Question about Garden
Need to know gas oil mix for echo cs 345 - Garden
50-1 as with all 2 cycle chain saws
Posted on Aug 21, 2010
Gas mixture for Echo 1500 hedge trimmer
Kathy, Gas mixture 50:1, with mid or premium gas.
Check the attached links,manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.echo-usa.com/getattachment/f9348047-25e4-468f-b298-f5927ec23249 2 Cycle Oil Mix Chart
Small Engine Repair How to Calculate or Mix 2 Stroke Oil with Gasoline or...
Jun 23, 2016 | Echo Hedge Trimmer Throttle Cable...
Why does derate lose power?
OK things to check. Gas/Oil mixture make sure you mix it in right amount. Be sure chain is NOT too tight. Now be sure to let the saw do the work . if you put too much pressure on it or,the chain is dull , the saw will loose power. Let me know how it goes.
Dec 03, 2015 | Echo Cs-400 18" Gas Chainsaw 40.2cc Sealed
Vintage Echo CS-302. Ran for years with zero problems. Until now. It starts and runs great for about 320 seconds. It will rev to max rpm, then it starts dying. wah, wah, wah,, shuts off. Repeat,same
check for problems in the carby--replace with a kit
check the filter on the end of the line in the tank-- they tend to block up
check for blocked exhaust--- carbined up inside
don't use E fuels as they will not operate on the E mix
Apr 14, 2015 | Echo Garden
I used fuel from old chainsaws sitting in garage and used it on my Echo CS-330T. I barley got it and it was basically new with a few hours of use. I guess the fuel was old and the gas was probably not...
Use echo 2 stroke oil Do not use ethanol fuel, use a premium fuel and mix with the oil. Empty all the old fuel out of the saw, Fill with fresh fuel. Should solve the problem
Oct 05, 2013 | Garden
Need to know the gas ratio mixture for a Echo Gas Trimmer GT2400 [serial#004349]
hello sir, the gas / oil ratio is, 3/4 o/z per quart or 2.6 o/z per gallon of two cycle oil, any two cycle oil will do,this is how i mix mine and never had a problem,it is a good mix.hope this helps,don't forget the 4 thumbs up,any comments welcome,thank you. ~~
Feb 18, 2012 | Echo Garden
What is the write oil and gas mix for Echo chainsaw CS-370
The right gas mix is 25:1 or 100ml to 4.5 litres
otherwise known as half a teacup to a gallon for US folks
Please rate my help++++Thanks for using FIXYA
Jul 01, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
What is correct fuel mixture for Echo CS 6701 Chain saw?
"Echo Power Blend Universal 2-Stroke Oil can be used in all of our 2-cycle air-cooled equipment ever made. You may also use this oil in any other brand of 2-cycle air cooled equipment, but it should always be mixed at the 50:1 ratio whether or not it was a 32:1 or 16:1 etc. machine. This oil is the highest quality 2-cycle oil on the market today. There is no need to have more than 1 tank of fuel for your 2-cycle equipment any more."
The above excerpt is from the Echo FAQs (6) here:
http://www.echo-usa.com/faqs/
Oil Mix Ratio:
The following ratios have been recommended for the last 10-15 years.
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
McCulloch, Poulan & Wen; recommend 40:1.
1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
Chinese chainsaws recommend 25:1.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 08, 2010 | Echo CS600P Gas Chainsaw 20 Inch
Proper gasoline and oil mix ratio.
My echo uses 50-1 ration. Home Depot sells the small containers for Echo Leaf Blowers that you mix with one gallon of gas.
May 24, 2009 | ECHO, Inc. PB-251C Handheld Blower
Echo CS-302 chain saw with no instructions (Inherited)
the echo cs302 is equiped with an automatic oiler that lubricates when the engine is running the manual states the unit runs on a 20:1 mixture 89 octane fuel with 6.4 oz of tcw3 oil per gallon
Apr 10, 2009 | Echo Garden
Garden Logo
74 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
