Question about Champion International Champion& Small Engine Spark Plug 8 Pack
Engine firing order for 2007 Chevrolet Equinox
Need all the bolt torque specs for 2005 equanox 4300 from intake on up
https://www.autozone.com/repairguides/Equinox-2005-2007-Torrent-2006-07/Engine-Mechanical-Components/Cylinder-Head/_/P-0996b43f80cb1b76
Feb 01, 2018 | 2005 Chevrolet Equinox
Was there a bulletin issued to extend a warranty for spark plug wires, maybe #10250
Yes....10 years or 120,000 miles
Condition
Some customers of 2007-2009 model year Chevrolet Equinox and Pontiac Torrent vehicles equipped with a 3.4L engine (LNJ), and 2008 Chevrolet Express, Silverado; GMC Savana, Sierra vehicles equipped with a 4.3L engine (LU3) may comment about rough engine operation and the illumination of the Check Engine Light. This may be caused by spark plug wire boots that do not provide a sufficiently robust dielectric seal to withstand the high voltage required to fire the spark plugs.
Special Coverage Adjustment
This special coverage covers the condition described above for a period of 10 years or 120,000 miles (193,000 km), whichever occurs first, from the date the vehicle was originally placed in service, regardless of ownership. Dealers are to replace all spark plug wires and, if necessary, the spark plug. The repairs will be made at no charge to the customer. For vehicles covered by Vehicle Service Contracts, all eligible claims with repair orders on or after January 5, 2011, are covered by this special coverage and must be submitted using the labor operation codes provided with this bulletin. Claims with repair orders prior to January 5, 2011, must be submitted to the Service Contract provider.
Vehicles Involved
Involved are 2007-2009 model year Chevrolet Equinox and Pontiac Torrent vehicles equipped with a 3.4L engine (LNJ), and 2008 Chevrolet Express, Silverado; GMC Savana, Sierra vehicles equipped with a 4.3L engine (LU3).
Mar 03, 2015 | 2007 Chevrolet Equinox LT1
Battery keeps dying
How many complaints would you like!!
Chevrolet Equinox Questions - Weird dead battery situation ...
https://ca.cargurus.com > Questions > Chevrolet > Equinox
Asked by Thad Dec 04, 2015 at 05:59 PM about the 2006 Chevrolet Equinox ... A month ago was the last time i did anything to the car's electrical system .... you know its either a bad ignition connection (corrosion, something loose or the switch ...
40 Complaints: 2010 Chevrolet Equinox Electrical System Problems
www.carcomplaints.com/Chevrolet/Equinox/2010/electrical/electrical_system.shtml It's not us. 2010 Chevrolet Equinox electrical problems. electrical problem ... The thermostat indicator indicated that the coolant system was operating normally.
16 Complaints: 2014 Chevrolet Equinox Electrical System Problems
www.carcomplaints.com/Chevrolet/Equinox/2014/electrical/electrical_system.shtml The 2014 Chevrolet Equinox has 16 NHTSA complaints for the electrical system at ... It's not us. 2014 Chevrolet Equinox electrical problems. electrical problem.
19 Complaints: 2012 Chevrolet Equinox Electrical System Problems
www.carcomplaints.com/Chevrolet/Equinox/2012/electrical/electrical_system.shtml It's not us. 2012 Chevrolet Equinox electrical problems. electrical problem .... Driving slowly the engine and entire electric system shuts down and the car just ...
2014 Chevrolet Equinox Electrical System Complaints
www.aboutautomobile.com/Complaint/2014/Chevrolet/Equinox/Electrical+System interior dome lights went on 2x on their own; infotainment system screen has a delay. Does not consistently display current song title & artist that is playing; ...
2010 Chevrolet Equinox Electrical System Complaints
www.aboutautomobile.com/Complaint/2010/Chevrolet/Equinox/Electrical+System 2010 Chevrolet Equinox Electrical System Complaints, Problems and ... Description of the Complaint: The car shuts off by its self can't pick up speed I can be at ...
2005 Chevrolet Equinox Electrical System Complaints
www.aboutautomobile.com/Complaint/2005/Chevrolet/Equinox/Electrical+System 2005 Chevrolet Equinox Electrical System Complaints, Problems and ... In fact, he said their "senior" repairman said he had never heard a thing like that ... electrical system in Chevy Equinox Google Search
Recalls too
electrical system RECALLS Equinox Google Search
Apr 23, 2017 | Chevrolet Equinox Cars & Trucks
Chevy equinox fires but dies a second later
Check the fuel pump and make sure fuel is flowing properly. Undo fuel ine and turn over engine to see if gas is flowing. Check spark plugs and change if necessary.
Jan 21, 2013 | Chevrolet Cars & Trucks
Firing order for 2007 chevy equinox
Here's a picture for you. I hope this helps and good luck.
May 30, 2011 | 2007 Chevrolet Equinox LS New Cars
I swapped engine with an 07 cam sensor diiferent changed connector and no spark
2005 AND 2007 BOTH HAS THE 3.4L ENGINES.WHEN YOU SWAP IN A NEW ENGINE IN PLACE OF THE OLD ENGINE.NEWER ENGINES WILL HAVE DIFFERENT PART AND SET UP. BEST TO USE THE SAME YEAR ENGINE.YOUR PCM MEMORY HAS YEAR 2005 INFORMATION FOR ALL ENGINE CONTROL SYSTEMS.IF YOU CHANGE TO ANOTHER ENGINE WHICH IS A NEWER ENGINE.THE PCM WONT RECOGNIZE NEWER ENGINE BECAUSE PCM CHIP MEMORY IS SET UP FOR 2005 NOT 2007 THAT WILL CAUSE NO FIRING CONDITIONS.
Feb 25, 2011 | 2005 Chevrolet Equinox
Champion International Champion& Small Engine Spark Plug 8 Pack  Logo
280 people viewed this question
Top Champion International Garden Experts
JohnPaul Robertson
chuck ringwood
chuck ringwood
Dennis Key
Dennis Key
Are you a Champion International Garden Expert? Answer questions, earn points and help others
