Question about Novatel MiFi 2200 Mobile WiFi Hotspot Modem (Verizon Wireless)
Connection failed - the modem is already in use or is not configured properly Error 633
My modem is not functioning
Uninstall and reinstall your modem driver.
• Click Start -> My Computer -> Properties -> Hardware Tab -> Device Manager
• All items in Device Manager are listed in alphabetical order.
• Select and click on Modems.
• Right mouse click on your Modem
• Left click on Uninstall
• Restart machine and test.
If you receive some errors like
633: The port is already in use or is not configured for Remote Access dial out.
678: There is no answer.
680: There is no dial tone.
777: The connection attempt failed because the modem on the remote computer is out of order.
Then you can use RegInout to fix such types of errors.
Hope it might help you.
Nov 13, 2011 | Dell Dimension 2400 PC Desktop
I am using zte usb modem FFF1 for internet access via reliance netconnect.whenever I connect the device to laptop it is shown as storage device but as soon as i install the driver software a driver not...
The ZTE modem when initially connected to any system loads as a storage device which contains the software necessary to install the modem. Connect the ZTE and open it in Explorer. Double click the setup file (.exe) to start installation. Follow instructions and allow installation to complete. The modem is automatically installed during this setup. Once completed restart and then your ZTE functions as a modem.
May 19, 2010 | Computers & Internet
Can't set up dial-up connection
Restart the computer.
Enter BIOS setup.
Click to "disable" both the COM1 and COM2 (or Serial1 and Serial 2) ports.
Save-and-exit from BIOS setup.
Restart Windows.
The modem should now be assigned as 'COM1', and should work.
Apr 17, 2010 | Arris SM56 (SM-56-PCI) Modem
Error 633
right click on my computer and go to properties then hardware in that click on device manger and choose the modem option just expand the list it will show the modem which you installed just right click on it and got to properties and choose the diagnostics option and there is one tab down query modem it will communicate with modem if you find the character or response that means modem is correctly installed or if it is not that means you need to re install modem driver.
Sep 17, 2009 | Smartlink All 56K Modems: V.92 PCI Chipset...
Can't connect internet. message reads error 633,
Here is a tip to work normally your modem, transfer it to another PCI Slots in the Motherboard and install again with the driver freeware provided. See to it that no other programs run on the system that interrupt your modem installation and diagnose it.
Please rate me.
Thank you.
Sep 15, 2009 | HP BCM5705 Modem
Get error 633
Try to install Avira Free antivirus and Malwarebytes antimalware. Update and scan. Or you can try to install hijackthis to view running processes in your system.
Or you can try to take out the harddrive and scan it to another computer with a good known antivirus.
Apr 28, 2009 | Computers & Internet
Trouble Connecting
Try this Winsock fix: http://www.snapfiles.com/get/winsockxpfix.html
Aug 23, 2007 | Gateway MT6705 Notebook
Open Questions:
See all Novatel MiFi 2200 Mobile WiFi Hotspot Modem Questions
Novatel MiFi 2200 Mobile WiFi Hotspot Modem (Verizon Wireless) Logo
320 people viewed this question
Top Novatel Computers & Internet Experts
ray gallant
Chris
Are you a Novatel Computer and Internet Expert? Answer questions, earn points and help others
