I need to get into my motorola sbg900i modem settings
  • 13,433 Answers
Consult your manual
in most cases the address is http://192.168.1.1 to connect to the modem settings.
Posted on May 03, 2008
Wifi discovery problem. I have installed a Motorola SBG900i. All my wifi devices have had trouble discovering the SSID. When I do a scan available networks it does not exist. I forced 2 laptops to...
Assuming you haven't changed your modem's settings...
  1. Access the modem by typing http://192.168.100.1 in your browser.
  2. Enter the default username admin and password motorola
  3. On the left frame, click Wireless
  4. Click on the Security tab
  5. Under the tab, click Advanced
  6. Untick Disable ESSID Broadcast
May 13, 2011 | Arris SURFboard SBG900 Wireless Router...
What wireless is compatible to a motorola modem
Any wireless router should be compatible with your modem.Some are as easy to set up as only plugging the cables in the right jacks and you are done.
Just make sure your Motorola is configured to stay connected 24/7, and instead of plugging it to your computer, plug it to the router. Generally, the routers don't need to be configured.
May 10, 2011 | Arris 221002 DSL Modem Southwest Region...
Lost the security key to my motorola wireless modem
Here's a link to common usernames and passwords for motorola modems: http://www.pcwintech.com/default-router-modem-passwords2
When you find the username and password for your model of router you can access the modem's settings by typing "192.168.1.1" into the address bar of your internet browser. Once you access the settings you can find the password under the "wireless" option and even change it.
May 01, 2011 | Motorola Computers & Internet
I have a motorola 2210 modem and want to switch to a Netgear N150 wireless modem router dgn1000. I unplugged the Motorola modem and connected the Netgear but it does not work? I typed in 192.168.0.1 to...
Yes you need to setup the modem to bridge mode.
below is a guide you can follow on how to setup the motorola to bridge mode.
http://www.dslreports.com/faq/15855
Feb 27, 2011 | Computers & Internet
How to open settings of motorola SURFboard SB5120 modem?
Support for the Motorola SB5120, discontinued product, see next site:
http://broadband.motorola.com/consumers/support/default.asp?supportSection=DiscontinuedProducts
Connecting the device, see the "Quick Reference Guide":
http://broadband.motorola.com/consumers/products/SB5120/downloads/SB5120_Quick_Ref_Guide.pdf
For installing the modem the easiest way is to run the provided cdrom.
When not available perform the settings as showed in the guides.
Motorola 5100 series user guide:
http://broadband.motorola.com/consumers/products/SB5120/downloads/SB5120_User_Guide.pdf
See page 7 "Before You Begin" for the requirements and selecting either USB or Ethernet connection.
Page 22 gives the overview for the pages how to configure ethernet settings.
Oct 31, 2009 | Arris SURFboard SB5120 Modem
My x box keeps saying my mtu settings need set at 1364 or higher i have a motorola sbg 900
Is this a router or a modem? Could you please tell me exactly how your xbox connects to your network?
Jul 17, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Motorola SBG900 settings set back to default settings
This exact problem just happened to me today. I called Motorola & they said this sometimes happens as a result of a power surge (can be on the cable or power lines). All settings were lost & I had to redo the entire set-up from scratch.
Jun 29, 2009 | Arris SURFboard SBG900 (49402201900) Modem
Motorola Router SBG900i blocks download from particular server
The best page for portforwarding can be found here.
It mainly depends on the software and the ports used, so it might differ from application to application.
Portforwarding.com has excellent user guides.
Jan 07, 2009 | Arris SURFboard 2.4GHz Wireless Cable...
Need to hook up Belkin G wireless router to Motorola SB5120
Plug your cable line into your modem, make sure it's tight, but don't use a tool. Next plug the ethernet line from the modem to your PC ethernet port. Then plug in your power to the modem. Allow your modem to sync. Don't use the USB line at all. Do not even hook it up unless your computer doesn't have a working ethernet line. Don't run the disk either, it will only install the modem driver that is only used if you use USB.
If you have issues connecting after that, you may have to go into your ethernet adapter settings and make sure that it is using DHCP. DSL usually uses a different setting (PPP I think) and you will not be able to connect.
By the way, excellent choice in modems.
Jan 14, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Computers & Internet Logo
David Payne
David Payne
