Question about Xantrex Technology DR3624 Inverter/Charger
I need a control board. - Xantrex Technology DR3624 Inverter/Charger
  • jimmy lee Nov 06, 2011
    I need a control board for a 32" samsung ln-s3251d lcd flatscreen tv.
  • 10,515 Answers
You could buy the control board from :-
http://cgi.ebay.com/Xantrex-Inverter-Repair-Board-DR3624-Control-Board-/260652658387?pt=LH_DefaultDomain_0
I hope i have been helpful.
Thank you!!
Posted on Aug 21, 2010
How to fix error code H1
Frigidaire Refrigerator Error Code = SY CE
Condition = Communications error at power up
Repair or Check = Check wiring between control board and user interface
Parts Needed = Control board or User interface
Frigidaire Refrigerator Error Code = 4
Condition = Fridge and the control board goes through cycles but does not detect a damper connection
Repair or Check = Check air damper
Parts Needed = Air damper
Frigidaire Refrigerator Error Code = 5Y EF
Condition = Evaporator fan circuit failure
Repair or Check = Check wiring between evaporator fan and control board
Parts Needed = Evaporator fan or control board
Frigidaire Refrigerator Error Code = EF
Frigidaire Refrigerator Error Code = dF
Condition = No defrost circuit
Repair or Check = Check wiring between defrost circuit and control board
Parts Needed = Main control board or Wiring harness
Frigidaire Refrigerator Error Code = H1
Condition = Freezer sensor shorted in freezer display
Repair or Check = Check wiring between thermistor and board. If correct, replace thermistor
Parts Needed = Thermistor (temp sensor)
Frigidaire Refrigerator Error Code = 5y CF
Condition = Communications failure at power up
Parts Needed = Control board or user interface
Sep 28, 2016 | Refrigerators
I want whirlpool oven mechanic in kakinada
see the details and proceed according. fix it. God bless you
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Nov 15, 2012 | Whirlpool Microwave Ovens
My garage door is not working is like not electricity
All you need is to use a multimeter to check the input voltage to the control board , ALso check the motor with a test to confirm the fault on the control board.
Only if you are tech savy can you be able to identify the faulty part as the control board circuit needs to be checked for the drive parameters.
If not get help to replace the control board or send it for repair to the dealer.
Aug 19, 2011 | liftmaster Garage Door Control Board...
Code F- Won't spin
Hi, it means you have an internal short in the display control board. You'll need to order and replace the relay control board in order to correct the issue. This control board is located on the far right corner under the control panel. Below is a link to the control board you'll need to order and replace. Click HERE.....
Mar 05, 2011 | Maytag Bravos MTW6600T Top Load Washer
My maytag 3000 washer displays f70
Hi
Error code F70 means Control Unit Failure, no communication is detected between the control board & interface. You'll need to use a multimeter to check for the continuity between the Keypad and the control board. Inspect the wiring between the boards. Also check for any burnt component on the control board. You may need to replace the control board or user interface. To be sure whether the boards use a multimeter. Usually if the drum moves then user interface is bad else its the control board. hope this helps...
Daniel
Aug 28, 2010 | Washing Machines
Need help with a ricoh color 6513 with code c400
I assume that should be "SC400"... This is an error which can be reset by turning the MAIN power switch off for a few seconds and then on. The code will be cleared, provided the problem does not happen again.
SC400 - Image transfer belt bias error
Detected Conditions:
- Timing -
While the image transfer belt bias is ON
- Condition -
The feedback voltage is 4.8V or higher, or PWM value is 50% or higher for 500ms continuously.
Possible Causes:
• Poor connections
• Defective high voltage supply board (T1/PCC/BR)
• Defective I/O control board
• Defective main control board
• Worn Transfer Belt
Troubleshooting Procedure:
1. Make sure the high voltage cable and trigger lines are properly connected to the high voltage supply board, I/O control board, and main control board.
2. Replace the high voltage supply board (T1/PCC/BR).
3. Replace the I/O control board.
4. Replace the main control board.
[Signal Check]
• Feedback signal: CN209-9, TP264, or CN211-A4 on I/O control board / CN302-A6 or TP106 on main control board.
• PWM: CN209-10 or TP272 on the I/O control board.
Dec 16, 2009 | Ricoh 6513 Copier
PDP5016H Akai Plasma TV
is the control board the one with the rca jacks on it,for sound and video input?if so email me at mesa1965@yahoo.com,i need one.
Oct 28, 2008 | Akai PDP-5016H 50 in. HD-Ready Plasma...
The tub that holds the clothes does not spin. The water goes in and it takethe soap and softner but will not spin. The timer works and it seems to go through the cycles and fillls and emptys but the tub...
I've only seen one of these belts break in my 7 years of fixing Neptune's. I have replaced dozens of motor/ motor control board kits. Maytag upgraded the washer motors about 5 years ago, if yours is older it's probably got the older style motor. If that's the case you need to verify that the motor control board is getting power from the main control board, if it is, then you need to replace both the motor and motor control board (it comes as a kit). If it isn't you need to put 120 volts to the motor control board and see if the motor spins at 50 rpm (normal agitate speed), if it does, you just need the main control board, if it still doesn't run you need the main board and the motor/ motor control kit. If it has the newer motor, you would also need to test and replace the motor and/ or the motor control board separetly.
Jul 15, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer issues
Could be just about anything. It's all designed to prevent it from spinning if there is a problem. If the motor is still turning, but never gets up to spin speed, check the out of balance circuit. There are two cabinet strike switches and an inertial unbalance switch. Or check the door latch assembly, it's possible for the door to lock enough to turn the 'door lock' light on, but not move far enough to actuate the 'spin enable' switch. Maytag has upgraded the motor/ motor control board for the older Neptunes. If the motor is not running at all, check that the main control board is sending power to the motor control board. If it is you need the motor/ motor control kit (just one part #) If the main board is not sending power to the motor control board, you need a main control board, but you still need to test the motor control board. Take a test cord and put 120 volts to the motor control board, the motor should start turning at 50 rpm (normal agitate speed) if it doesn't you would need the motor/ motor control kit as well.
Jul 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
Frigidaire Washer - pressure sensor
I WOULD SAY REPLACE THE PRESSURE SENSOR IF BOTH CONTROL BOARDS HAVE BEEN REPLACED
THE MOST ECONOMICAL PART ASSOCIATED WITH THE CONTROL BOARDS ESPECIALLY AFTER HAVING ELECTRICAL PROBLEMS IS MORE THAN LIKELY THE PRESSURE SENSOR it may have BLOWN ALSO
Jan 31, 2008 | Frigidaire Affinity ATF7000E Front Load...
Xantrex Technology DR3624 Inverter/Charger Logo
2,520 people viewed this question
Top Xantrex Technology Electronics - Others Experts
Craig Butler
Craig Butler
EE Eddie
Are you a Xantrex Technology Electronics - Other Expert? Answer questions, earn points and help others
