows is not loading properly.
if you're not worried about anything on the computer:
insert the recovery CD, boot the system to the CD, and reinsatll windows.
May 19, 2009 | Dell Dimension 8400 PC Desktop
With lan card
please restart your system and at the blue dell logo keep tapping the F2 key, the bios setup screen will open, check in here if the lan card is enabled here or not. if not enable the lan card, once it is enabled from here windows will detect it and prompt you to install drivers.
Further Queries are welcome
If you find my solutions helpfull please do rate me
Feb 21, 2009 | Dell Inspiron 1100 Notebook
Dell Inspiron 531s Desktop Computer   Logo
35 people viewed this question
Alun Cox
