Question about Behringer Xenyx 1002fx Mixer 10 Input 2 Bus with Efx
My beringer europowered 800w mixer blew a fuse ,replaced it ,has blown several more fuse's since,i used a lower 5 amp fuse did not last - 10 amp is standard > is it time to trash this unit?
  • Behringer Master
  • 5,603 Answers
I don't understand because the Xenyx 1002fx draws only 16 Watts so the fuse should be well less than 1 amp why would you put a 5 amp?
And your 800 Watt mixer???... There is something wrong with this model number as the 1002fx certainly is not 800 Watts. Please supply the correct model numbers so we can help you.
The unit is repairable I am sure.
Posted on Aug 22, 2010
The special effects does not work on my europower 3000 mixer
Unfortunatly getting parts to fix older Behringer gear is next to impossible. i would suggest jut replacing it. If the ret of the mixer is working i would imagine it would sell for $100-150.
May 30, 2017 | Music
I have a Behringer PMP5000, after a gig, I accidentlly plugged the outputs from an external power amp, into the monitor sends and powered up the unit. After I realized what I did, I powered down, corrected...
Yes, you blew out components associated with the monitor sends. There are several components including an RF bypass to ground and the driver IC, IC8 and a decoupling electrolytic cap. The repair is going to be extensive as it is likely you will have to remove ALL the panel knobs and screws to free up the circuit board for repair. I have worked on several mixers and have three of the PMP5000's myself and dread removing the main board. I am going to suggest something you might consider: Many of the PMP's fail either in their power supply or one of the amps. Due to the repair cost I would consider getting a scrap PMP with this problem and swapping out the panelboard for yours. Often you can get one with blown supply or power amp for around $200 and I suspect a repair shop is going to charge at least that to repair your unit... Then you will have a spare parts bucket as well.
Oct 07, 2011 | Behringer Europower Pmp5000 Powered Mixer...
After a gig, I accidentally plugged my monitor sends 1 and 2 on my PMP5000 to the outputs of an external power amp, and powered it up.... I realized my mistake, plugged it in correctly, and now the monitor...
You blew the driver chip for those sends... NEVER plug the outputs of power amps into a mixer period... These chips are surface mounted and you will probably/maybe have to take the main board out of the mixer unless they are on the bottom side... I have several of these mixers and I might be able to uncover the main board of one I have open... Here is the schematic for the PMP5000:
http://elektrotanya.com/behringer_europower-p0569_hca2400_sps1000_dpx_pmp-1280s_5000_sch.pdf/download.html
Scroll down to "get manual" and click to download... IGNORE other download links on the page. It looks like you might have blown IC8 on page 5 which is one of the monitor sends. It is a standard NJM4580 chip... a little dual op amp that is SURE to be surface mounted. There is a possibility that capacitor C60 and its mate for MON2 may have been blown so check those. If the board has to come off the front panel... "enjoy" pulling off all the knobs, removing the nuts on the 1/4 inch connectors and possibly the screws from the XLR connector to get the panel separated... Been there, done that...Maybe you will luck out and the part will be mounted on the back of the board... Let me know if you need more help... fredy2 on aol.com
Sep 12, 2011 | Behringer Europower Pmp5000 Powered Mixer...
Hi! I need a SM of my europower pmp 2000
This site for the PMH2000 should be near identicla to your unit:
http://elektrotanya.com/behringer_pmh2000.pdf/download.html
Scroll down to "get manual" and click to download schematic. IGNORE other download links.
The HCA2400 amp module in this has a chronic failure and is hard to work on.
Aug 28, 2011 | Behringer Pmp2000 Europower 800w 10ch...
My europower pmp 2000 powered mixer wont turn on and the fuse appears good. I turned it on and it immediately turned off ,nothing smells burnt. any ideas on what it could be
This is likely a power supply failure, possibly brought on by a failure of one of the amp channels.
This is probably close to your supply:
http://elektrotanya.com/behringer_sps600_power-supply_sch.pdf/download.html
Scroll down to "get manual" and click on that to download schematic. Ignore other download links.
Aug 05, 2011 | Behringer Pmp2000 Europower 800w 10ch...
Fuse blown on Europower PMP 3000. Where can I find a 10 Amp 250 V ceramic replacement fuse?
You don't need to use a ceramic fuse if one's not available. You can also use a glass cartridge fuse as well. Just be sure the rating is the same. Be aware, though, that fuses seldom blow on their own. Usually it's because something else has shorted. So don't be surprised if replacing the fuse only results in another blown fuse. Behringer stuff is notoriously cheap and under-protected, so by the time the fuse blows it's usually more trouble than it's worth trying to fix. But maybe you'll be lucky and it will be something simple. Good luck, and thanks for using Fixya!
Jul 05, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
None of the channels work. Most of the LED lights work. Im going thru the beringer mixer for power but using another mixer.
If you plug into the PA input or inserts of this unit, that DISCONNECTS all the mixing channels within this unit and none in this unit will work. That is how it is supposed to work.
If you wish to use another mixer as well as the channels in this, I suggest you run the other mixer into one of the stereo channel inputs OR the CD inputs, although the CD are NOT balanced inouts and subject to higher noise level.
Feb 01, 2011 | Behringer Europower Pmp5000 Powered Mixer...
My Behringer Europower Pmp5000 Powered Mixer blew one of my speakers and then it burnt out one of the outputs.
Probably the channel A went. If you are fortunate, the power supply is still OK. There are protection circuits for the speakers, however you MUST use speakers that are rated at over 400 Watts. If you use smaller ones, they can get blown. There is a weakness primarily on insulation for channel A and an arc between layers of a circuit board can wipe out several transistors and a zener diode and sometimes a metering resistor. Once this happens, have unit serviced before using it again as further damage can result.
ALSO PLEASE read my tip I posted on FIXYA regarding a grounding hazard when using Speakon to 1/4 inch speaker cables... essentially the barrel of the 1/4 inch jack of the A channel is the hot lead, NOT the tip for that channel.
Nov 26, 2010 | Behringer Europower Pmp5000 Powered Mixer...
No Power at all. Fuse blown-Burn smell from fan area.
You did a lot of damage, and replacing the fuse and trying it has caused much more.
There will be about seven blown parts on the amp and a dozen on the power supply. To give you an idea of the extent, the WHOLESALE parts cost is roughly $50, including the main power supply switchers IGBT's which cost nearly $20 for the pair by themselves.
I have repaired several of these and the larger cousin the PMP5000. It is a lot of skilled work to repair these.
The cause is a marginal insulation between layers of the multi-layer amplifier board. Usually the rearmost amp arcs between the layers. This fries three big switching transistors followed sometimes by a metering resistor and two small surface mounted transistors. A zener diode often goes. The cancer and burned area has to be ground out with a dental drill and new wire replaces the blown circuit traces.
If you are under warranty, take the unit for replacement.
The thing that can arc the amp is if speaker leads are marginal or get pulled out while under power. Excessive volume, especially pulses at high level can break down the insulaton causing the arc and failure. The black smoke is likely from the metering resistor.
Jul 30, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Open Questions:
See all Behringer Xenyx 1002fx Mixer 10 Input 2 Bus with Questions
Behringer Xenyx 1002fx Mixer 10 Input 2 Bus with Efx Logo
229 people viewed this question
Top Behringer Music Experts
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
