Question about Pyle Car Audio & Video
FIRST TIME WIRING AN AMP--JUST PURCHASED THE MARINE PYLY PLMRKT4A 4 CHANNEL AMPLIFIED SPEAKER SYSTEM WITH A PYLE PLCDMR97 RECIEVER--MATCHED SET IN THE BOX. THE INSTRUCTION ARE MINAMAL CAN YOU E-MAIL ME A MORE IN DEPTH WIRING DIAGRAM--MY RADIO HAS EIGHT SPEAKER WIRES COMING OUT-- DO THESE WIRE'S GO TO THE INPUT SIDE OF THE AMP?? [WHICH SEEMS LOGICAL] THE ONLY PROBLEM IS THESE 8 NEED TO SOME HOW PLUG INTO ONLY 4 LARGE WHITE [2] AND RED[2] CONNECTIONS---AMP IS PLMRMP3A 100668 THANX JIM
SparkGap
  • 363 Answers
SOURCE: Hooking up speakers to amp
YES ! This is usually ok, the speaker cabinet should contain a high pass filter or crossover on the tweeter to decouple it from the low frequency signals. My Linn Index speakers are wired like this.
Posted on Sep 22, 2007
SOURCE: Alpine Cdm- 7834 wiring help
bypass amp and run new wires to all speakers ,,,, will sound better .
Posted on Jun 17, 2008
  • 4234 Answers
SOURCE: New speakers to an old (1960s) record player
It is difficult to say with 100% confidence because the pictures are out of focus, but it looks like you have just a regular turntable. The wire connections you show are the bridge between the tonearm and the external RCA style cables. The extra wire (#5) is the ground wire. You should be able to connect this to any receiver that has a phono input.
For confirmation, can you update this with the model number of the turntable? That will allow me to confirm what I have stated above.
Thanks,
Dan
Posted on Nov 13, 2008
  • 14 Answers
SOURCE: DEH-P80MP need wiring/color description
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/103539332INSTALLATION%20MANUAL%20DEH-P80MP.pdf
Installation guide for your model with wiring diagram.
Hope this helps.
Posted on Dec 25, 2008
  • 45 Answers
SOURCE: HOW TO INSTALL
I would say look for a custom box off ebay or build one behind rear seat. Im not shure if you can fit a small truck box behind there but you may be able to. It would sound pretty good behind rear seat. Hope this helps
Posted on Jan 13, 2009
On my pd3000a receiver I have two subwoofer rca jacks but I have a sub volume control so can I still hook up pqa4100 poweramp this is all pyle equipment, please give detailed answer
First, I'm not a Pyle tech. But back in the day I used to be an audio freak (1970's 4 channel all-the-way!)
* I tried to get the exact specs on your receiver but I suspect it's a non-amplified output. RCA jacks almost never have a high level output. (yes, the old 1940-60's used RCA jacks for speaker high level output. But you have a late model receiver.) Most likely you need a separate amp to power the sub woofer (unless it has it's own power amps.) You may still use another audio amplifier if you have a spare (mono or stereo won't mater as you only use one channel) but be aware that low frequency use way more power than normal frequencies (600 to 3KHz) The low end (50 to 300 Hz) will burn out any speaker and amp as the lower the frequency it's like hooking up a car battery directly to the speaker! If you have an old style vinyl record player that's playing a warped record. watch the speaker flap around to the wave of the record. Need to turn on the 50 Hz cancel out button to prevent speaker blowout!
* This link is still for a powered woofer. It looks like the same PD3000 receiver as yours though I can't be sure:
https://www.youtube.com/watch?v=OXEtib5OnGI
* This is an external "Powered" sub woofer (powered amp and additional cross over "filter" to extract just the lower frequencies. The following you tube link is a detailed example of how this type of system works:
https://www.youtube.com/watch?v=ZpSAQDjuWN0
Aloha, ukeboy57
May 11, 2018 | RCA Audio Players & Recorders
How to set the time on a pyle plcd11mrkt marine radio?
Click "Download manual or factory spec sheet", save it to your documents folder, and see page 9 here... http://www.rocktheboatmarinestereo.com/html/67460.html
Jul 16, 2014 | Pyle Audio Players & Recorders
How do i connect a sub wooferto my reciever
I own 2 of these Pioneer VSX-D903S units.
The only way to hook a powered subwoofer up to a VSX-D903S is if your subwoofer is equipped with amplified/speaker level terminals on the back, in addition to the line-level input. If you only have a line-level input, do not attempt to hook it up to this receiver.
If you're lucky, and have speaker-level inputs on your powered subwoofer, you would use the amplified terminals (connect to B-channel on the receiver). DO NOT connect anything to the line-level connection.
Alternatively, you could build two unpowered subwoofers, then set the receiver's Impedance switch to LOW, then connect one enclosure to each of the "B-channel" outputs. Connect your regular left and right speakers to their corresponding "A-channel" outputs. [Impedance range: 4 Ohm minimum, 16 Ohm Maximum]
Jul 20, 2012 | Pioneer VSX-D903S Receiver
Hooked the damn thing up power my subs wonderfully for that evening, and all day today, got in this evening and nothing, checked the amp and red light, ok, fine, checked the manual, says the light protects...
probably something corssed in your speaker wiring. be sure that you did not exceed the ohmage capabilities of the amp, and that no speaker wires are crossed, or shorting out on the frame. if you have too many speakers hooked up, that can reduce the ohmage, and your not supposed to go below 2 ohms -per channel, or 4 ohms bridged mono.
Mar 13, 2011 | Pyle PLA2200 Car Audio Amplifier
My pyle plmra 220 600 watt 4 channel amp blew out, pyler said it would be 50 dollars to send it in to them so i said to heck with that and oppened her up and found a capacitor blown, but when i replaced...
outputs also blown, go to ebay and buy a better amp form the same price you would have paid for pyle to fix that one, just keep playing with that one and you will get better at repairs, thats how i learned to fix amps.
Dec 13, 2010 | Pyle - plmra220 - Marine 600 Watt 2...
2003 Cadillac DTS w/Bose, has rear sub & adding Pyle dual 10 sub
two channel will do with the same power power rating of your speakers ex. your speaker is 500 watts per piece so you need to buy a 500 watts per channel amplifier
May 16, 2010 | Pyle PLHB10 Car Subwoofer
Where can I get wiring diagram?
www.pyleaudio.com/manuals/PLMRA220-420.pdf
Jul 22, 2009 | Pyle - plmra220 - Marine 600 Watt 2...
Amplifier trip while cruising
is it hot when it shuts off? from what you just described sounds like amp could have the "ohms" too low on a channel. Check you speakers with a meter. They should be no lower than 4 ohms.
May 26, 2009 | Pyle - PLMRA420 Marine 1000 Watt 4 Channel...
Trouble connecting marine amp to stereo
Hello lizskates814,
You can use either the high level (speaker) or the low-level (RCA's) inputs to the amp, but not both. Choose whichever one sounds the best or is more convenient to install and leave the other disconnected.
Hope this helps.
May 23, 2009 | Pyle PLMRA400 Car Amp
What is wrong with my system
wiring may not be the problem but try connecting each coil to separate channel and make sure polarities are correct.
Aug 08, 2007 | Pyle PLA2200 Car Audio Amplifier
Car Audio & Video Logo
113 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
